I've been wondering what generation of tapes (I assume Betacam SP in most cases in the 90s) TV stations would typically use for the actual broadcasts. And if they did use second, third, forth, etc. generation tapes, how noticeable would the differences be between those and the master copies?
Noticeable.
Usually, they'd make the master and at least one backup copy. Then they'd make a couple of working dub tapes (usually from the master) which they'd re-use until they wore out. For commercials/psas they'd often put those on 3/4" U-matic instead of BetaSP. So the master usually only had 1 record pass & <10 play passes on it.
Scott -
So how many passes/years would it typically take before Beta SP showed signs of wear?
I don't remember. 25? 50? probably somewhere in between there, depending upon the quality of the tape and the state-of-repair of the deck(s) in use. Years? For storage, top quality tapes should last 25-50 years or more if well stored (assuming you still have a great quality deck with which to play them on). Combine use/passes & storage/time and I'd bet they wouldn't last that long.
2 TV's, one antenna ; different stations?!?!?!
By HDFreeV in forum DVB / IPTVReplies: 13Last Post: 2nd Feb 2010, 14:36 -
Remaning analog stations
By Darth Paris in forum DVB / IPTVReplies: 5Last Post: 4th Aug 2009, 15:31 -
Panasonic DMR-E80H not able to record sub stations
By chrisincent in forum Newbie / General discussionsReplies: 9Last Post: 15th Apr 2009, 13:57 -
How do analog repeater stations get their signal?
By cal_tony in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2009, 13:04 -
I want to record several TV stations at the same time ;-)) Is it possible?
By avchdbg in forum DVD & Blu-ray RecordersReplies: 2Last Post: 7th Oct 2008, 10:11
