Page 3 of 12
FirstFirst 1 2 3 4 5 ... LastLast
Results 61 to 90 of 359
  1. why cant i get 2.8.0
ID:	29552Click image for larger version
    I can only get 2.7.5
    i dont understand..
  2. Ok, let's face it from another perspective: have you tried to create a DVD structure with just one title? Do you get the same error?
    Bye
    MrC
    AVStoDVD Homepage
  3. again erreos
    <07-01-2015 19:12:14>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 4
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: ISO UDF Image
    DVD Label: DVD
    DVD Menu: Static Menu
    Output Folder: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage sęson 1
    Delete Temp Assets Files: Yes
    Delete Temp Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Video Source Filter: A2DSource
    AVS Audio Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
    Frame Adjust Strategy: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 1
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 224
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Audio Language (Primary): EN - English
    DVD Audio Language (Secondary): EN - English
    DVD Subs Language (Primary): DA - Danish
    DVD Subs Language (Secondary): EN - English
    DVD Subs Font: Tahoma 20pt (255,255,255)
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: H: TSSTcorp CDDVDW SH-222AB SB00
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Unload ActiveMovie library: 0
    Adjust DirectShow Filters at runtime: 1
    Save General Settings: 0
    SYSTEM INFO
    Processor Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
    Operating System: Windows 8 (64 bit)
    AviSynth is installed: YES (release 2.5.8)
    LAV Filters is installed: YES (release 0.63.0)
    ffdshow is installed: YES (release 1.3.4500)
    TITLE 1 SOURCE FILES
    Video: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E01..mkv
    Info: AVC - 1411 kbps - 720x404 - DAR 1,782 - 25 fps (CFR) - Progressive - 41:44 minutes - 62613 frames
    Audio 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E01..mkv
    Info: AC3 - 192 kbps - CBR - 2 ch - 44100 Hz - 16 bit - 41:44 minutes (-6 ms delay)
    Subs 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E01..mkv
    Info: SubRip (SRT) - DA
    [MediaInfoLib - v0.7.69]
    AVISYNTH SCRIPT
    Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E01..mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp", FrameRate=25, VFR=false)
    Audio = A2DAudioSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E01..mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp")
    Video = Video.ConvertToYV12()
    Video = Video.Lanczos4Resize(720,576)
    Audio = Audio.SSRC(48000)
    Audio = Audio.DelayAudio(-0.006)
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 2-pass
    Target Video FileSize: 1006,6 MB
    Encoding Parameters: -ini "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01..HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01._1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01..m2v
    *LOGFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01..HCenc.log
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *DBPATH C:\Users\Bruger\AppData\Local\Temp
    *WAIT 2
    <07-01-2015 19:20:27>
    END VIDEO ENCODING OPERATIONS
    Video Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01..m2v (1006,9 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 3372 kbps - 720x576 - DAR 16:9 - 25 fps (CFR) - Progressive (TFF) - 41:44 minutes - 62610 frames
    DIRECTSHOW AUDIO MIXER OPERATIONS:
    No mixer adjustment required at runtime.
    START AUDIO ENCODING OPERATIONS (Track 1)
    FFmpeg (WAV) Parameters: -i "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01._1.avs" "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01._1.wav"
    Aften (AC3) Parameters: -b 224 -pad 0 -dynrng 5 -bwfilter 0 "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01._1.wav" "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._1.ac3"
    <07-01-2015 19:21:28>
    ffdshow mixer setting restored to '1'
    END AUDIO ENCODING OPERATIONS (Track 1)
    Audio Source Filter: A2DSource (DirectShowSource)
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._1.ac3 (66,9 MB)
    OUTPUT AUDIO INFO: AC3 - 224 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 41:44 minutes (0 ms delay)
    START SUBS EXTRACTING OPERATIONS (Track 1)
    MKVExtract Parameters: tracks "C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E01..mkv" 2:"C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01..srt"
    <07-01-2015 19:21:29>
    END SUBS EXTRACTING OPERATIONS (Track 1)
    Created File: C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01..srt (31,3 KB)
    START SUBS ENCODING OPERATIONS (Track 1)
    ANSI format conversion routine applied
    SRT fixing routine applied (0 lines fixed)
    SubtitleCreator Parameters: "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_01_ Leverage E01..srt" -p2 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <07-01-2015 19:21:32>
    END SUBS ENCODING OPERATIONS (Track 1)
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._1.sup (0,88 MB)
    TITLE 2 SOURCE FILES
    Video: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E02.mkv
    Info: AVC - 1411 kbps - 720x404 - DAR 1,782 - 25 fps (CFR) - Progressive - 41:24 minutes - 62121 frames
    Audio 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E02.mkv
    Info: AC3 - 192 kbps - CBR - 2 ch - 44100 Hz - 16 bit - 41:24 minutes (-6 ms delay)
    Subs 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E02.mkv
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E02.mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp", FrameRate=25, VFR=false)
    Audio = A2DAudioSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E02.mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp")
    Target Video FileSize: 998,6 MB
    Encoding Parameters: -ini "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02.m2v
    *LOGFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <07-01-2015 19:29:51>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02.m2v (999 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 3372 kbps - 720x576 - DAR 16:9 - 25 fps (CFR) - Progressive (TFF) - 41:24 minutes - 62118 frames
    FFmpeg (WAV) Parameters: -i "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02_1.avs" "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02_1.wav"
    Aften (AC3) Parameters: -b 224 -pad 0 -dynrng 5 -bwfilter 0 "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02_1.wav" "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_1.ac3"
    <07-01-2015 19:30:50>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_1.ac3 (66,3 MB)
    OUTPUT AUDIO INFO: AC3 - 224 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 41:24 minutes (0 ms delay)
    MKVExtract Parameters: tracks "C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E02.mkv" 2:"C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02.srt"
    <07-01-2015 19:30:52>
    Created File: C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02.srt (35,6 KB)
    SubtitleCreator Parameters: "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_02_ Leverage E02.srt" -p2 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <07-01-2015 19:30:55>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_1.sup (0,99 MB)
    TITLE 3 SOURCE FILES
    Video: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E03.mkv
    Info: AVC - 1411 kbps - 720x404 - DAR 1,782 - 25 fps (CFR) - Progressive - 41:44 minutes - 62617 frames
    Audio 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E03.mkv
    Subs 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E03.mkv
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E03.mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp", FrameRate=25, VFR=false)
    Audio = A2DAudioSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E03.mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp")
    Encoding Parameters: -ini "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03.m2v
    *LOGFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <07-01-2015 19:39:21>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03.m2v (1007 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 3372 kbps - 720x576 - DAR 16:9 - 25 fps (CFR) - Progressive (TFF) - 41:44 minutes - 62614 frames
    FFmpeg (WAV) Parameters: -i "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03_1.avs" "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03_1.wav"
    Aften (AC3) Parameters: -b 224 -pad 0 -dynrng 5 -bwfilter 0 "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03_1.wav" "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_1.ac3"
    <07-01-2015 19:40:25>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_1.ac3 (66,9 MB)
    MKVExtract Parameters: tracks "C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E03.mkv" 2:"C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03.srt"
    <07-01-2015 19:40:27>
    Created File: C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03.srt (36,2 KB)
    SubtitleCreator Parameters: "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_03_ Leverage E03.srt" -p2 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <07-01-2015 19:40:30>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_1.sup (1,03 MB)
    TITLE 4 SOURCE FILES
    Video: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E04.mkv
    Audio 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E04.mkv
    Subs 1: C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E04.mkv
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E04.mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp", FrameRate=25, VFR=false)
    Audio = A2DAudioSource("C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E04.mkv", CacheFolder="C:\Users\Bruger\AppData\Local\Temp")
    Encoding Parameters: -ini "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04.m2v
    *LOGFILE C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <07-01-2015 19:48:53>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04.m2v (1007 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 3373 kbps - 720x576 - DAR 16:9 - 25 fps (CFR) - Progressive (TFF) - 41:44 minutes - 62610 frames
    FFmpeg (WAV) Parameters: -i "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04_1.avs" "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04_1.wav"
    Aften (AC3) Parameters: -b 224 -pad 0 -dynrng 5 -bwfilter 0 "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04_1.wav" "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_1.ac3"
    <07-01-2015 19:49:55>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_1.ac3 (66,9 MB)
    MKVExtract Parameters: tracks "C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage E04.mkv" 2:"C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04.srt"
    <07-01-2015 19:49:57>
    Created File: C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04.srt (36,5 KB)
    SubtitleCreator Parameters: "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Title_04_ Leverage E04.srt" -p2 -i"C:\Program Files (x86)\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <07-01-2015 19:50:00>
    Created File: C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_1.sup (1,01 MB)
    <07-01-2015 19:50:01>
    START DVD MENU BUILDING OPERATIONS
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Template: Menu in Black
    Max Titles Page: 12
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    Thumb Image Source: 0
    Thumb Frame Position: 10%
    HL Frame Format: 0
    HL Selection Color: 5
    HL Play Color: 0
    Menu Video BitRate: 6000 kbps
    Motion Menu Duration: 15 seconds
    Thumb Drop Shadow: 2
    Play All Shadow: 2
    Arrows Shadow: 0
    <07-01-2015 19:50:06>
    END DVD MENU BUILDING OPERATIONS
    Created File (Menu Page 1): C:\Users\Bruger\Videos\DVD_1_MenuPage1.bmp (1,2 MB)
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Users\Bruger\AppData\Local\Temp\DVD_1_BatchMux. ini"
    BatchMux ini file:
    -d "C:\Users\Bruger\Documents\Downloads\Leverage.S01-S05.COMPLETE.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage.S01.RETAiL.DKSubs.WEB-DL.H.264-GREYHOUNDS\Leverage sęson 1\DVD_1\VIDEO_TS"
    -mxp "C:\Users\Bruger\AppData\Local\Temp\DVD_1_MuxMan.mx p"
    -l "C:\Users\Bruger\AppData\Local\Temp\DVD_1_MuxMan.lo g"
    -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
    -prio LOW
    -palette "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Palette.t xt"
    -v "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01..m2v"
    -vidmode LB
    -a1 "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._1.ac3"
    -a1lang en
    -s1 "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._1.sup"
    -s1lang da
    -s1ext 1
    -cellfr "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._Chapters.txt"
    -progfr "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._Chapters.txt"
    -chapfr "C:\Users\Bruger\Videos\DVD_1_Title_01_Leverage E01._Chapters.txt"
    -SEG2v "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02.m2v"
    -SEG2vidmode LB
    -SEG2a1 "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_1.ac3"
    -SEG2a1lang en
    -SEG2s1 "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_1.sup"
    -SEG2s1lang da
    -SEG2s1ext 1
    -SEG2cellfr "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_Chapters.txt"
    -SEG2progfr "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_Chapters.txt"
    -SEG2chapfr "C:\Users\Bruger\Videos\DVD_1_Title_02_Leverage E02_Chapters.txt"
    -SEG3v "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03.m2v"
    -SEG3vidmode LB
    -SEG3a1 "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_1.ac3"
    -SEG3a1lang en
    -SEG3s1 "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_1.sup"
    -SEG3s1lang da
    -SEG3s1ext 1
    -SEG3cellfr "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_Chapters.txt"
    -SEG3progfr "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_Chapters.txt"
    -SEG3chapfr "C:\Users\Bruger\Videos\DVD_1_Title_03_Leverage E03_Chapters.txt"
    -SEG4v "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04.m2v"
    -SEG4vidmode LB
    -SEG4a1 "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_1.ac3"
    -SEG4a1lang en
    -SEG4s1 "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_1.sup"
    -SEG4s1lang da
    -SEG4s1ext 1
    -SEG4cellfr "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_Chapters.txt"
    -SEG4progfr "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_Chapters.txt"
    -SEG4chapfr "C:\Users\Bruger\Videos\DVD_1_Title_04_Leverage E04_Chapters.txt"
    -SEG5v "C:\Users\Bruger\Videos\DVD_1_MenuPage1.bmp"
    -SEG5vidmode LB
    -SEG5s1 "C:\Users\Bruger\Videos\DVD_1_Menu.sst"
    -SEG5s1dmode WIDE_LB
    -SEG5hlmnu "C:\Users\Bruger\AppData\Local\Temp\DVD_1_MenuPage1 _Buttons.mnu"
    -SEG5hlcsm "C:\Users\Bruger\AppData\Local\Temp\DVD_1_Highlight Scheme.csm
    -hcn "C:\Users\Bruger\AppData\Local\Temp\DVD_1_BatchMux. hcn"
    <07-01-2015 19:50:17>
    Process aborted during DVD AUTHORING operations!
    Check following files for more details:
    AVStoDVD log file
    BatchMux log file
    For more troubleshooting on Authoring issues, see Help/FAQ/Authoring.
    <07-01-2015 19:50:27>
    Log file created by AVStoDVD Release 2.8.0
    and from DVD_1_BatchMux.log
    Segment memory resources --> RELEASED
    Local Stack memory --> RELEASED
    File i/o structures --> DEALLOCATED
    there are the sam problem i see.. and yes i tryed with one titel
  4. again erreos
    START PROCESS
    PROJECT SETTINGS
    DVD Label: DVD
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    DVD Audio Format: 0
    Normalize Audio: 0
    Auto Delay Audio: 1
    SYSTEM INFO
    AVISYNTH SCRIPT
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    AVISYNTH SCRIPT
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    AVISYNTH SCRIPT
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    AVISYNTH SCRIPT
    HCenc ini file:
    *AVSRELOAD
    *MAXBITRATE 9000
    *BITRATE 3371
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 30
    *DC_PREC 8
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    DVD Menu settings:
    Style: 0
    Aspect Ratio: 1
    Titles Format: 1
    Max Titles Page: 12
    Enable Play All: 1
    Force Play All: 0
    Background Audio: 0
    Max Thumbs Row: 4
    HL Frame Format: 0
    HL Play Color: 0
    Play All Shadow: 2
    Arrows Shadow: 0
    BatchMux ini file:
    -prio LOW
    -vidmode LB
    -a1lang en
    -s1lang da
    -s1ext 1
    -SEG2vidmode LB
    -SEG2a1lang en
    -SEG2s1lang da
    -SEG2s1ext 1
    -SEG3vidmode LB
    -SEG3a1lang en
    -SEG3s1lang da
    -SEG3s1ext 1
    -SEG4vidmode LB
    -SEG4a1lang en
    -SEG4s1lang da
    -SEG4s1ext 1
    -SEG5vidmode LB
    AVStoDVD log file
    BatchMux log file
  5. And with one title only, do you get the same error?
    I have noticed from the log file you have installed both ffdshow and LAV Filters. That's redundant: I suggest you to remove one of them.
    Bye
    MrC
    AVStoDVD Homepage
  6. yes.. i get the same error ever danm time...
    and its some bullshit...
    i cant work with that program anymore.. when the same error comes..
  7. Please be more polite and a bit more confident, we are here (for free) to help you.
    Have you removed either ffdshow or LAV?
    Do you have the possibility to upload one of the MKV title to test it?
    Bye
    MrC
    AVStoDVD Homepage
  8. I had problems last week with AVStoDVD, but also with another program too (Audio-Coder).
    I simple System-Restore (7 days behind) make my day.
    P.S.
    I was thinking to start using the new update v.280, but haven't yet.
    Hope it help.
  9. Originally Posted by _MrC_ View Post
    Bye
    yes i have remove LAV and it not working
  10. Originally Posted by denmark1990 View Post
    Well, we have removed one variable. Now, moving forward, do you have the possibility to upload one of the MKV title to test it?
    Bye
    MrC
    AVStoDVD Homepage
    Jan 2015
    Hi, I am new to the site and AVStoDVD but I have tried to research this problem but no luck.
    I have installed AVStoDVD 2.8 and it works well [ty] except, when I try and convert an MKV file to a PAL DVD, the audio is out of synch.
    It is also out of synch if I convert it to an mpeg.
    The MKV plays perfectly in VLC media player.
    Please could anyone tell me which settings I need to change to make this work? I have tried lots, but cant find an option that allows me to control the audio delay. I see the audio could possibly be demuxed then remuxed, but that seems like overkill, hoping there is a simpler way.
    Many thanks, Richard.
  12. Hi blakpawn,
    first of all welcome there.
    A good start can be to post here the log file of a project with audio out of sync. You find the .log file in the Output Folder you have selected in main AVStoDVD window.
    Bye
    MrC
    AVStoDVD Homepage
    Jan 2015
    Hi, below is the log file I have with my attempted conversion [my problem is the audio is out of synch with the picture throughout]. Before I created the file I reset all options. Any clues on how to remedy this would be much appreciated. Thank you.
    <20/01/2015 19:55:33>
    START PROCESS
    PROJECT SETTINGS
    DVD Titles number: 1
    DVD Size: 2705/4450 MB (61%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\Richard\Videos
    PREFERENCES
    MultiThread: 1
    PAL SpeedUp: 0
    NTSC SlowDown: 0
    Video Resolution: 0
    AC3 Audio Encoder: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Normalize Audio: 0
    Auto Delay Audio: 1
    DVD Subs Language (Primary): EN - English
    DVD Subs Font: Tahoma 16pt (255,255,255)
    DVD Burning Drive: E:\
    SYSTEM INFO
    Processor Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
    Operating System: Windows 7 Service Pack 1 (64 bit)
    ffdshow is installed: NO
    Video: C:\Users\Richard\Downloads\Arrow.S03E02.720p.HDTV. X264-DIMENSION.mkv
    Info: AVC - 2659 kbps - 1280x720 - DAR 16:9 - 23.976 fps (CFR) - Progressive - 42:04 minutes - 60516 frames
    Audio 1: C:\Users\Richard\Downloads\Arrow.S03E02.720p.HDTV. X264-DIMENSION.mkv
    Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 42:04 minutes (4 ms delay)
    AVISYNTH SCRIPT
    Video = A2DVideoSource("C:\Users\Richard\Downloads\Arrow.S03E02.720p.HDTV. X264-DIMENSION.mkv", CacheFolder="C:\Users\Richard\AppData\Local\Temp", FrameRate=23.976, VFR=false)
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("C:\Users\Richard\Downloads\Arrow.S03E02.720p.HDTV. X264-DIMENSION.mkv", CacheFolder="C:\Users\Richard\AppData\Local\Temp")
    Video = Video.Spline16Resize(720,576)
    #Using DGPulldown/HCenc to upsize FPS
    Encoding Profile: FFmpeg CBR 1-pass
    Target Video FileSize: 2557.5 MB
    Encoding Parameters: -i "C:\Users\Richard\AppData\Local\Temp\DVD_Arrow.S03E 02.720p.HDTV.X264-DIMENSION_1.avs" -threads 8 -aspect 16:9 -c:v mpeg2video -b:v 8500k -minrate 8500k -maxrate 8500k -bufsize 2000k -dc 10 -y "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION.m2v"
    <20/01/2015 20:09:06>
    Created File: C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION.m2v (2557.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x576 - DAR 16:9 - 23.976 fps (CFR) - Progressive - 42:00 minutes - 60440 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <20/01/2015 20:11:56>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION.m2v (2557.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x576 - DAR 16:9 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 42:04 minutes - 63100 frames
    START AUDIO DEMUXING OPERATIONS (Track 1)
    FFmpeg Parameters: -i "C:\Users\Richard\Downloads\Arrow.S03E02.720p.HDTV. X264-DIMENSION.mkv" -acodec copy -vn -sn -y "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION_1.ToFix.ac3"
    <20/01/2015 20:12:10>
    END AUDIO DEMUXING OPERATIONS (Track 1)
    Created File: C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION_1.ac3 (115.5 MB)
    OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 16 bit - 42:03 minutes (0 ms delay)
    BatchMux Parameters: -arglist "C:\Users\Richard\AppData\Local\Temp\DVD_BatchMux.i ni"
    BatchMux ini file:
    -d "C:\Users\Richard\Videos\DVD\VIDEO_TS"
    -mxp "C:\Users\Richard\AppData\Local\Temp\DVD_MuxMan.mxp"
    -l "C:\Users\Richard\AppData\Local\Temp\DVD_MuxMan.log"
    -prio LOW
    -palette "C:\Users\Richard\AppData\Local\Temp\DVD_Palette.tx t"
    -v "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION.m2v"
    -vidmode LB
    -a1 "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION_1.ac3"
    -a1lang en
    -cellfr "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION_Chapters.txt"
    -progfr "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION_Chapters.txt"
    -chapfr "C:\Users\Richard\Videos\DVD_Arrow.S03E02.720p.HDTV .X264-DIMENSION_Chapters.txt"
    <20/01/2015 20:13:12>
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Users\Richard\Videos\DVD (2717.7 MB)
    CHECK DVD SIZE
    DVD Folder (actual) Size: 2717.7 MB
    vs Estimated Size: 2705 MB -> 0.5% oversize
    vs Assets Size: 2673 MB -> OK
    <20/01/2015 20:13:13>
  14. Verify if LAV Filters is being used by your system: use the 'Codecs'/'Build DirectShow Filters Graph' for this purpose. Post here the graph screenshot.
    Bye
    MrC
    AVStoDVD Homepage
    Jan 2015
    Hi, Thanks again for your patience, investigating this issue, here is the graph as requested.
  16. The audio section is ok, but the video track is being decoded by Win7 native codecs, instead of LAV Filters.
    You can use the 'Codecs'/'Preferred DirectShow Codecs Setup' to force the priority to LAV Filters. If you get errors, you can use Win7DSFilterTweaker, which is a dedicated tool, to accomplish the same thing.
    Then, check again with 'Codecs'/'Build DirectShow Filters Graph' if LAV Filters is decoding both video and audio. Restart the AVStoDVD project.
    Bye
    MrC
    AVStoDVD Homepage
    Jan 2015
    That worked perfectly. I got the errors exactly as you described, and used the tool to switch the priority to LAV filters, now the audio and video are in perfect synch. Thank you so much, your help was spot on and your instructions very clear.
  18. Bye
    MrC
    AVStoDVD Homepage
  19. I am a N00B
    Jan 2015
    Purul
    Looking for the best dvd quality as possible
    Time factor don't matter. Encoding can take as long as it takes
Name:	1HCenc video.JPG
    My source are Nikon D5200/D5300, Canon 600D/D600
    post-proceesing with Premier and After Effects
    Contents are mainly Weddings Videos.
    Also I have an i7 3 Gen While encoding it seems to be using only 40-50%
    Jan 2015
    Here is an interesting thing I would like to report, it doesn't need a fix, its just odd.
    The day after I installed Win7DSFilterTweaker, when my PC booted I got a fail error on hard disc 0. This is odd because the machine behaved fine but kept reporting this error. I tried numerous ways to fix this, all failed. Today I ran a system restore to 1 week ago, before I installed Win7DSFilterTweaker and now the problem has gone. I reinstalled AvsToDvd and it kept my LAV preferences. So all is well but maybe this tool Win7DSFilterTweaker had a conflicted with IAStorUI which is my hard disc management software from Intel.
    I'm not complaining I just mention it for your information. Thank you.
  21. Hi blakpawn,
    thanks for the feedback about the your experience with Win7DSFilterTweaker. Maybe you can report this issue to the author as well.
    Starting from next release (2.8.1) there will be some significant improvement to the internal 'Preferred DirectShow Codecs Setup' tool. Stay tuned.
    Bye
    MrC
    AVStoDVD Homepage
  22. Hi, I wonder if anyone can help me. I'm new to AVStoDVD, after it came VERY highly recommended. And I love the program. It's incredibly intuitive, and as I've learned more about it I've found the customization to be impressive. Beautifully made.
    But now I'm hung up. I'm trying to create an ISO of an m4v video. No issues with the m4v, but after converting to the ISO the video gets choppy during action. No problems with audio.
    I'm using version 2.8.1 on a windows 7 pc, encoding to NTSC.
    Things I've tried:
    -I've changed the codecs to the LAV filters in the PreferredDirectShowCodecs Setup
    -I've verified that the BuildDirectShowFiltersGraph looks the same as the one in the help file. (The only difference is an unused subtitle option in the source video. I haven't started playing around with subs yet.)
    -In Edit Title->Video, I've switched Video Encoding Profile to FFmpeg
    -I've tried raising (and lowering) the average bitrates in Preferences->Video
    -I've changed AVS Source Filter to FFmpeg Source in Preferences->Avisynth
    -I'm in the process of trying the different matrix options in HCenc. But honestly, I'm the farthest thing from an expert, and this method feels like flailing around in a dark room. The differences between the matrix options are not clear to me except that they are somehow optimized to different bitrates. I've tried "MPEG," "QLB," "MPEGSTD," and "AVAMAT6" thus far.
    I've noticed that the content bitrate of the ISO is quite a bit higher than the bitrate for the m4v (and in fact it seems to be when the content bitrate jumps up to >8000 that the video starts getting choppy). Excuse the ignorant question, but is it normal for the bitrate on the ISO to be so much higher (about 4x bitrate for the m4v)?
    I've also tried converting to mpeg2 using WinFF, and I get the same choppiness. Is this just an inevitable consequence of converting from m4v to mpeg2?
    Any advice anyone can offer would be greatly appreciated!
  23. I'm a MEGA Super Moderator Baldrick's Avatar
    Things I've tried:
    What is the frame rate in your mv4/mp4? Check with mediainfo. And to what frame rate are you converting to? 25fps PAL or 23.976/29.97 NTSC.
  24. The AVStoDVD project log file and a portion of the output DVD (or mpeg file) with choppiness would be great to better understand the issue.
    Bye
    MrC
    AVStoDVD Homepage
  25. Thanks for the quick replies!
  26. Hey, I have an update that may or may not be relevant. Just for the heck of it, I tried backing up as an .mkv instead of .m4v. When I add that title to AVStoDVD, it kicks up a warning that my media has a frame rate of 25 fps, so I should encode as PAL. (I'm encoding as NTSC currently.) When I check with VLC, it claims that the frame rate is 23.976, which I think should be consistent with NTSC.
    Is this just some quirk of AVStoDVD reading an .mkv? Or am I doing something wrong? The ISO shows that same choppiness.
  27. Hi pheeno, the main issue with your source m4v file is that it is VFR (variable frame rate), hence AVStoDVD selects MotionProtectedFPS to do an hard conversion from 23.976 VFR to 29.97 CFR (constant), instead of selecting DGPulldown for a soft pulldown.
    Workaround: go to 'Edit Title'/'Avisynth' and manually change:
    MotionProtectedFPS(29.97)
    to:
    MotionProtectedFPS(23.976)
    Now the hard conversion from VFR should have a limited impact. Then soft pulldown will be invoked.
    Another option may be to totally remove the MotionProtectedFPS call, but I would leave it as 2nd workaround.
    Bye
    MrC
    AVStoDVD Homepage
  28. Hi there,
    I just downloaded AVStoDVD and am excited to get my project moving. There seems to be so much customization. One problem I have run across...as I enter frames for chapters, after I enter 15, it seems I can't create any more custom ones. Is this a limit (I didnt see any discussion of it, but I could have missed it), or am I missing something else. I have checked to see confirm if the frames I have entered were within range, and they were.
    Has anyone else experienced this? Any thoughts would be appreciated. Thanks.
    Brian
  29. Hi bcomp,
    are you entering chapters using the 'Edit Title' -> 'Chapters' -> 'Add Chapter' command? Actually there's no limit to the chapter flags you may insert. Can you provide a screenshot of the error/warning message, if any?
    Bye
    MrC
    AVStoDVD Homepage
