How to save it right way up?
Quicktime pro
Open the movie with QuickTime Player
Choose Show Movie Properties from the Window menu
Click on the video track, then click on the Visual Settings tab
Clip the button to rotate your video.
Save your movie. No reconverting required.
Or with free software:
Mpeg streamclip, http://gopro.com/support/articles/rotate-stream-clip (if you use the save as a mov you don't need to reconvert...but I don't know if it works with rotating)
Avidemux,under filters.
Freemake video converter, add video and double click on it, click on the rotate icon.
But you must then reconvert to a new format.Last edited by Baldrick; 1st Feb 2013 at 06:33.
Fixing audio in a clip taken by a mobile phone
By shorto in forum AudioReplies: 3Last Post: 23rd Jun 2011, 08:34 -
Wanna Play HD video Clip on my cell phone !
By augustya in forum Video ConversionReplies: 6Last Post: 3rd Oct 2010, 10:43 -
CONVERTING MPEG 4 TO MOV FILE, ONLY FIRST 30 SEC OF CLIP WORK,help please !
By Haymaker in forum Video ConversionReplies: 5Last Post: 11th Aug 2010, 18:14 -
Can't find a good program to convert .mov/.mp4/H.264/AVC watever video clip
By Nintendo Fan in forum Video ConversionReplies: 8Last Post: 21st Jan 2009, 19:28 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26
