Check under your system:extentions folder and make sure the following extentions are there.
Toast CD Reader
ToastVideoCDSupport.component <-- This one must be there!
Toast USB Support C
Toast USB Support B
Toast USB Support
Toast FireWire Support
If all of those are not there then you'll need to reinstall Toast.
Results 31 to 34 of 34
i have all these! what is going on? this is frustrating me
thank you very much for the help though, i appreciate it. what do u suggest? should i reinstall it anyways?
If I were you I would. It's obvious that something isn't working as it should with it, so reinstall Toast and reset and see if the option appears.
MAC DivX Author Equivalent?
By innovyse in forum Authoring (DVD)Replies: 4Last Post: 6th May 2011, 10:51 -
Submerge - Subtitling made easy in Mac OS
By devilcoelhodog in forum MacReplies: 0Last Post: 30th Nov 2008, 14:25 -
A good and easy conversion program for Mac
By slackeer in forum MacReplies: 2Last Post: 24th Jun 2008, 08:41 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
EASY DvD to Divx Ultra (with chapters)
By daisbrown0722 in forum DVD RippingReplies: 3Last Post: 16th Aug 2007, 20:26
