i have the kylie agent provocateur mpeg wich when i check its details are
ftype file (mpeg)
ms dos name klyie~1.mpg
how can i make this better quality to put on a vcd
cheers
i have tried videomi encoder but it failed
any help apreciated
cheers
am i right in thinking mpeg 2 or 4 are better quality ? if so thats what i want to convert to or if you have a better idea would be great
thanks
Have you ever heard of the saying garbage in garbage out. Simply encoding an mpeg1(VCD) to mpeg2(SVCD) is not going to improve picture quality, in fact it may well make it worse, as each time you reencode the video you loose detail due to the compression technique. The only thing you might be able to try is to add filters such as noise reduction, smoothing etc. in software such as Vdub.
Craig -
mrg,
You can never take something and encode or convert it into a better quality. What you can do however; is convert your video there, to a VCD compliant standard and then be able to trow it on a CD.
Regards,
John Brondum -
mrg,
in short, you don't make ANYTHING better quality once it's in
it's final format.
ie, say you encode a clip... that clip gets compressed and
looses some detail, etc.
NOW, you wanna RE-encode it to another format? or, just re
encode it to a better quality?? Naah. Not gonna happen.
Sure you could filterize the hell out of it and maybe clean
it up at best, only adding artifacts, etc to the re-encoded
clip. That's about it. really. So, you will re-compress
again on itself, again, loosing more detail, hence quality.
No, you can't "make better quality" from another encode.
But, sometimes, IF the source (ie, in your case, "klyie~1.mpg"
was of a DVD source, AND, done perfectly enough, no blocks,
etc. then maybe you would get "about" the same quality as
the orginal. I've done a few like this on some of my OWN
DVD encodes to SVCD, and then re-encoded those clips to say,
VCD. So, it really depends. But, mostly no, if it's from
the internet. You don't know what/how these clips were
perduced. And just because it looks great (ie, divX) on your
PC, doesn't mean it's gonna look even better if you re-encode
it to a VCD for instance. That's about it. Does that answer
your question(s) ? I Hope.
-vhelp -
cheers guys for the replys .
question answered and id have spent ages trying to make it better quality id have thought it would have been quite easy to do but now i know
cheers
How to make the best quality TV RIP in Avisynth-Megui?????HELP please
By rijubrata in forum Video ConversionReplies: 10Last Post: 5th Feb 2011, 05:26 -
How do I make my youtube quality better?
By bojadada in forum RestorationReplies: 3Last Post: 1st Jan 2010, 17:35 -
How to make DVD movies in high quality
By bell in forum Authoring (DVD)Replies: 11Last Post: 2nd Nov 2009, 09:42 -
Which format produces better quality overall MPEG-2, MPEG-4 or .x264?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2009, 04:00 -
how to improve my code to make better video quality?
By George2 in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2009, 09:29
