Ive just changed my drive over to a 3D model and found it doesnt support HD DVD titles, luckily my old LG drive does, but the software doesnt work with Windows 7 anymore.
In this day and age does anyone know of a sure fire way to play HD DVD.. from DISC? Ive tried Total Media Theatre, as this is what used to work, version 3 wont start at all and version 6 plays the file with no audio at around fps (!!)
PowerDVD doesnt work either, says unsupported disc.
Help!
Results 1 to 9 of 9
Ancient versions of PowerDVD can do it, but...
I have no idea if those versions work under Win 7.
I don't remember which was the last version that did (you can search for this yourself easily enough).
Cyberlink will NOT sell you those versions of PowerDVD that supported HD DVD any more, so you will have to find them through "other channels". I'm not allowed to tell you what those "other channels" are but hopefully you are smart enough to figure that out.
That "3D capability" may be bs to drive up the price because regular BluRay drives on PCs will also work if you have the right CPU, video card and monitor. -
If it were me and I had a collection of HD-DVDs, I would do 2 things:
1. Buy BDs to replace them (might take a while)
2. In the meantime, rip+ demux (main movie only) + remux to M2TS +reauthor to BD-R.
The specs are close enough, you probably shouldn't have to lose any quality, either. I'm actually surprised there isn't already an all-in-one app that does this already.
BTW, this ought to have been done back in 2009, when it was clear HD-DVD was going away. Also, if you have trouble with player apps in Win7, you should dual-boot into XP (or use a VM of XP). -
multiAVCHD can do this, just rip the HDDVD_TS folder and import.Last edited by MOVIEGEEK; 7th Feb 2013 at 20:11.
I stand corrected: 2 very good HD-DVD -> BD conversion suggestions above...
Scott -
I did both.Originally Posted by cornucopia
I had 8 hd-dvd movies. I finally replaced the last of them recently. But I also ripped a few to h264/mkv to bide my time.
Thing is now you can get bluray movies at a really good price if you look hard enough. Also you can finally buy bluray movies used at good prices so I would look into that option first.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for all your suggestions though I did want to play from disc direct rather than rip and convert to make use of the drive. I managed to find an old version of Total Media Theatre V5.3.1.172 that plays them fine direct from DVD, so if anyone else is having issues, thats the version you need to get. Thansk again for all the responses, much appreciated.
What can I do with the 3D MP4 files from an Evo 3D?
By Tyler2000 in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2011, 17:49 -
Playing EVO files
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 5th Jan 2009, 03:15 -
How to play HD-DVD(RIPS), .evo files in MPC or MPCHC
By btvs2000 in forum Software PlayingReplies: 2Last Post: 23rd Sep 2008, 14:58 -
problems with EVO files
By deadrats in forum Blu-ray RippingReplies: 0Last Post: 6th Sep 2008, 23:57 -
HD-DVD video files (eg. EVO) - any plans to support?
By broaddd in forum ffmpegX general discussionReplies: 0Last Post: 29th Feb 2008, 19:49
