When i open DVD2SVCD and the tab is "Conversion" a error pup up saying..
"The vStrip file does not exit!" ? what does that mean. I have the DVD in the DVD-rom...
what can be wrong?
PLZ HELP!
Him
If you do not use smartripper (or equivalent) to rip the dvd first on your harddrive youself you can use the vstrip function in dvd2svcd
It actually uses the program vstrip.exe for it
The error is telling you that it can't find vstrip in the dvd2svcd program folder
Look in \Program Files\DVD2SVD\
If you used the bundle setup it should be in \program files\dvd2svcd\vstrip
Try reinstalling the bundle version (and afterwards all the updates)
ps: in the sub folders you'll all the utils dvd2svd uses
good luck
Bart. -
Ahh 2nd try I tryed to install it . it worked=)
THX.....now its ripping off....dammm how long time does it take! it have been on for 13 houres!! -
I have 1333 Mhz athlon with 512 Meg SDRAM
a 100 minutes dvd using VBR mode with 4 passes takes 10-11 hours
(including audio/titles/muxing and the vcdimager)
btw i always use CCE (in stead of tmpgenc)
If you use CBR it will be 3 times faster (but not better unfortunately)
gr
Bart
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48
