I have a HP 1360t and an AMD radeon 7570 videocard. It says that it can run multiple monitors, but I cant see my 2nd display. I have one connected to the DVI and the other is connected dvi to displayport adapter to displayport on pc. the displayport monitor is not being detected.
What We Do In Life, Echoes In Eternity....
Just hit win + P then chose extended and both monitors appeared. Issue is now that 2nd monitor is not outputting correctly. The screen has green all over it. it is dvi currently. If I plug in a vga cable with a dvi adapter all is good. So whicih do you think it is bad dvi cable or bad dvi port on monitor?
What We Do In Life, Echoes In Eternity.... -
only way to check is with a known good dvi cable. use one off a working computer of yours or borrow one from a friend.
Displayport to HDMI audio problem
By jimhoofd in forum AudioReplies: 3Last Post: 7th Sep 2012, 08:47 -
Camera through computer so I can view on my monitor when in video mode
By Orion1122 in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2010, 21:32 -
EasyCap Line In Not Plugged In?
By Zackth in forum Capturing and VCRReplies: 20Last Post: 20th Oct 2010, 11:50 -
Video panel lost on 2nd monitor on laptop VGA port
By jeth32 in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 20:08 -
Adding a 2nd Monitor
By Tafflad in forum ComputerReplies: 3Last Post: 4th Feb 2010, 10:11
