Page 6 of 12
FirstFirst ... 4 5 6 7 8 ... LastLast
Results 151 to 180 of 359
    Apr 2011
    bristol
    hi dave, already reinstalled avstodvd last night from fresh, that is version I was using, avstodvd is working fine with other files, just three files I have which all play fine etc ,but getting the shorter msg when try to convert to dvd, i also don't know any other free software that does as good a job as avstodvd to do those 3 files, i thing vso is nowhere near as good a quality outcome and takes a lot longer to give a poorer result,just tried it again with how you said and same error
    <8/30/2016 7:19:47 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: ISO UDF Image
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\blood\Videos
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: FFMpegSource
    AVS Audio Source Filter: FFMpegSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 0
    FPS Hard Conversion: 0
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 3
    Video BitRate Min: 3300
    Video BitRate Max: 5400
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 448
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 0
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): EN - English
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: E: HL-DT-ST DVDRAM GH24NSD0 LH00
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Execute with Elevated Privileges: 0
    Unload ActiveMovie Library: 1
    Adjust DirectShow Filters at runtime: 1
    Save General Settings: 1
    SYSTEM INFO
    Processor Name: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz
    Operating System: Windows 10 (10.0.10586) 64 bit
    User has Admin Rights: YES
    Running with Elevated Privileges: NO (3)
    Available Output Disc Space: 137 GB
    AviSynth is installed: YES (release 2.6.0)
    LAV Filters is installed: YES (release 0.68.0)
    ffdshow is installed: NO
    CODECS REPORT
    H.264/AVC: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    Xvid: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    DivX 4/5/6: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    Other MPG4: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    DV: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    MPEG1: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    MPEG2: LAV Video Decoder {EE30215D-164F-4A92-A4EB-9D4C13390F9F}
    MP2: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    MP3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    AAC: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    AC3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
    TITLE 1 SOURCE FILES
    Video: C:\Users\blood\Desktop\movie.mkv.mkv
    Info: AVC - 4840 kbps - 1280x536 - DAR 2.388 - 23.976 fps (CFR) - Progressive - 2:27:42 hours - 212474 frames
    Audio 1: C:\Users\blood\Desktop\movie.mkv.mkv
    Info: DTS - 1509 kbps - CBR - 6 ch - 48000 Hz - 24 bit - 2:27:42 hours (0 ms delay) - EN
    Subs 1: C:\Users\blood\Desktop\movie.mkv.mkv
    Info: SubRip (SRT) - Forced - EN
    Subs 2: C:\Users\blood\Desktop\movie.mkv.mkv
    Info: SubRip (SRT) - EN
    Subs 3: C:\Users\blood\Desktop\movie.mkv.mkv
    Info: SubRip (SRT) - SDH - EN
    [MediaInfoLib - v0.7.77]
    AVISYNTH SCRIPT
    LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ffms2.dll")
    Audio = FFAudioSource("C:\Users\blood\Desktop\movie.mkv.mkv", track=-1)
    Video = FFVideoSource("C:\Users\blood\Desktop\movie.mkv.mkv", track=-1, seekmode=0)
    Video = Video.ConvertToYV12()
    Video = Video.AddBorders(0,92,0,92)
    Video = Video.Spline16Resize(720,480)
    #PullDown: using DGPulldown/HCenc to upsize FPS
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Video Encoding Profile: HCenc VBR 2-pass
    Target Video FileSize: 3812.7 MB
    Encoding Parameters: -ini "C:\Users\blood\AppData\Local\Temp\DVD_3_movie.mkv. HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\blood\AppData\Local\Temp\DVD_3_movie.mkv_ 1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\blood\Videos\DVD_3_movie.mkv.m2v
    *LOGFILE C:\Users\blood\AppData\Local\Temp\DVD_3_movie.mkv. HCenc.log
    *MAXBITRATE 9000
    *BITRATE 3609
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *PULLDOWN
    *BIAS 40
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY NORMAL
    *DBPATH C:\Users\blood\AppData\Local\Temp
    *WAIT 2
    <8/30/2016 7:21:32 PM>
    Process aborted during Title 1 VIDEO encoding operations.
    Error Message: Warning! Title 1 output Video duration (00:00:00) is shorter than expected duration (02:27:42).
    For Video issues troubleshooting see Help/FAQ/Video section.
    Warning! AVStoDVD Project ended with errors.
    Log file created by AVStoDVD Release 2.8.4
    Mar 2008
    Could be the file itself. I'd like to take a look at it. Here's a way to get a small clip.
    (if you have a preferred method of cutting off a clip, use that instead)
    Open the file in Mkvmerge (mmg.exe). This can be found in the avstodvd folders here:
    \AVStopDVD_284_alpha1\MKVtoolNix
    Open your video mkv file. Make sure the output file name location is pointed to your Desktop
    On the global tab
    select enable splitting
    after this size 75M
    max number of file = 2
    Hit "start muxing" and when it's done send me the small clip. Upload it it to a file hosting site and send me the link in a PM
  3. Hi all,
    I've demuxed several ts files using tsmuxergui into separate mpeg2 and ac3 streams.
    Will AVStoDVD allow me to combine these streams so I can create a compliant dvd structure to burn onto a disk with imgburn ?
    Cheers
    Apr 2011
    bristol
    back again, everytime i convert a pal file with pal settings i get a slightly choppy conversion ,can anyone tell me why this is, when I convert ntsc stuff in ntsc it is fine it is all pal files
  5. Hi tyson,
    can you post the project log file?
    Bye
    MrC
    AVStoDVD Homepage
    Apr 2011
    bristol
    @_MrC_ it is not just one project it is every single pal file I try and convert it does it on,
  7. Well, then post one of those PAL project log files.
    Bye
    MrC
    AVStoDVD Homepage
    Apr 2011
    bristol
    @_MrC_ here you go pal source
    Mar 2008
    The most obvious thing is that the source is not PAL it is 24 fps (PAL is 25) - typical Blu ray .
    A quick glance at the script shows AVStoDVD is using DGPulldown to do the 24 > 25 conversion, it may be this that
    is causing a perceivable choppiness . I wouldn't do this, I'd be tempted to do 24 > 25 fps speed up.
    Perhaps MrC has a suggestion
  10. Yes, I agree with Dave to try the PAL SpeedUp option to convert that NTSC-film based mkv (24 fps) to PAL DVD (25 fps).
    See Preferences > AviSynth > Use PAL SpeedUp ...
    Then add the source mkv and start the project.
    Bye
    MrC
    AVStoDVD Homepage
  11. Just started using the program, & am super impressed by what a great job it does! I haven't figured out what the procedure is for longer events. I want to maintain the best quality, so I would prefer to turn the events over 2hr 10 minutes into multiple DVD-5 sets. Is there a way to do this with AVStoDVD (DVD-9 doesn't really help me, & I have plenty of stuff that's a 5-6hr .mp4s)? If not, what program should I use first to give me the best results when finishing the DVD with AVStoDVD? Thanks for your help!
    Mar 2008
    There is nothing in A2D (at the moment) to automatically do what you're asking.
    Best bet is to split the source manually and process them separately in A2D
    Jan 2007
    you need an editor that does smart rendering, recodes only the frames where you split it
    then you manually split and save sections at the time point, you pick
    its a frame for frame copy/split, with only a few frames on each side of the break recoded
    use your new split files to create your DVDs
    something like VideoRedo will do this
    but if you want to mark it and do an auto save of each split section, you will need some other similar software with that extra function
  14. I'm not worried about auto saving the split decisions. If there's a good open source program that will recode only the frames I split so I can save a 4hr mp4 as 2 files to make the 2 DVD-5's out of that would be wonderful. VideoRedo looks great, but to just use it to make the split, it seems like I would just buy something like TMPGEnc Authoring Works that can automatically split, but I like the quality of my DVDs that I made on AVStoDVD better than the ones my friend made on TMPGEnc.
  15. Hello, I am trying to create a dvd starting from a dozen or so .mp4 files from my video camera but I can't make it.
    I used avidemux to adjust light and cut away blurred parts etc, then I joined them together in 4 different .AVI files, that should become the 4 chapters of the dvd. On VLC they play fine and display the right duration, and all together they weigh little more than 1 GB.
    I must add that they're of the 5:4 type, but AVStoDVD recognizes that and prompts me to choose between 4:3 or 16:9.
    As soon as I add the first title (300 mb) to AVStoDVD, though, I see that it exceeds the maximum space (I tried with many other softwares and they all say that, from DeVeDe to DVD styler) for a dvd. And the duration of the videos is completely messed up, since it pretends to be over 22 hours, while it is way under 30 minutes!! Only one is displayd as less than an hour after I added it with the "+" icon.
    Still when I say "start" it seems to work, until it stops at the third title with a buffer error. It happened in the night, since it was way over 4 hours of processing when I went to bed...
    At least AVStoDVD manages to start processing the files, other softwares say that there isn't enough space on my HD to create the dvd (while I have over 200 free GB!) or refuse to start since the result won't fit in any dvd.
    What could be the problem? If it's the files I created, shouldn't they play strange on VLC too? Could it be the change from 5:4 to 4:3 that "explodes" them so much? What could I do? Re-make them with avidemux? Use some setting of AVStoDVD?
    Thanks for any advice and apologies for my imperfect English, it's not my language.
    Jan 2007
    My best guess, is run a test using the uncut original files
    There is a good possibility you have changed something using aviDemux
    If there original work
    You can look over your cutting procedure
    Could be bit rate, or any number of framing issues, like going then together
    Load each cut as a separate file to avstodvd, do not join them with aviDemux
    There are others here with more experience on this
    In the top bar of avstodvd you can run a frame serving check
    Doing this for all titles will save a lot of wasted run time
  17. With the original files it worked perfectly.
    Then I must have done something strange with avidemux, but I am no expert and I only cut some seconds here and there, added light (they're pretty dark videos) and saved (in .avi).
    Where could my mistake be? I need to rework on the original files, if only to make them clearer...
  18. @sichenia
    please post the failed project .log file, it contains useful info to understand what went wrong with your source AVI files.
    Bye
    MrC
    AVStoDVD Homepage
  19. I had deleted the logs, but found one... here it is:
    01/09/2017 21:54:30>
    START PROCESS
    <01/09/2017 21:54:30>
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 4
    DVD Size: /4450 MB (0%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: Static Menu
    Output Folder: D:\Casa zia\Giacobazzi\dvd
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 0
    Video BitRate Min: 2500
    Video BitRate Max: 8500
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): IT - Italian
    DVD Subs Language (Primary): IT - Italian
    DVD Burning Drive: F:\
    Save General Settings: 0
    SYSTEM INFO
    Processor Name: Intel(R) Core(TM) i3-6100 CPU @ 3.70GHz
    Operating System: Windows 10 (10.0.15063) 64 bit
    Available Output Disc Space: 114 GB
    LAV Filters is installed: YES (release 0.69.0)
    CODECS REPORT
    H.264/AVC: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
    Xvid: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
    DivX 4/5/6: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
    Other MPG4: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
    DV: DV Video Decoder {B1B77C00-C3E4-11cf-AF79-00AA00B67A42}
    MPEG1: MPEG Video Codec {feb50740-7bef-11ce-9bd9-0000e202599c}
    MPEG2: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
    MP2: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
    MP3: MP3 Decoder DMO {BBEEA841-0A63-4F52-A7AB-A9B3A84ED38A}
    AAC: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
    AC3: No Preferred Filter set
    Video: D:\Casa zia\Giacobazzi\Esterno.avi
    Info: AVC - 6207 kbps - 720x576 - DAR 4:3 - 25 fps - Progressive - 6:00:52 hours - 11771 frames
    Audio 1: D:\Casa zia\Giacobazzi\Esterno.avi
    Info: AAC LC - 128 kbps - CBR - 2 ch - 48000 Hz - 6:00:52 hours (0 ms delay)
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("D:\Casa zia\Giacobazzi\Esterno.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp", FrameRateNum=25, FrameRateDen=1, FrameRate=25)
    Audio = A2DAudioSource("D:\Casa zia\Giacobazzi\Esterno.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp")
    DIRECTSHOW AUDIO MIXER OPERATIONS:
    No LAV Filters mixer ON/OFF adjustment required at runtime
    Target Video FileSize: 32202 MB
    Encoding Parameters: -ini "C:\Users\Elena\AppData\Local\Temp\DVD_Title_01_Est erno.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_01_Est erno_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Elena\Videos\DVD_Title_01_Esterno.m2v
    *LOGFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_01_Est erno.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2500
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 20
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *DBPATH C:\Users\Elena\AppData\Local\Temp
    *WAIT 2
    <02/09/2017 02:16:32>
    END VIDEO ENCODING OPERATIONS
    Video Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Users\Elena\Videos\DVD_Title_01_Esterno.m2v (32218,3 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 12482 kbps - 720x576 - DAR 4:3 - 25 fps - Progressive (TFF) - 6:00:52 hours - 541312 frames
    <02/09/2017 02:17:33>
    Process halted during Title 1 VIDEO encoding operations.
    Error Message: 'Warning! Title 1 output Video duration (06:00:52) is shorter than expected duration (06:00:52).'
    Video errors warning message skipped.
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "C:\Users\Elena\AppData\Local\Temp\DVD_Title_01_Est erno_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Elena\Videos\DVD_Title_01_Esterno_1.ac3"
    <02/09/2017 04:18:34>
    WARNING! Errors found during Title 1 Audio Track 1 encoding.
    Audio filesize is too low (0 MB)
    Backup Audio encoding routine (FFmpeg Safe Mode) is starting ...
    <02/09/2017 04:18:35>
    START FFMPEG (SAFE MODE) AUDIO ENCODING OPERATIONS (Track 1) - Trial 1/2
    FFmpeg Parameters: -threads 4 -i "D:\Casa zia\Giacobazzi\Esterno.avi" -vn -c:a ac3 -ar 48000 -ab 192k -y "C:\Users\Elena\Videos\DVD_Title_01_Esterno_1.ac3"
    <02/09/2017 04:18:44>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Audio Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Users\Elena\Videos\DVD_Title_01_Esterno_1.ac3 (7,2 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 5:17 minutes (0 ms delay)
    <02/09/2017 04:19:45>
    Process halted during Title 1 AUDIO (Track 1) encoding operations.
    Error Message: 'Warning! Title 1 Audio Track 1 output Audio duration (00:05:17) is shorter than expected duration (06:00:52).'
    Audio (Track 1) errors warning message skipped.
    DVD CHAPTERS CREATION OPERATIONS
    Title 1 Input Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500 90000 97500 105000 112500 120000 127500 135000 142500 150000 157500 165000 172500 180000 187500 195000 202500 210000 217500 225000 232500 240000 247500 255000 262500 270000 277500 285000 292500 300000 307500 315000 322500 330000 337500 345000 352500 360000 367500 375000 382500 390000 397500 405000 412500 420000 427500 435000 442500 450000 457500 465000 472500 480000
    Title 1 Output Chapters List: 7500 15000 22500 30000 37500 45000 52500 60000 67500 75000 82500 90000 97500 105000 112500 120000 127500 135000 142500 150000 157500 165000 172500 180000 187500 195000 202500 210000 217500 225000 232500 240000 247500 255000 262500 270000 277500 285000 292500 300000 307500 315000 322500 330000 337500 345000 352500 360000 367500 375000 382500 390000 397500 405000 412500 420000 427500 435000 442500 450000 457500 465000 472500 480000
    Created File: C:\Users\Elena\Videos\DVD_Title_01_Esterno_Chapter s.txt (500 Byte)
    TITLE 2 SOURCE FILES
    Video: D:\Casa zia\Giacobazzi\Interno.avi
    Info: AVC - 1054 kbps - 720x576 - DAR 4:3 - 25 fps (VFR) - Progressive - 12:27 minutes - 18665 frames
    Audio 1: D:\Casa zia\Giacobazzi\Interno.avi
    Info: AAC LC - 128 kbps - CBR - 2 ch - 48000 Hz - 0 seconds (0 ms delay)
    AVISYNTH SCRIPT
    Video = A2DVideoSource("D:\Casa zia\Giacobazzi\Interno.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp", VFR=true, FrameRateNum=25, FrameRateDen=1, FrameRate=25)
    Audio = A2DAudioSource("D:\Casa zia\Giacobazzi\Interno.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp")
    Target Video FileSize: 222,6 MB
    Encoding Parameters: -ini "C:\Users\Elena\AppData\Local\Temp\DVD_Title_02_Int erno.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_02_Int erno_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Elena\Videos\DVD_Title_02_Interno.m2v
    *LOGFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_02_Int erno.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2500
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 20
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <02/09/2017 04:22:31>
    Created File: C:\Users\Elena\Videos\DVD_Title_02_Interno.m2v (222,6 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 2501 kbps - 720x576 - DAR 4:3 - 25 fps - Progressive (TFF) - 12:27 minutes - 18665 frames
    Wavi+Aften Parameters: "C:\Users\Elena\AppData\Local\Temp\DVD_Title_02_Int erno_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Elena\Videos\DVD_Title_02_Interno_1.ac3"
    <02/09/2017 04:22:34>
    Created File: C:\Users\Elena\Videos\DVD_Title_02_Interno_1.ac3 (17,1 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 12:27 minutes (0 ms delay)
    Title 2 Input Chapters List: 7500 15000
    Title 2 Output Chapters List: 7500 15000
    Created File: C:\Users\Elena\Videos\DVD_Title_02_Interno_Chapter s.txt (15 Byte)
    TITLE 3 SOURCE FILES
    Video: D:\Casa zia\Giacobazzi\persone.avi
    Info: AVC - 622 kbps - 720x576 - DAR 4:3 - 25 fps (VFR) - Progressive - 22:58:34 hours - 3260 frames
    Audio 1: D:\Casa zia\Giacobazzi\persone.avi
    Info: AAC LC - 128 kbps - CBR - 2 ch - 48000 Hz - 22:58:34 hours (0 ms delay)
    AVISYNTH SCRIPT
    Video = A2DVideoSource("D:\Casa zia\Giacobazzi\persone.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp", VFR=true, FrameRateNum=25, FrameRateDen=1, FrameRate=25)
    Audio = A2DAudioSource("D:\Casa zia\Giacobazzi\persone.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp")
    Target Video FileSize: 1,413522E+07 MB
    Encoding Parameters: -ini "C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_per sone.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_per sone_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Elena\Videos\DVD_Title_03_persone.m2v
    *LOGFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_per sone.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2500
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 20
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <02/09/2017 09:14:47>
    Process halted during Title 3 VIDEO encoding operations.
    Error Message: 'Warning! Title 3 output Video duration (00:00:00) is shorter than expected duration (22:58:34).'
    Wavi+Aften Parameters: "C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_per sone_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Elena\Videos\DVD_Title_03_persone_1.ac3"
    <02/09/2017 09:15:07>
    Process aborted during Title 3 AUDIO (Track 1) encoding operations.
    Error Message: Warning! Title 3 Audio Track 1 cannot be encoded!
    For Audio issues troubleshooting see Help/FAQ/Audio section.
    Log file created by AVStoDVD Release 2.8.6
  20. It could be just a directshow codecs issue. Take a look at Help/FAQ/General/Q1.5
    If you have troubles in changing the default codecs from Microsoft to LAV Filters, then go to Help/FAQ/GUI/Q2.7
    Restart your project. If you still have errors messages, come back here with the log file. Buona fortuna con la zia!
    Bye
    MrC
    AVStoDVD Homepage
  21. Ciao MrC,
    I changed the codecs and started again the process with the same files, it didn't work. Here's the log:
    Thanks for your help! (la zia apprezza)
    <11/09/2017 22:29:15>
    START PROCESS
    PROJECT SETTINGS
    DVD Output Setup: Struttura DVD
    DVD Label: DVD
    Post Process Task: Mostra la finestra Controllo Progresso
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 0
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Burning Drive: F: HL-DT-ST DVDRAM GH24NSD1 LG00
    Execute with Elevated Privileges: 1
    SYSTEM INFO
    Running with Elevated Privileges: YES
    CODECS REPORT
    AVISYNTH SCRIPT
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 2500
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 20
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <12/09/2017 02:36:18>
    <12/09/2017 02:37:19>
    <12/09/2017 04:38:20>
    <12/09/2017 04:38:21>
    <12/09/2017 04:38:30>
    <12/09/2017 04:39:31>
    AVISYNTH SCRIPT
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 2500
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 20
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <12/09/2017 04:42:02>
    OUTPUT VIDEO INFO: MPEG-2 Video - 2500 kbps - 720x576 - DAR 4:3 - 25 fps - Progressive (TFF) - 12:27 minutes - 18665 frames
    <12/09/2017 04:42:04>
    Video: D:\Casa zia\Giacobazzi\Cantine.avi
    Info: AVC - 737 kbps - 720x576 - DAR 4:3 - 25 fps (VFR) - Progressive - 18:01:11 hours - 11061 frames
    Audio 1: D:\Casa zia\Giacobazzi\Cantine.avi
    Info: AAC LC - 128 kbps - CBR - 2 ch - 48000 Hz - 18:01:11 hours (0 ms delay)
    AVISYNTH SCRIPT
    Video = A2DVideoSource("D:\Casa zia\Giacobazzi\Cantine.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp", VFR=true, FrameRateNum=25, FrameRateDen=1, FrameRate=25)
    Audio = A2DAudioSource("D:\Casa zia\Giacobazzi\Cantine.avi", CacheFolder="C:\Users\Elena\AppData\Local\Temp")
    Target Video FileSize: 1,263645E+07 MB
    Encoding Parameters: -ini "C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_Can tine.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_Can tine_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Elena\Videos\DVD_Title_03_Cantine.m2v
    *LOGFILE C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_Can tine.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 2500
    *PROFILE BEST
    *ASPECT 4:3
    *PROGRESSIVE
    *TFF
    *BIAS 20
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <12/09/2017 07:19:25>
    Error Message: 'Warning! Title 3 output Video duration (00:00:00) is shorter than expected duration (18:01:11).'
    Wavi+Aften Parameters: "C:\Users\Elena\AppData\Local\Temp\DVD_Title_03_Can tine_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Elena\Videos\DVD_Title_03_Cantine_1.ac3"
    <12/09/2017 07:19:36>
    WARNING! Errors found during Title 3 Audio Track 1 encoding.
    <12/09/2017 07:19:37>
    FFmpeg Parameters: -threads 4 -i "D:\Casa zia\Giacobazzi\Cantine.avi" -vn -c:a ac3 -ar 48000 -ab 192k -y "C:\Users\Elena\Videos\DVD_Title_03_Cantine_1.ac3"
    <12/09/2017 07:19:39>
    Created File: C:\Users\Elena\Videos\DVD_Title_03_Cantine_1.ac3 (10,1 MB)
    OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 7:22 minutes (0 ms delay)
    <12/09/2017 07:19:41>
    Error Message: Warning! Title 3 Audio Track 1 output Audio duration (00:07:22) is shorter than expected duration (18:01:11).
  22. Member
    Mar 2008
    There is something wrong with this file
    The mediainfo says it is over 6 hours, but 11771 frames @ 25 fps is less that 8 minutes
    Some of the other input files have similar issues. Could it be a mediainfo problem?
  23. Definitively the source AVI files are problematic: abnormal video and audio durations, variable frame rate, AVC/AAC in AVI container. At least we have understood that it's not a decoding issue.
    I would go back to the editing step.
    1. Load title 1 into Avidemux, do use a recent stable 64bit release
    2. Execute your cuts and brightness/colors adjustments
    3. Re-encode video with a lossless codec (e.g. HuffYUV). If the original video stream from the mp4 file is VFR (variable frame rate), apply Resample FPS filter (25 fps) to convert to CFR (constant frame rate)
    4. Re-encode audio with a lossless codec (e.g. PCM).
    5. Save as AVI
    6. Load the new AVI into AVStoDVD and check if audio and video timings are consistent
    7. Run the project
    If the resulting AVI from step 5 is too huge for your HD, then use lossy codecs (e.g. x264 and AAC) with high bitrates (e.g. 5000 for video, 384 for audio). Save as MKV.
    Come back here with the log files if you still have issues.
    AVStoDVD has also some editing capability (Edit Title > AviSynth), but for sure Avidemux is easier to use.
    Bye
    MrC
    AVStoDVD Homepage
  24. I made it!! It was an editing problem with the files I used. After re-editing following the steps you provided, everything worked like a charm.
    Thanks a lot everyone!!
  25. Member
    Jan 2014
    Western Arkansas
    Help!I'm trying to convert an mp4 video (about 3 hours long) using the latest AVStoDVD 2.8.6 ver. DVD9 folder structure. It starts out normally, with FFmpeg running normally then after a few minutes it slows way way down. It is taking about 2 minutes per frame. It has been running for nearly 48 hours now and still not done. I'm not getting any error messages and it still running but just very very slow.
    It is not my computer. I have nothing else running except the operating system. I checked the task manager and the CPU is only running at about 7% utilization and the memory about 40%. I have converted lots of videos in the past and never had this problem.
    Anyone know what I can do to fix this? Thanks in advance....
    Here is the current log file.
    <9/30/2017 10:28:30 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Size: 8100/8100 MB (100%)
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\Daddy\Videos
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video Encoder: 1
    AC3 Audio Encoder: 2
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Burning Drive: D: MATSHITA BD-MLT UJ272 1.00
    SYSTEM INFO
    Processor Name: AMD A8-7410 APU with AMD Radeon R5 Graphics
    Available Output Disc Space: 149 GB
    LAV Filters is installed: YES (release 0.66.0)
    CODECS REPORT
    Video: C:\Users\Daddy\Documents\Cornhuskers 2017\G5-Illinois\G5-Illinois.mp4
    Info: AVC - 5986 kbps - 1280x720 - DAR 16:9 - 60 fps (CFR) - Progressive - 3:00:08 hours - 648470 frames
    Audio 1: C:\Users\Daddy\Documents\Cornhuskers 2017\G5-Illinois\G5-Illinois.mp4
    Info: AAC LC - 165 kbps - VBR - 2 ch - 48000 Hz - 3:00:08 hours (0 ms delay)
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\MotionProtectedFPS.avsi")
    Video = A2DVideoSource("C:\Users\Daddy\Documents\Cornhuskers 2017\G5-Illinois\G5-Illinois.mp4", CacheFolder="C:\Users\Daddy\AppData\Local\Temp", VFR=false, FrameRateNum=60, FrameRateDen=1, FrameRate=60)
    Audio = A2DAudioSource("C:\Users\Daddy\Documents\Cornhuskers 2017\G5-Illinois\G5-Illinois.mp4", CacheFolder="C:\Users\Daddy\AppData\Local\Temp")
    Video = Video.MotionProtectedFPS(29.97)
    Video Encoding Profile: FFmpeg CBR 1-pass
    Target Video FileSize: 7622.3 MB
    Encoding Parameters: -i "C:\Users\Daddy\AppData\Local\Temp\DVD_G5-Illinois_1.avs" -threads 4 -aspect 16:9 -c:v mpeg2video -b:v 5916k -minrate 5916k -maxrate 5916k -bufsize 2000k -dc 9 -y "C:\Users\Daddy\Videos\DVD_G5-Illinois.m2v"
  26. Member
    Mar 2008
    START PROCESS
    PROJECT SETTINGS
    * snip*
    I woud first try setting these two preferences:
    On the Avisynth tab AVS Video source filter - set it to FFmpegsource
    also on the same tab, hard frame rate conversion - set it to ChangeFPS
    Save the preferences as default and rebuild the project before you restart it
  27. Member
    Jan 2014
    Western Arkansas
    Thank you much davexnet! it worked. although I don't understand why. I'd really like to understand what all of the different parameters do so I know what to choose.
  28. Member
    Mar 2008
    You can see from the your log that LAV filters are installed but not active, defaulting to the usage of the MS filters which can cause this and other problems.
    Best to set the source filter to FFmpegsource in this case.
    The other item becomes germane when the program has to do a frame rate conversion for DVD compliance.
    ChangeFPS does a sort of "intelligent" decimation/ repetition of frames while MotionProtectedFPS blends frames to get the required result.
    MotionProtectedFPS has been known to cause problems with CPU usage and extended run times when it is used with the HCenc encoder
    (see the video encoder on the video tab of Title/Edit Title)
    Generally, MotionProtectedFPS is safe to use when AvstoDVD has been set (or defaulted) to the FFmpeg encoder and it's matter of preference
    which one to use. Some are sensitive to the blurring inherent in it's use, while others are more sensitive to possible small stuttering in motion scenes
    you may notice when ChangeFPS is used.
  29. Member
    Jan 2014
    Western Arkansas
    thank you again that helps!
  30. Can someone please give me step by step directions on how to delay the audio when it's out of sync? I thought I could correct it by going into LAV Filters audio settings, enable audio delay, & then playing around with the Delay (in ms) settings. When I do that, I can preview the title & have the audio delay actually change, but there's obviously something I'm missing because it still always says 0ms delay in the title that I'm setting up to burn. Once I click start, it just makes the disk image as if I didn't actually do anything and the log files where I attempted to create the disk with different delay settings look essentially identical to me (just different start times & less space on my hard drive). I tried disabling auto A/V sync correction & Auto Adjust Delay, but got nowhere with that either.
