Page 7 of 12
FirstFirst ... 5 6 7 8 9 ... LastLast
Results 181 to 210 of 359
  1. Hi there, I would suggest to start by posting the last projeject log file, to better understand the source titles properties and the encoding settings you have already tried.
    Bye
    MrC
    AVStoDVD Homepage
  2. The audio is roughly 3 seconds behind the video, so I was playing around trying to see if I could do anything to get things back in sync. If you see any other settings I should probably change, LMK. Thanks for the help.
    <12/25/2017 12:47:50 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 4449/4450 MB (100%)
    DVD Output Setup: ISO UDF Image
    DVD Label: G
    DVD Menu: Static Menu
    Output Folder: C:\Users\M\Desktop
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 0
    FPS Hard Conversion: 0
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    Video BitRate Min: 2500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: E: TSSTcorp CDDVDW SH-222BB SB00
    DVD Burning Speed: 8x
    Auto Erase DVD RW: 1
    Execute with Elevated Privileges: 0
    Unload ActiveMovie Library: 1
    Adjust DirectShow Filters at runtime: 1
    Save General Settings: 0
    SYSTEM INFO
    Processor Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
    Operating System: Windows 10 (10.0.16299) 64 bit
    User has Admin Rights: YES
    Running with Elevated Privileges: NO (3)
    Available Output Disc Space: 52 GB
    AviSynth is installed: YES (release 2.6.0)
    LAV Filters is installed: YES (release 0.70.2)
    ffdshow is installed: NO
    CODECS REPORT
    H.264/AVC: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
    Xvid: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
    DivX 4/5/6: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
    Other MPG4: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
    DV: DV Video Decoder {B1B77C00-C3E4-11cf-AF79-00AA00B67A42}
    MPEG1: MPEG Video Codec {feb50740-7bef-11ce-9bd9-0000e202599c}
    MPEG2: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
    MP2: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
    MP3: MP3 Decoder DMO {BBEEA841-0A63-4F52-A7AB-A9B3A84ED38A}
    AAC: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
    AC3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    TITLE 1 SOURCE FILES
    Video: C:\Users\M\Music\Documents\Favorites\Downloads\G.m p4
    Info: AVC - 4288 kbps - 1280x720 - DAR 16:9 - 29.97 fps (CFR) - Progressive - 1:35:23 hours - 171498 frames
    Audio 1: C:\Users\M\Music\Documents\Favorites\Downloads\G.m p4
    Info: AAC LC - 126 kbps - CBR - 2 ch - 44100 Hz - 1:35:23 hours (0 ms delay)
    [MediaInfoLib - v0.7.77]
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Users\M\Music\Documents\Favorites\Downloads\G.m p4", CacheFolder="C:\Users\M\AppData\Local\Temp", VFR=false, FrameRateNum=2997, FrameRateDen=100, FrameRate=29.97)
    Audio = A2DAudioSource("C:\Users\M\Music\Documents\Favorites\Downloads\G.m p4", CacheFolder="C:\Users\M\AppData\Local\Temp")
    Video = Video.ConvertToYV12()
    Video = Video.Spline16Resize(720,480)
    Audio = Audio.SSRC(48000)
    AudioDub(Video, Audio)
    DIRECTSHOW AUDIO MIXER OPERATIONS:
    No LAV Filters mixer ON/OFF adjustment required at runtime
    START VIDEO ENCODING OPERATIONS
    Video Encoding Profile: HCenc VBR 2-pass
    Target Video FileSize: 4218.9 MB
    Encoding Parameters: -ini "C:\Users\M\AppData\Local\Temp\G.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\M\AppData\Local\Temp\G_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\M\Videos\G.m2v
    *LOGFILE C:\Users\M\AppData\Local\Temp\G.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 6184
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *DBPATH C:\Users\M\AppData\Local\Temp
    *WAIT 2
    <12/25/2017 1:25:14 AM>
    END VIDEO ENCODING OPERATIONS
    Video Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Users\M\Videos\G.m2v (4220.1 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 6185 kbps - 720x480 - DAR 16:9 - 29.97 fps - Progressive (TFF) - 1:35:23 hours - 171517 frames
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "C:\Users\M\AppData\Local\Temp\G_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\M\Videos\G_1.ac3"
    <12/25/2017 1:30:21 AM>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Audio Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Users\M\Videos\G_1.ac3 (131 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 1:35:23 hours (0 ms delay)
    DVD CHAPTERS CREATION OPERATIONS
    Title 1 Input Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829
    Title 1 Output Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829
    Created File: C:\Users\M\Videos\G_Chapters.txt (142 Byte)
    START DVD MENU BUILDING OPERATIONS
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Blue Rain
    Max Titles Page: 12
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    Thumb Image Source: 1
    Thumb Frame Position: 10%
    HL Frame Format: 0
    HL Selection Color: 5
    HL Play Color: 0
    Menu Video BitRate: 6000 kbps
    Motion Menu Duration: 15 seconds
    Thumb Drop Shadow: 2
    Play All Shadow: 2
    Arrows Shadow: 0
    <12/25/2017 1:30:22 AM>
    END DVD MENU BUILDING OPERATIONS
    Created File (Menu Page 1): C:\Users\M\Videos\G_MenuPage1.bmp (1 MB)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Users\M\AppData\Local\Temp\G_4_BatchMux.ini"
    BatchMux ini file:
    -bmlog "C:\Users\M\AppData\Local\Temp\G_4_BatchMux.log"
    -d "C:\Users\M\Desktop\G_4\VIDEO_TS"
    -mxp "C:\Users\M\AppData\Local\Temp\G4_MuxMan.mxp"
    -l "C:\Users\M\AppData\Local\Temp\G_4_MuxMan.log"
    -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
    -prio LOW
    -palette "C:\Users\M\AppData\Local\Temp\G_4_Palette.txt"
    -v "C:\Users\M\Videos\G.m2v"
    -vidmode LB
    -a1 "C:\Users\M\Videos\G_1.ac3"
    -a1lang en
    -cellfr "C:\Users\M\Videos\G_Chapters.txt"
    -progfr "C:\Users\M\Videos\G_Chapters.txt"
    -chapfr "C:\Users\M\Videos\G_Chapters.txt"
    -SEG2v "C:\Users\M\Videos\G4_MenuPage1.bmp"
    -SEG2vidmode LB
    -SEG2s1 "C:\Users\M\Videos\G_4_Menu.sst"
    -SEG2s1dmode WIDE_LB
    -SEG2hlmnu "C:\Users\M\AppData\Local\Temp\G_4_MenuPage1_Button s.mnu"
    -SEG2hlcsm "C:\Users\M\AppData\Local\Temp\G_4_HighlightScheme. csm
    -hcn "C:\Users\M\AppData\Local\Temp\G_4_BatchMux.hcn"
    <12/25/2017 1:31:31 AM>
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Users\M\Desktop\G_4 (4435.6 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4435.6 MB
    vs Assets Size: 4352.1 MB -> OK
    vs Estimated Size: 4449 MB -> 0.3% undersize
    <12/25/2017 1:31:32 AM>
    START ISO IMAGE BUILDING OPERATIONS
    ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\M\Desktop\G_4\VIDEO_TS" /dest "C:\Users\M\Desktop\G_4.iso" /volumelabel "G" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
    <12/25/2017 1:32:38 AM>
    END ISO IMAGE BUILDING OPERATIONS
    Created File: C:\Users\M\Desktop\G_4.iso (4.3 GB)
    AVStoDVD Project ended successfully.
    Log file created by AVStoDVD Release 2.8.6
  3. The audio and video preferred codecs are all default Microsoft. You should change the codecs merit to LAV Filters using the tool you find directly in AVStoDVD (Codecs > Preferred DirectShow Codecs Setup) or with Win7DSFilterTweaker.
    See AVStoDVD Help/FAQ/General/Q1.5 for more details.
    If you still have sync issue, come back with the new project log file.
    Bye
    MrC
    AVStoDVD Homepage
  4. "The audio and video preferred codecs are all default Microsoft. You should change the codecs merit to LAV Filters using the tool you find directly in AVStoDVD (Codecs > Preferred DirectShow Codecs Setup) or with Win7DSFilterTweaker."
    Do you have to do this whenever you update the LAV filters? I had the Tweaker already & know I had used it initially, so I'm curious why things might have reverted back to Microsoft?
    Now the audio looks in sync when I preview, but is roughly a second late now that I've created the actual .iso file.
    <12/28/2017 10:46:24 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: G
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    SYSTEM INFO
    Available Output Disc Space: 58 GB
    CODECS REPORT
    H.264/AVC: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    Xvid: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    DivX 4/5/6: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    Other MPG4: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    DV: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    MPEG1: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    MPEG2: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    MP2: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    MP3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    AAC: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\M\Music\Documents\Favorites\Downloads\G.m p4", CacheFolder="C:\Users\M~1\AppData\Local\Temp", VFR=false, FrameRateNum=2997, FrameRateDen=100, FrameRate=29.97)
    Audio = A2DAudioSource("C:\Users\M\Music\Documents\Favorites\Downloads\G.m p4", CacheFolder="C:\Users\M~1\AppData\Local\Temp")
    Encoding Parameters: -ini "C:\Users\M~1\AppData\Local\Temp\G_G.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\M~1\AppData\Local\Temp\G_G_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\M\Videos\G_G.m2v
    *LOGFILE C:\Users\M~1\AppData\Local\Temp\G_G.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 6184
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 60
    *DC_PREC 10
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *DBPATH C:\Users\M~1\AppData\Local\Temp
    *WAIT 2
    <12/28/2017 11:18:44 AM>
    Created File: C:\Users\M\Videos\G_G.m2v (4220.1 MB)
    Wavi+Aften Parameters: "C:\Users\M~1\AppData\Local\Temp\G_G_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\M\Videos\G_G_1.ac3"
    <12/28/2017 11:23:23 AM>
    Created File: C:\Users\M\Videos\G_G_1.ac3 (131 MB)
    Created File: C:\Users\M\Videos\G_G_Chapters.txt (142 Byte)
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Blue Rain
    Max Titles Page: 12
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Play Color: 0
    Play All Shadow: 2
    Arrows Shadow: 0
    <12/28/2017 11:23:24 AM>
    BatchMux Parameters: -arglist "C:\Users\M~1\AppData\Local\Temp\G_BatchMux.ini"
    BatchMux ini file:
    -bmlog "C:\Users\M~1\AppData\Local\Temp\G_BatchMux.log"
    -d "C:\Users\M\Desktop\G\VIDEO_TS"
    -mxp "C:\Users\M~1\AppData\Local\Temp\G_MuxMan.mxp"
    -l "C:\Users\M~1\AppData\Local\Temp\G_MuxMan.log"
    -prio LOW
    -palette "C:\Users\M~1\AppData\Local\Temp\G_Palette.txt"
    -v "C:\Users\M\Videos\G_G.m2v"
    -vidmode LB
    -a1 "C:\Users\M\Videos\G_G_1.ac3"
    -a1lang en
    -cellfr "C:\Users\M\Videos\G_G_Chapters.txt"
    -progfr "C:\Users\M\Videos\G_G_Chapters.txt"
    -chapfr "C:\Users\M\Videos\G_G_Chapters.txt"
    -SEG2v "C:\Users\M\Videos\G_MenuPage1.bmp"
    -SEG2vidmode LB
    -SEG2s1 "C:\Users\M\Videos\G_Menu.sst"
    -SEG2hlmnu "C:\Users\M~1\AppData\Local\Temp\G_MenuPage1_Button s.mnu"
    -SEG2hlcsm "C:\Users\M~1\AppData\Local\Temp\G_HighlightScheme. csm
    -hcn "C:\Users\M~1\AppData\Local\Temp\G_BatchMux.hcn"
    <12/28/2017 11:24:48 AM>
    Created Folder: C:\Users\M\Desktop\G (4435.8 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4435.8 MB
    vs Assets Size: 4352 MB -> OK
    <12/28/2017 11:24:49 AM>
    ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\M\Desktop\G\VIDEO_TS" /dest "C:\Users\M\Desktop\G.iso" /volumelabel "G" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
    <12/28/2017 11:25:49 AM>
    Created File: C:\Users\M\Desktop\G.iso (4.3 GB)
    <12/28/2017 11:25:52 AM>
    Mar 2008
    Sometimes Windows updates can cause the filter merit to be reset, so if you're going to use directshow, i'd check it often.
    Give FFmpegsource a try for the video and audio source filters. Set it in the preferences, Avisynth tab. Save, and then re-add your source file.
  6. That seems to have finally fixed it!!! Thanks!!! I leaving my source filters at FFmpegsource likely my best bet since I've had problems with a number of other files?
    Mar 2008
    I would first try the latest alpha release some changes were made in the source filter smart selection logic.
    But on the otherhand, leaving it as you set it is fine also, it works great for most file types
    Apr 2012
    Hungary
    Guys!
    How can I add extra text to the menu page in the DVD menu Editor? I see there are segments like: Title, Thumbnails and Buttons listed, but I cannot find an option to add an extra text to the element list. I want a custom text under the title in the menu.
  9. Hi Bencuri,
    currently it is not possible to add an extra text as new element to the DVD Menu section. As workaround you can use the existing text elements and press some "enter" to write your custom text below.
    Bye
    MrC
    AVStoDVD Homepage
  10. Since I upgraded to 2.8.7 I'm suddenly getting this "Warning! Title 1 output Video duration (00:00:00) is shorter than expected duration" error a lot. What setting(s) do I need to change? Here's a log. Thanks for your time.
    <12/7/2018 6:45:36 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Size: 4450/4450 MB (100%)
    DVD Label: DVD
    Output Folder: C:\Users\Me\Desktop
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: FFMpegSource
    AVS Audio Source Filter: FFMpegSource
    FPS Hard Conversion: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Subs Font: Tahoma 16pt (240,240,240)
    DVD Burning Speed: 4x
    SYSTEM INFO
    Operating System: Windows 10 (10.0.17134) 64 bit
    Available Output Disc Space: 83 GB
    LAV Filters is installed: YES (release 0.73.1)
    CODECS REPORT
    Video: C:\Users\Me\Music\Documents\Favorites\Downloads\fi le.mp4
    Info: AVC - 4987 kbps - 1920x1080 - DAR 16:9 - 25 fps - Progressive - 1:50:04 hours - 165030 frames
    Audio 1: C:\Users\Me\Music\Documents\Favorites\Downloads\fi le.mp4
    Info: AAC LC - 256 kbps - CBR - 2 ch - 48000 Hz - 1:50:04 hours (0 ms delay)
    AVISYNTH SCRIPT
    LoadCPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ffms2.dll")
    LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ColorMatrix.dll")
    Audio = FFAudioSource("C:\Users\Me\Music\Documents\Favorites\Downloads\fi le.mp4", track=-1)
    Video = FFVideoSource("C:\Users\Me\Music\Documents\Favorites\Downloads\fi le.mp4", track=-1, fpsnum=25, fpsden=1, seekmode=0)
    Video = Video.ColorMatrix(source=0,dest=2)
    #PullDown: using DGPulldown/HCenc to upsize FPS
    Target Video FileSize: 4193.7 MB
    Encoding Parameters: -ini "C:\Users\me\AppData\Local\Temp\DVD_file.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\me\AppData\Local\Temp\DVD_file_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Me\Desktop\DVD_file.m2v
    *LOGFILE C:\Users\me\AppData\Local\Temp\DVD_file.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 5327
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY NORMAL
    *DBPATH C:\Users\me\AppData\Local\Temp
    *WAIT 2
    <12/7/2018 7:14:39 AM>
    Process halted during Title 1 VIDEO encoding operations.
    Error Message: 'Warning! Title 1 output Video duration (00:00:00) is shorter than expected duration (01:50:04).'
    Video errors warning message skipped.
    Wavi+Aften Parameters: "C:\Users\me\AppData\Local\Temp\DVD_file_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Me\Desktop\DVD_file_1.ac3"
    <12/7/2018 7:16:00 AM>
    Created File: C:\Users\Me\Desktop\DVD_file_1.ac3 (151.1 MB)
    Output Audio Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 1:50:01 hours (0 ms delay)
    Title 1 Input Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500 90000 97500 105000 112500 120000 127500 135000 142500 150000 157500 165000
    No Chapters List created for Title 1
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Blue Rain
    Max Titles Page: 16
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Selection Color: 11
    HL Play Color: 7
    Play All Shadow: 2
    Arrows Shadow: 0
    <12/7/2018 7:16:01 AM>
    Created File (Menu Page 1): C:\Users\Me\Desktop\DVD_MenuPage1.bmp (1 MB)
    BatchMux Parameters: -arglist "C:\Users\me\AppData\Local\Temp\DVD_BatchMux.ini"
    BatchMux ini file:
    -bmlog "C:\Users\me\AppData\Local\Temp\DVD_BatchMux.log"
    -d "C:\Users\Me\Desktop\DVD\VIDEO_TS"
    -mxp "C:\Users\me\AppData\Local\Temp\DVD_MuxMan.mxp"
    -l "C:\Users\me\AppData\Local\Temp\DVD_MuxMan.log"
    -prio ABOVENORMAL
    -palette "C:\Users\me\AppData\Local\Temp\DVD_Palette.txt"
    -v "C:\Users\Me\Desktop\DVD_file.m2v"
    -vidmode LB
    -a1 "C:\Users\Me\Desktop\DVD_file_1.ac3"
    -a1lang en
    -SEG2v "C:\Users\Me\Desktop\DVD_MenuPage1.bmp"
    -SEG2vidmode LB
    -SEG2s1 "C:\Users\Me\Desktop\DVD_Menu.sst"
    -SEG2hlmnu "C:\Users\me\AppData\Local\Temp\DVD_MenuPage1_Butto ns.mnu"
    -SEG2hlcsm "C:\Users\me\AppData\Local\Temp\DVD_HighlightScheme .csm
    -hcn "C:\Users\me\AppData\Local\Temp\DVD_BatchMux.hcn"
    <12/7/2018 7:16:19 AM>
    Process aborted during DVD AUTHORING operations!
    Check following files for more details:
    AVStoDVD log file
    BatchMux log file
    For more troubleshooting on Authoring issues, see Help/FAQ/Authoring.
    <12/7/2018 7:16:38 AM>
    Warning! AVStoDVD Project ended with errors.
    Log file created by AVStoDVD Release 2.8.7
    Mar 2008
    From the AVStoDVD log you can see
    What happened during this 30 minutes? Did you see the HCenc window open encoding the video?
    Does the HCenc log file mentioned above still exist, you may want to look in there
  12. I posted the entire log. It always seems to be working properly. The HCenc window is open charting the frame progress from 0% to 100% for 30 minutes or however long it takes to make it's 2 passes encoding the video, then it tells me the duration is shorter than expected when it gets to the audio.
  13. Hi JLG/JLG,
    do you get that error with all input files or only with some of them? Can you find any commonalities?
    As general troubleshooting, have you tried to use default preferences (e.g. you have selected FFMpegSource instead of A2DSource)?
    Bye
    MrC
    AVStoDVD Homepage
  14. I get it with only some of them. It seems like it sometimes doesn't like when I use MP4Splitter now, though it's the same program (albeit there's probably a better option somewhere for a free lossless program) I used a couple hundred times with version 2.8.6 & never had a problem. When I'm using it now with say a 20 minute file to just cut 15 seconds off the beginning & end, that still seems to work fine, but when I'm using it with a 4hr file to split it so I can make two separate DVD-5s instead of killing the quality by having the whole event one DVD-5 that's when it's now hit & miss.
    When I started using 2.8.6 I had trouble with the sound being out of sync, and ffmpegsource was recommended, so I stuck w/ that & had much better success. Sometimes when I use ffmpeg safe mode on 2.8.7 it's out of sync again, so I tried going back to the default wavi+aften for audio. I will try redoing it with A2DSource & let you know if that helps.
  15. Hi JLG/JLG,
    give a try also to latest 2.8.8 Alpha release.
    Bye
    MrC
    AVStoDVD Homepage
  16. Hi MrC,
    I've been having good luck with the disks since I updated to 2.8.8 Alpha & switched back to A2DSource. The only issue now is the disks are generally taking 9 times as long. With versions 2.6 & 2.7, a disk with roughly one 2hr video file would take 15 minutes for each pass of HCenc & then another 15 minutes for the rest. Now each pass is often taking 3-4 hours. It just chugs away at roughly 15 frames a second instead of 120+. Here's the log file for the last one I made. HCenc ju
    <1/10/2019 2:03:28 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: DVD
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    SYSTEM INFO
    Available Output Disc Space: 70 GB
    CODECS REPORT
    Video: C:\Users\Me\Music\Documents\Favorites\Downloads\vi deo.mp4
    Info: AVC - 1426 kbps - 1280x720 - DAR 16:9 - 30 fps - Progressive - 1:54:13 hours - 205581 frames
    Audio 1: C:\Users\Me\Music\Documents\Favorites\Downloads\vi deo.mp4
    Info: AAC LC - 128 kbps - CBR - 2 ch - 44100 Hz - 1:54:18 hours (0 ms delay)
    [MediaInfoLib - v18.03.1]
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\MCJMFPS.avsi")
    Video = A2DVideoSource("C:\Users\Me\Music\Documents\Favorites\Downloads\vi deo.mp4", CacheFolder="C:\Users\Me\AppData\Local\Temp", FrameRate=30)
    Audio = A2DAudioSource("C:\Users\Me\Music\Documents\Favorites\Downloads\vi deo.mp4", CacheFolder="C:\Users\Me\AppData\Local\Temp")
    Video = Video.MCJMFPS(29.97)
    Target Video FileSize: 4187.4 MB
    Encoding Parameters: -ini "C:\Users\Me\AppData\Local\Temp\DVD_video.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Me\AppData\Local\Temp\DVD_video_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Me\Desktop\DVD_video.m2v
    *LOGFILE C:\Users\Me\AppData\Local\Temp\DVD_video.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 5122
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY NORMAL
    *DBPATH C:\Users\Me\AppData\Local\Temp
    *WAIT 2
    <1/10/2019 8:34:13 PM>
    Video Source Filter: A2DSource - DSS2 mod (LAV Filters on)
    Created File: C:\Users\Me\Desktop\DVD_video.m2v (4188.9 MB)
    Ouput Video Info: MPEG-2 Video - 5123 kbps - 720x480 - DAR 16:9 - 29.97 fps - Progressive (TFF) - 1:54:18 hours - 205533 frames
    Avg Video Encoding Speed: 8.8 fps
    Wavi+Aften Parameters: "C:\Users\Me\AppData\Local\Temp\DVD_video_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Me\Desktop\DVD_video_1.ac3"
    <1/10/2019 8:39:56 PM>
    Audio Source Filter: A2DSource - DirectShowSource
    Created File: C:\Users\Me\Desktop\DVD_video_1.ac3 (157 MB)
    Output Audio Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:54:18 hours (0 ms delay)
    Title 1 Input Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829 179820 188811 197802
    Title 1 Output Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829 179820 188811 197802
    Created File: C:\Users\Me\Desktop\DVD_video_Chapters.txt (166 Byte)
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Blue Rain
    Max Titles Page: 16
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Play Color: 7
    Play All Shadow: 2
    Arrows Shadow: 0
    <1/10/2019 8:39:57 PM>
    BatchMux Parameters: -arglist "C:\Users\Me\AppData\Local\Temp\DVD_BatchMux.ini"
    BatchMux ini file:
    -bmlog "C:\Users\Me\AppData\Local\Temp\DVD_BatchMux.log"
    -mxp "C:\Users\Me\AppData\Local\Temp\DVD_MuxMan.mxp"
    -l "C:\Users\Me\AppData\Local\Temp\DVD_MuxMan.log"
    -prio ABOVENORMAL
    -palette "C:\Users\Me\AppData\Local\Temp\DVD_Palette.txt"
    -v "C:\Users\Me\Desktop\DVD_video.m2v"
    -vidmode LB
    -a1 "C:\Users\Me\Desktop\DVD_video_1.ac3"
    -a1lang en
    -cellfr "C:\Users\Me\Desktop\DVD_video_Chapters.txt"
    -progfr "C:\Users\Me\Desktop\DVD_video_Chapters.txt"
    -chapfr "C:\Users\Me\Desktop\DVD_video_Chapters.txt"
    -SEG2vidmode LB
    -SEG2hlmnu "C:\Users\Me\AppData\Local\Temp\DVD_MenuPage1_Butto ns.mnu"
    -SEG2hlcsm "C:\Users\Me\AppData\Local\Temp\DVD_HighlightScheme .csm
    -hcn "C:\Users\Me\AppData\Local\Temp\DVD_BatchMux.hcn"
    <1/10/2019 8:41:50 PM>
    Created Folder: C:\Users\Me\Desktop\DVD (4438.8 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4438.8 MB
    vs Assets Size: 4346.8 MB -> OK
    vs Estimated Size: 4450 MB -> 0.3% undersize
    ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\Me\Desktop\DVD\VIDEO_TS" /dest "C:\Users\Me\Desktop\DVD.iso" /volumelabel "DVD" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
    <1/10/2019 8:42:46 PM>
    Created File: C:\Users\Me\Desktop\DVD.iso (4.3 GB)
    <1/10/2019 8:42:47 PM>
    Log file created by AVStoDVD Release 2.8.8 Alpha build 180706
    Mar 2008
    This is because the program is doing a CPU-intensive frame rate conversion
    from 30 FPS to 29.97 (DVD standard). It's using motion compensation
    From the log - Video = Video.MCJMFPS(29.97)
    If you want to speed it up you can try Preferences/Avisynth Tab/Hard framerate conversion - set it to insert/drop frames.
    You may notice an occasional small stutter in the output, up to you if it's acceptable or not.
    Sometimes the motion compensation does some strange things and it's worse
  18. The jump frames was one of the big issues I had when I first started with 2.6, so I switched to whatever the comparable setting in the previous versions was called. Even doing 25 fps stuff my overseas relatives sent it never took even close to this amount of time. If stutter is the alternative, I guess I'm stuck w/ it taking 6-8hr to make a disk.
    Mar 2008
    Not necessarily there is another setting at the preference I mentioned "blend frames", sort of in between the other two.
    Uses Avisynth convertfps if you want to look it up. Perhaps you should do some test encodes of five minutes each and view them with a critical eye.
    What is your 30 fps source? From a camera?
    For 25 fps the program uses pulldown which does not add any appreciable time to the job
  20. Thanks for your help. Is blend frames the option the previous versions were using? Is there an easier way of doing a test encode than clipping 5 min of video & making this as a short disk?
    Mar 2008
    Start with an empty project.
    Set the preference you want to test. OK out. Add your source.
    Edit title settings/video tab - deselect "auto video setup" and "auto bitrate"
    Avisynth tab - deselect "auto Avisynth script". Select "trim" give it a range of about 10,000 frames.
    Encode and repeat for each setting you want to check
    For this test it may be better to choose output/muxed mpeg2 file, then you
    can look at the frames one by one in Virtualdub 2 - any stuttering, blends or other issues
    will be obvious
  22. I upgraded to the regular version of 2.8.8 & tried keeping the default preferences since I don't really understand which modes to use when anyway, but the audio on this is a couple seconds early.
    <2/4/2019 12:24:12 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: DVD
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 0
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    SYSTEM INFO
    Operating System: Windows 10 (10.0.17763) 64 bit
    Running with Elevated Privileges: YES
    CODECS REPORT
    Video: G:\My Videos\In Progress\file.mp4
    Info: AVC - 4285 kbps - 1280x720 - DAR 16:9 - 29.97 fps (VFR) - Progressive - 1:58:37 hours - 213126 frames
    Audio 1: G:\My Videos\In Progress\file.mp4
    Info: AAC LC - 132 kbps - CBR - 2 ch - 44100 Hz - 1:58:37 hours (0 ms delay) - Default
    AVISYNTH SCRIPT
    Video = A2DVideoSource("G:\My Videos\In Progress\file.mp4", CacheFolder="C:\Users\Me\AppData\Local\Temp", VFR=true, FrameRate=29.97)
    Audio = A2DAudioSource("G:\My Videos\In Progress\file.mp4", CacheFolder="C:\Users\Me\AppData\Local\Temp")
    Target Video FileSize: 4179.3 MB
    Encoding Parameters: -ini "C:\Users\Me\AppData\Local\Temp\DVD_1_file.HCenc.in i"
    HCenc ini file:
    *INFILE C:\Users\Me\AppData\Local\Temp\DVD_1_file_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Me\Desktop\DVD_1_file.m2v
    *LOGFILE C:\Users\Me\AppData\Local\Temp\DVD_1_file.HCenc.lo g
    *MAXBITRATE 9000
    *BITRATE 4926
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY NORMAL
    *WAIT 2
    <2/4/2019 1:04:54 AM>
    Created File: C:\Users\Me\Desktop\DVD_1_file.m2v (4180.9 MB)
    Ouput Video Info: MPEG-2 Video - 4927 kbps - 720x480 - DAR 16:9 - 29.97 fps - Progressive (TFF) - 1:58:37 hours - 213304 frames
    Avg Video Encoding Speed: 88.1 fps
    Wavi+Aften Parameters: "C:\Users\Me\AppData\Local\Temp\DVD_1_file_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Me\Desktop\DVD_1_file_1.ac3"
    <2/4/2019 1:09:02 AM>
    Created File: C:\Users\Me\Desktop\DVD_1_file_1.ac3 (162.9 MB)
    Output Audio Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:58:37 hours (0 ms delay)
    Title 1 Input Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829 179820 188811 197802 206793
    Title 1 Output Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829 179820 188811 197802 206793
    Created File: C:\Users\Me\Desktop\DVD_1_file_Chapters.txt (174 Byte)
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Blue Rain
    Max Titles Page: 12
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Play Color: 7
    Play All Shadow: 2
    Arrows Shadow: 0
    <2/4/2019 1:09:03 AM>
    Created File (Menu Page 1): C:\Users\Me\Desktop\DVD_1_MenuPage1.bmp (1 MB)
    BatchMux Parameters: -arglist "C:\Users\Me\AppData\Local\Temp\DVD_1_BatchMux.ini"
    BatchMux ini file:
    -bmlog "C:\Users\Me\AppData\Local\Temp\DVD_1_BatchMux.log"
    -d "C:\Users\Me\Desktop\DVD_1\VIDEO_TS"
    -mxp "C:\Users\Me\AppData\Local\Temp\DVD_1_MuxMan.mxp"
    -l "C:\Users\Me\AppData\Local\Temp\DVD_1_MuxMan.log"
    -prio ABOVENORMAL
    -palette "C:\Users\Me\AppData\Local\Temp\DVD_1_Palette.txt"
    -v "C:\Users\Me\Desktop\DVD_1_file.m2v"
    -vidmode LB
    -a1 "C:\Users\Me\Desktop\DVD_1_file_1.ac3"
    -a1lang en
    -cellfr "C:\Users\Me\Desktop\DVD_1_file_Chapters.txt"
    -progfr "C:\Users\Me\Desktop\DVD_1_file_Chapters.txt"
    -chapfr "C:\Users\Me\Desktop\DVD_1_file_Chapters.txt"
    -SEG2v "C:\Users\Me\Desktop\DVD_1_MenuPage1.bmp"
    -SEG2vidmode LB
    -SEG2s1 "C:\Users\Me\Desktop\DVD_1_Menu.sst"
    -SEG2hlmnu "C:\Users\Me\AppData\Local\Temp\DVD_1_MenuPage1_But tons.mnu"
    -SEG2hlcsm "C:\Users\Me\AppData\Local\Temp\DVD_1_HighlightSche me.csm
    -hcn "C:\Users\Me\AppData\Local\Temp\DVD_1_BatchMux.hcn"
    <2/4/2019 1:10:02 AM>
    Created Folder: C:\Users\Me\Desktop\DVD_1 (4437.3 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 4437.3 MB
    vs Assets Size: 4344.8 MB -> OK
    ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\Me\Desktop\DVD_1\VIDEO_TS" /dest "C:\Users\Me\Desktop\DVD_1.iso" /volumelabel "DVD" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
    <2/4/2019 1:11:00 AM>
    Created File: C:\Users\Me\Desktop\DVD_1.iso (4.3 GB)
  23. The audio seems ok at the beginning of the show, but grows progressively off the deeper into it I get no matter what settings I've used. I cut a clip from toward the end & tried making a little test disk of that, and the audio seemed in sync. The problem may be related to the frame rate. AVS claims the video is 29.97, but windows explorer claims it's 29.94, so I guess those fractions are adding up over time? I tried using the suggestions in FAQ audio encoding, neither FFMpegSource nor Toggle off 'Auto Delay Audio' fixed the problem, but I must be missing something somewhere because I couldn't get force audio re-encoding ('Edit Title'/'Audio'/'Audio Direct Stream Copy) to work at all. I can toggle off Auto Audio Setup, but Audio Direct Stream Copy is still grey & can't be toggled on.
  24. Member
    Mar 2008
    I think you're on the right track, variable frame rate video.
    In the preferences, Avisynth tab, set FFmpeg as the video source filter. OK out.
    Add your movie and try it again
  25. The 1st one I tried w/ FFmpeg audio & video & it gave me that error I was having problems with in the previous version Error Message: Warning! Title 1 output Video duration (00:00:00) is shorter than expected duration (01:58:37). The second one I just used FFmpeg video & it made the disk, but the audio is still way off by the end.
    <2/11/2019 9:26:03 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: Disk
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    SYSTEM INFO
    Available Output Disc Space: 93 GB
    CODECS REPORT
    Video: G:\My Videos\Unfinished downloads\file.mp4
    Audio 1: G:\My Videos\Unfinished downloads\file.mp4
    AVISYNTH SCRIPT
    Audio = FFAudioSource("G:\My Videos\Unfinished downloads\file.mp4", track=-1)
    Video = FFVideoSource("G:\My Videos\Unfinished downloads\file.mp4", track=-1, fpsnum=2997, fpsden=100, seekmode=0)
    Encoding Parameters: -ini "C:\Users\me\AppData\Local\Temp\file_file.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\me\AppData\Local\Temp\file_file_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Me\Desktop\file_file.m2v
    *LOGFILE C:\Users\me\AppData\Local\Temp\file_file.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 4926
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY NORMAL
    *WAIT 2
    <2/11/2019 9:27:21 PM>
    Process aborted during Title 1 VIDEO encoding operations.
    For Video issues troubleshooting see Help/FAQ/Video section.
    <2/11/2019 9:28:56 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: Disk
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    SYSTEM INFO
    CODECS REPORT
    AVISYNTH SCRIPT
    Audio = A2DAudioSource("G:\My Videos\Unfinished downloads\file.mp4", CacheFolder="C:\Users\me\AppData\Local\Temp")
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 4926
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY NORMAL
    *WAIT 2
    <2/11/2019 10:02:55 PM>
    Created File: C:\Users\Me\Desktop\file_file.m2v (4180.9 MB)
    Ouput Video Info: MPEG-2 Video - 4927 kbps - 720x480 - DAR 16:9 - 29.97 fps - Progressive (TFF) - 1:58:37 hours - 213305 frames
    Avg Video Encoding Speed: 105 fps
    Wavi+Aften Parameters: "C:\Users\me\AppData\Local\Temp\file_file_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Me\Desktop\file_file_1.ac3"
    <2/11/2019 10:08:55 PM>
    Created File: C:\Users\Me\Desktop\file_file_1.ac3 (162.9 MB)
    Created File: C:\Users\Me\Desktop\file_file_Chapters.txt (174 Byte)
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Blue Rain
    Max Titles Page: 16
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Play Color: 7
    Play All Shadow: 2
    Arrows Shadow: 0
    <2/11/2019 10:08:56 PM>
    Created File (Menu Page 1): C:\Users\Me\Desktop\file_MenuPage1.bmp (1 MB)
    BatchMux Parameters: -arglist "C:\Users\me\AppData\Local\Temp\file_BatchMux.ini"
    BatchMux ini file:
    -bmlog "C:\Users\me\AppData\Local\Temp\file_BatchMux.log"
    -d "C:\Users\Me\Desktop\file\VIDEO_TS"
    -mxp "C:\Users\me\AppData\Local\Temp\file_MuxMan.mxp"
    -l "C:\Users\me\AppData\Local\Temp\file_MuxMan.log"
    -prio ABOVENORMAL
    -palette "C:\Users\me\AppData\Local\Temp\file_Palette.txt"
    -v "C:\Users\Me\Desktop\file_file.m2v"
    -vidmode LB
    -a1 "C:\Users\Me\Desktop\file_file_1.ac3"
    -a1lang en
    -cellfr "C:\Users\Me\Desktop\file_file_Chapters.txt"
    -progfr "C:\Users\Me\Desktop\file_file_Chapters.txt"
    -chapfr "C:\Users\Me\Desktop\file_file_Chapters.txt"
    -SEG2v "C:\Users\Me\Desktop\file_MenuPage1.bmp"
    -SEG2vidmode LB
    -SEG2s1 "C:\Users\Me\Desktop\file_Menu.sst"
    -SEG2hlmnu "C:\Users\me\AppData\Local\Temp\file_MenuPage1_Butt ons.mnu"
    -SEG2hlcsm "C:\Users\me\AppData\Local\Temp\file_HighlightSchem e.csm
    -hcn "C:\Users\me\AppData\Local\Temp\file_BatchMux.hcn"
    <2/11/2019 10:10:39 PM>
    Created Folder: C:\Users\Me\Desktop\file (4437.3 MB)
    CHECK DVD SIZE
    <2/11/2019 10:10:40 PM>
    ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\Me\Desktop\file\VIDEO_TS" /dest "C:\Users\Me\Desktop\file.iso" /volumelabel "DVD" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
    <2/11/2019 10:11:38 PM>
    Created File: C:\Users\Me\Desktop\file.iso (4.3 GB)
  26. Member
    Mar 2008
    I would think there is something wrong with the source file.
    Can you share it, or some of it ?
  27. Demux and remux to mkv container with MKVToolNix could help to understand if the source file is broken.
    Bye
    MrC
    AVStoDVD Homepage
  28. AVStoDVD-I want to add a subtitle file, its in sub/idx format, do I have to convert it to srt format?? how?
    I added the subtitle file(sub/idx) but it didnt add the subtitles
  29. Originally Posted by muddy7 View Post
    That's strange, AVStoDVD supports idx/sub format. Could you upload here the idx/sub subtitle files?
    Bye
    MrC
    AVStoDVD Homepage
  30. Please help me,i whant to make a dvd for nrs 510 (wv passat navi ) i tried with :i download from yt with 4k videodownloader in mp4 exemple 120 mb video , ashampoo burning studio 20 - dvd video ,but mp4 file it is 350 mb wow ! why ?
    for dvd 4,7 only 10 mp4 files ?
    i tried with dvd flick but video it is 350 mb ... please help me how i make a dvd with many mp4 files ,thank you
