Ill try to make this short. Im kind of an amateur and need some guidance in the world of AVCHD.
I film in AVCHD. So if I use a program like Adobe Premiere Pro or Final Cut Pro X do I need a conversion program for AVCHD?
I have the program TOAST on my computer. Do I need to convert the video through Toast before it can be edited on one of those programs like Adobe Premiere?
Bottom line is, Im trying to figure out the easiest way to edit the video without having to go through a bunch of programs and I'm Not on a budget so whats the best program option for me? Thanks and sorry for the ignorance!
Im looking to learn a professional program so any suggestions would be great thanks
Last edited by Baldrick; 10th Feb 2013 at 18:12. Reason: I didn't read the entire thread...:)
FCPX can edit AVCHD natively , FCP7 and below cannot (log & transfer, encode to prores)
Premiere Pro had native AVCHD support since CS4 -
Perfect, thanks poisondeathray, so do you have experience with either of those programs and prefer one to the other? I have read mixed reviews about both
Yes I've used both. They are both fine , each has it's own little quirks . FCPX is probably easier to use if you're new to editing . If you're on a Mac, get FCPX, Premiere doesn't run as well on a Mac compared to PC (has to do with drivers and graphics cards) . FCPX is less expensive as well
I primarily use Adobe because of the tight integration with other Adobe applications in the suite (photoshop, after effects, audition, encore) -
I've never experienced a crash with it (but then again I haven't used it much)
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 12:16 -
AVCHD - x264.exe has stopped working
By KlintIstwood in forum Blu-ray RippingReplies: 3Last Post: 27th Jun 2010, 09:17 -
Archiving and Working with AVCHD on a Mac
By monteric in forum MacReplies: 5Last Post: 10th Jan 2010, 13:56 -
Working with Mac Programs and HDV
By George Wallace in forum MacReplies: 8Last Post: 12th Feb 2009, 19:55 -
Cameras working through USB and Firewire on Mac ?
By Mister Paul in forum MacReplies: 7Last Post: 11th Jun 2008, 21:13
