Hello everyone. I have been racking my brain for 3 hours trying to fix my problem. I have 12 video files from a recording in 1920x1080 resolution. And 2 are 1920x1004 (these were not full screen when others was all are avi format. I been trying to join all of them to make one large video file to eventually upload to youtube. But of course them being different resolutions it wont let me. I take the 2 files and added a border to make it 1920x1080 and it wont work. I take the 2 files and resize them but still no luck keeps giving me errors that they are different resolutions even when I change them. Im using avidemux and virtural dub (veedub64) and windows movie maker none work. I am an extreme novice to video editing but wanna learn. What can I do to fix this.
				Results 1 to 13 of 13
	tater259-in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time.And welcome to the forums. I think,therefore i am a hamster.
	Add all in freemake video converter, click join at top right, convert to a mp4 with h264.
 Ok below are the files that are 1920x1080 do you want me to post all 12 video info ?
 General
 Complete name : D:\Fraps\javaw 2013-02-01 19-50-34-78.avi
 Format : AVI
 File size : 3.91 GiB
 Duration : 3mn 1s
 Overall bit rate : 185 Mbps
 Video
 Format : Fraps
 Codec ID : FPS1
 Duration : 3mn 1s
 Bit rate : 184 Mbps
 Width : 1 920 pixels
 Height : 1 080 pixels
 Display aspect ratio : 16:9
 Frame rate : 30.000 fps
 Color space : YUV
 Bit depth : 8 bits
 Bits/(Pixel*Frame) : 2.951
 Stream size : 3.88 GiB (99%)
 Audio
 Format : PCM
 Format settings, Endianness : Little
 Format settings, Sign : Signed
 Codec ID : 1
 Duration : 3mn 1s
 Bit rate mode : Constant
 Bit rate : 1 411.2 Kbps
 Channel(s) : 2 channels
 Sampling rate : 44.1 KHz
 Bit depth : 16 bits
 Stream size : 30.5 MiB (1%)
 Interleave, duration : 997 ms (29.91 video frames)
 And here is the one with the 1920x1004
 General
 Complete name : D:\Fraps\javaw 2013-02-01 21-46-21-24.avi
 Format : AVI
 File size : 2.19 GiB
 Duration : 2mn 15s
 Overall bit rate : 139 Mbps
 Video
 Format : Fraps
 Codec ID : FPS1
 Duration : 2mn 15s
 Bit rate : 138 Mbps
 Height : 1 004 pixels
 Display aspect ratio : 1.912
 Color space : YUV
 Bit depth : 8 bits
 Bits/(Pixel*Frame) : 2.378
 Stream size : 2.17 GiB (99%)
 Audio
 Format : PCM
 Codec ID : 1
 Duration : 2mn 15s
 Bit depth : 16 bits
 Stream size : 22.8 MiB (1%)
 Interleave, duration : 997 ms (29.92 video frames)
	Since your source is Fraps and your targeting YouTube you'll need to re-encode all your 12 videos, ie not so much need to focus on the two that deviate since all may be join during re-encoding.
 You may try FormatFactory if you'r novice since it is fairly easy to use. Under "Advanced" in the left coulum select "Join" and have you output settings match those for YouTube
 http://support.google.com/youtube/bin/answer.py?hl=en&answer=1722171
 (I've try to see if YouTube migth have a tutorial on joining in FormatFactory but frankly didn't find the one I found recommendable. But perhaps you have more luck if you try yourself.)
	Why not resize them all to a smaller standard resolution, assuming they are all either NTSC or PAL, and then join these together
 It will take much less to upload and be easier for others to play from their end .... unless it MUST be 1920x1080
 No they dont have to be all that size its just my standard record size. But I have tried to resize them and it still rejects them. Gives me error different resolution size or different compression . The two files are not that very important just might leave them out ?? If its this trouble I will make sure to leave it all full screen and record it that way.
	AnyVideoConverter will do it. There's a free version. You just need to load and select them all, right click and choose "merge output". AVC's default settings will probably allow it to work fine (choose your desired output resolution from the list or type it in). If it gives you an error, go into it's options and change the ones for resizing video. I think checking both "fit to width" and "expand to frame size" will get it to resize them all to the same resolution by adding any black borders where necessary in order not to distort the picture.
 Just below the resize setting under the Video tab, there's one for audio sync. If you have sync problems, crank it up to maximum and choose "default" as the audio sync method in the section for setting up the audio encoder.
	What is the aversion to using a standard NLE? That would certainly do the trick.
  Video Files, join video_ts and flash videoBy Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2011, 07:45
  Easiest way to cut and join video filesBy zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 13:04
  Join Video FilesBy maxhugen in forum Newbie / General discussionsReplies: 4Last Post: 25th Nov 2009, 04:11
  Vdubmod, cannot join 2 video filesBy kidcash in forum EditingReplies: 7Last Post: 11th May 2008, 10:17
  Toast 8 - Can I join 2 avi files to make one video?By Ivor Bigone in forum MacReplies: 5Last Post: 13th Feb 2008, 10:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
