I'm talking about transcoding DNxHD from MXF containers, which traditionally separate the video stream and each audio channel into totally separate files. So what I need to do is basically say
- Input 'video.mxf'
- Input 'Audioleft_mono.mxf'
- Input 'Audioright_mono.mxf'
- Output a new file with a stereo audio stream, in which audioleft is panned 100% to the left and audioright is panned 100% to the right.
Sounds simple, but the syntax of the -amerge command is just inscrutable to me. I have no idea how to work it.
If someone could just throw out the correct syntax for a command like this, I'd be grateful.
ffmpeg generate audio/add to video help please, command line
By surfmonkee in forum LinuxReplies: 3Last Post: 11th Sep 2011, 17:17 -
FFmpeg / FFmbc ---> 8 Mono track to 1 Stereo
By elmuz in forum Video ConversionReplies: 2Last Post: 13th Jun 2011, 07:06 -
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 06:45 -
Best Way To Detect Whether Audio In A File Is Dual-Mono Stereo?
By onesikgypo in forum AudioReplies: 15Last Post: 26th Jul 2009, 00:47 -
how is dvd source audio determined to be stereo or mono?
By iamtehsux in forum DVD RippingReplies: 1Last Post: 28th Aug 2008, 02:29
