I have downloaded the movie Panic Room from iMesh, but something is wrong with it. It plays, but there is absolutely NO sound or picture. It is just all pitch black when I double clikc on the file. How can I fix this? Here is what the file name looks like:
panic.room.-telesync[2of2].asf[OK].avi
Same boat here buddy! I have tried every codec I can think of but it still doesn't work.
I also tried to rename it to different extensions such as asf, wmv, and mpg. None of it worked at all.
Sometimes when you download movies and other files they don't always work. This is not always your fault. The person who either ripped or put that on the net probably has some problems.
Try re-saving the file with VirtualDub software. Look at the CONVERT menu in this forum. I had the same problem and this has helped.
This person is telling you its "panic.room.-telesync[2of2].asf"panic.room.-telesync[2of2].asf[OK].avi
the .avi has been added so it shows up in the AVI list on a search.
If you want to convert ASF files use Vdub 1.3c
Apart from that make sure you have Windows media player 6 or above installed.
PS3 won't play some MP4 and AVI files
By jiggy in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Feb 2010, 20:22 -
AVI files won't play in anything but VLC
By zanos in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 22:07 -
Won't play whole downloaded movie.
By amyyo9 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Dec 2008, 00:20 -
Some WMV files won't stream, but play fine if downloaded
By DVantrease in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2008, 14:49 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 06:31
