Results 1 to 20 of 20
  1. Anonymous
    Guest
  2. Member Wolfen's Avatar
    Jun 2009
    Canada
    Well if they're not copy protected dvds then use Freemake Video Converter or older DVD Shrink to copy to the HDD, then you can try this multiAVCHD
  3. You can rip with dvd decrypter or any tool on the list since these won't be copy protected
    The video should already be blu-ray compliant , but the MP2 audio needs to be re-encoded
    Unless you want to re-encode the video as well ? I don't see any reason to, unless you want to compress it farther (in which case you should filter and improve it , which will also improve compressibility)
  4. Anonymous
    Guest
  5. Originally Posted by getaman View Post
    Isn't Bluray videos H264/262 encoded? So I thought I had to re-encode them after ripping :O
    blu-ray can use MPEG2, VC-1, or h264/AVC for video encoding
    DVD material is already blu-ray compliant (just needs to be re-authored)
    But in your case, the audio needs to be re-encoded as well
  6. One tool worth mentioning here also is DVD2BD Express ,it is free and what it does is: it transfers DVD to BDMV structure, menuis included.
    So if you are good with DVD authoring you can do quick reauthoring yourself using some tools (PGCDemux, DVD Lab, avs2dvd etc., or some tools mentioned above), you can reauthor your 5-6 DVD's into one 20GB volume or so and that DVD2BD Express will transfer it to BD structure, creating BDMV folder , you literally just press a button and it automatically does it, I checked that software, liked it. Menu is not HD, it is there just for quick access into video content.
  7. Anonymous
    Guest
  8. Anonymous
    Guest
  9. Originally Posted by getaman View Post
    I was thinking if there is any way to either analyze a video for ghosting or field problems, or if it is possible to correct these problems in encoding to BD perhaps? I have downloaded the programs you mentioned and will look through them of course. I know some dvds look like ghosting or whatever it is (looks ok on tv though).
    If there is none in the DVD, and you're not re-encoding the video, there will be none in the BD
    To analyze for field problems, the absolute best method is to use your eyes looking at separated fields (you might use avisynth's separatefields() ) . Automated detection methods are no good; they make mistakes
  10. Anonymous
    Guest
  11. Originally Posted by getaman View Post
    So in case there would be a field error or ghosting on the vids, by re encoding it to BD it could be fixed?
    Not just by reencoding it to BD but by filtering it properly while reencoding it for BD. And that's if it can be fixed. If you think you see ghosting in your source, maybe post a sample.
    Or would I need an original source for that?
    Isn't the DVD you made your only source? Then it'll have to do.
    Feb 2008
    India
    DvdNextcopy with bd will do ur job with ease and without reencoding.
    Nov 2003
    West Texas
    If you put more than one dvd on the blu ray, DVDNextCopy will not make a menu to select each one. So it is basically useless for compilations.
    MultiAVCHD will work better, if your player is compatible with its output.
    I've also made oversized dvds in AVStoDVD from multiple dvd input, set up a menu, then used this as input into DVD2BD Express. This works fairly well.
  14. Anonymous
    Guest
  15. None of these programs automatically get rid of ghosting or field errors . They are various authoring and encoding tools
    If there is a ghosting or field problem in the source, the problem will persist whether or not you re-encode or just author it. You have to do something to fix it (e.g. apply some filters or manipulations)
  16. Anonymous
    Guest
  17. Banned
    New York, US
    TMPGenc is an encoder (MPEG2). It takes AVI or MPEG input. You can also use its image filters and save the file as Lagarith or Huffyuv AVI.
    From the discussion, it appears your video needs some cleanup. You can do that in Avisynth or VirtualDub, but you'll have to decode to lossless AVI, then re-encode. You're re-encoding anyway.
  18. Yes, if you are reencoding you can add any filters you like -- but your video is already blu-ray compliant so there is no technical necessity to reencode.
    Remember a reencode always loses quality even if it seems perceptually better.
  19. Banned
    New York, US
    Filter in a lossy-encoded state? The damage will be more than "perceptually" worse. It will be garbage. Period.
    But the O.P. states that quality is not a consideration (should be obvious by now). So why does ghosting matter?
