I started to rip my dvd's using DVD cloner then later I found DVDFab and started to use it since then. I ripped all of my dvd's to ISO and used the movie only option, then later I learned that if I converted the DVD to MKV I would reduce the size of the DVD. my problem is that I already converted all of the movies ripped by DVDFab to ISO with no issue, but the ones ripped with DVD Cloner does not show the correct length of the movie only 50 minutes out of 120, somehow DVD cloner fu&^ed the time of the movie even the players see the time wrong but play the movie to the end.
Does anybody knows if is even possible to fix or should I move on?
Thanks! The videocode worked, I tried your other suggestion but it didn't work. Thank you.
Makemkv doesn't reencode/shrink the file, so I don't think that's what the OP is looking for. I've found that handbrake or vidcoder (same encoder, different interface) have the best balance between power and ease of use.
There are a lot of good encoders recommended here that require real skills. Video encoding is pretty complex, and you can't simplify it all that much. Digital video is too hardware dependent for that.
DVD/ISO to MKV using ffmpeg?
By linux in forum DVD RippingReplies: 16Last Post: 6th Dec 2011, 16:10 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
MKV To VIDEO_TS / ISO / DVD
By Valentin in forum MacReplies: 1Last Post: 31st Aug 2010, 20:13 -
ripping DVD to ISO
By scarlac in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2009, 19:10 -
MKV to DVD but become ISO instead
By c1steady in forum Video ConversionReplies: 2Last Post: 24th Apr 2009, 02:14
