I did some filming with my MiniDV camera, captured it and created an MPEG movie with Pinnacle Studio 7. I then played the resulting movie on my computer (WinXP WMP8) without incident.
When I burned the file (200+MB) to a CD and took it to my fiance's computer (WinXP WMP8), but it wouldn't work. I received the following error.
What can I do?
Forgot to mention that I tried lowering IE6's security setting and I check to make sure this was the latest version of WMP.
When you captuerd the video what codec/settings did you use, you have it installed on yours but not on the other machine?
I told Pinnacle to capture in full DV quality and then to make the movie (after I'd done the editing) in MPEG mode (DVD compatible I think).
All I can do is assume I have a codec on my machine that isn't on her's, but I don't know how to verify that (where are the installed codecs listed?), and WMP says it's up to date on her's. -
Control panel > Multimedia > Devices
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks, but that's not an accurate representation of the Control Panel in WinXP (as far as I can see)
mmm, can't help you there, only had XP on for a week
I am sure you will be able to find it, if I tell you where it is within 98
1, Double click my computer
2, double click the control panel
3, double click the Multimedia Icon
4, click the devices (TAB)
5, select video compression codec's
Can you load the mpeg into TMPGEnc or something, that will tell you what codec's are used.
CODEC problem
By DavidPriest in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2011, 06:39 -
CamStudio codec problem
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 5th Mar 2008, 16:17 -
I think I have a codec problem. D:
By Neverwhere in forum Newbie / General discussionsReplies: 6Last Post: 24th Jan 2008, 16:02 -
WMV codec problem
By coasterfreak212 in forum Portable VideoReplies: 7Last Post: 24th Jan 2008, 11:34 -
codec problem...
By cwb in forum EditingReplies: 6Last Post: 16th May 2007, 11:29
