test
Results 1 to 9 of 9
Split it?
Just use an editor that doesn't reconvert, https://www.videohelp.com/tools/sections/video-editors-basic -
Did you use video->direct stream copy in virtualdub?
But just split it with virtualdub, set start and stop, save and then import the cuts in Premiere.
If you have several HDDs then try save to another hdd. It should be much faster than saving/copying between same HDD/partition.
Acrobat Pro X not opening files within an IE window
By Toastie in forum ComputerReplies: 1Last Post: 22nd May 2011, 13:49 -
Opening video files from computer
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 17:55 -
Opening files in Graph Edit
By tb582 in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 13:27 -
Opening Multiple files in Dr. Divx
By clawg in forum Video ConversionReplies: 0Last Post: 8th Apr 2008, 13:04 -
opening .z files on a mac?
By jwnulife in forum MacReplies: 1Last Post: 20th Mar 2008, 09:53
