I can't seem to find a player that will autodetect the fact that I put a VCD into my computer. I didn't think I had to have a DVD Rom in the machine to play one. I can browse the CD and play parts of the disk, but I made it with Nero and made a menu for it, and I can't load the menu on my pc. I CAN, however, put it into my APEX DVD player for my TV and it autoloads and plays the menu just fine. What software will do that for my PC? And again, do I have to have it in the DVD rom drive or just any CD drive? Any help would be appreciated m8s.
Thanks,
Tandem
See http://www.vcdhelp.com/autorun.htm
I have used the method at the bottom at http://www.pcphotovideo.com/burning1.htm but not with a menu VCD
Da Kitty -
usally a vcdplayer will dectect your vcd and play the menu
a good program to use would prolly be power vcd player or go to the tools section to check out for som good "free" players you can dl and use.
http://www.vcdhelp.com/vcdtools.htm
F1!! F1!! F1!!!
Custom menus will not play back
By janlafata in forum Authoring (DVD)Replies: 3Last Post: 1st Jan 2009, 00:26 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 19:28 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 01:34 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 11:46
