hi
how can i convert flv to mp4 without re-encoding using ffmpeg ?
video infos
VIDEO
Format : VP6
Codec ID : 4
Duration : 59mn 38s
Bit rate : 800 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 15.000 fps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.174
Stream size : 341 MiB
AUDIO
Format : MPEG Audio
Format version : Version 2
Format profile : Layer 3
Codec ID : 2
Codec ID/Hint : MP3
Duration : 59mn 38s
Bit rate mode : Constant
Bit rate : 48.0 Kbps
Channel(s) : 1 channel
Sampling rate : 22.05 KHz
Compression mode : Lossy
Stream size : 20.5 MiB (10%)
thanks for help
I don't think you can put vp6 in the mp4 container....so you must reconvert.
h264/avc with the x264 encoder, http://ffmpeg.org/trac/ffmpeg/wiki/x264EncodingGuide
"%~dp0ffmpeg.exe" -y -i "%~dp0video.flv" -vcodec copy -acodec copy "%~dp0video.mp4"
General
Format : Flash Video
File size : 364 MiB
Duration : 49mn 24s
Overall bit rate : 1 030 Kbps
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 7
Duration : 49mn 24s
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : AAC
Format profile : HE-AAC / LC
Codec ID : 10
Duration : 49mn 24s
Channel(s) : 2 channels
Sampling rate : 44.1 KHz / 22.05 KHz
i'm trying to convert it to MP4 without re-encoding, after converting the video is ok but no audio
i'm using ffmpeg newest version
i also tried to demux it convert audio to MP3 and mux it but audio is always out of sync i'm using Yamb with newest version of MP4Box
please help
sorry for my englishLast edited by CristianoA; 21st Nov 2013 at 13:37.
FLV to MP4 conversion
By edong in forum Video ConversionReplies: 3Last Post: 10th Jul 2012, 21:50 -
FLV - MP4 - Join
By Simmons in forum Video ConversionReplies: 1Last Post: 13th May 2011, 07:54 -
FLV to MP4 help
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2009, 10:37 -
VOB2MPG... can it go to MP4/FLV?
By slanubis in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 21st May 2009, 12:23 -
mp4->avi->flv??
By graphictodd in forum ffmpegX general discussionReplies: 11Last Post: 23rd Oct 2008, 11:10
