Hi all, this is my first post on this board and it's looking great and the people here are so friendly. The tutorials are amazing! But anyway onto my problem: I can never play my burned VCDs on my DVD player! I have two DVD players of the same model (sony DVP-S330) and neither will play. It spins for 5 seconds then stops and displays 'NO DISC.'
I've tried two software titles and neither works: Easy CD Creator Platinum 5 (the Video CD function) and VCDEasy. I'm running Windows XP Pro.
Could the problem possibly be my discs? They're pretty shitty. They're made by PNY Technologies, they say "80 min./700 MB," 16x speed. They're blueback and I bought a spindle of 100 (it was a steal, just $20) They work just fine for software and music. I've never tried any other kind of disc, could this work?
What am I doing wrong?
hi,
Your palyer Does not support CD-R Palyback. You have to use CD-RW in order to play it in the player. Any have have you tested any CD-R audio cd on the dvd player. i belive it will not play . Check that out if it plays the CD-R audio then it is some thing the way you burn it or so -
i have a dvp s-350, and the unics cd brands that works are vivastar and precision, the rest did not work.
I have the same problem. I'm using VCDEasy to burn and neither of my Sony DVP S330 nor Sony DAV-S300 will play (both play purchased VCDs). However, my laptop's DVD player plays burned VCDs, so at least I know the burning was successful. I've read the Vivastar CD-R works on Sony DAV-300, but I can't find any retailer here in the US. Not even was I able to make a purchase on Vivastar's website. Sony players have good quality but they are just not very compatible with the rest of the world!
Help!!! E30:00 Error Code on (old) Sony DVP-S500D ???
By mlloyd1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Oct 2011, 13:12 -
Cannot play Zone 1 disc on my Sony dvp-sr100 DVD player
By lea in forum DVD & Blu-ray PlayersReplies: 12Last Post: 23rd Apr 2010, 13:24 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2010, 23:56 -
Sony DVP S360 DVD player - No DISC problem
By weenie02000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Aug 2009, 08:43 -
Sony DVP S360 DVD players - No DISC ERROR
By parmar in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Dec 2007, 09:44
