Page 4 of 6
FirstFirst ... 2 3 4 5 6 LastLast
Results 91 to 120 of 179
    Sep 2015
    Atlanta, Georgia, USA
    Moet, any ideas on my video?
  2. Originally Posted by wb8nbs View Post
    PBS used RTMP last year. In 2013 they are using Adobe HDS streaming. This breaks up the video into hundreds of ten second files. There is a manifest file (.M3U8) file that lists all the (.TS) files that make up the video. You can find and copy the M3U8 URL by accessing the video in Firefox then before you click the forward button to start playing it, open a network debug window (Tools -> Web Developer -> Network). Click forward and then stop it as soon as it starts playing. You can then copy the URL from the Network window and paste the URL into ffmpeg or better avconv which understand the M3U8 format to download the stream. Example:
    avconv -i http://ga.video.cdn.pbs.org/cove2.0/woodwrights-shop/e7b30a81-e9b6-4679-b829-13ca12424...-hls-800k.m3u8 wows3301800k.mp4
    Disclaimer: this works in Ubuntu linux. It is probably the same in windows.
    I am very happy with this procedure. For those that consider this piracy (I don't), consider that on a slow DSL line like mine, the only way to see these videos in high definition is to download the stream and replay it from the hard drive. On line playback from PBS is awful especially during network busy times.
    Trying to get this video: http://www.pbs.org/wgbh/pages/frontline/sports/league-of-denial/the-frontline-intervie...-bennet-omalu/
    How I found the m3u8 file
    https://forum.videohelp.com/images/imgfiles/G52SsRl.png (chrome developer tools 'Network' tab, after hitting play, HTTP 200)
    Input
    avconv -i http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-64-2500k.m3u8 test.mp4
    Output
    me@vm-ubuntu:~$ avconv -i http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b 63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-64-2500k.m3u8 test.mp4
    avconv version 9.18-6:9.18-0ubuntu0.14.04.1, Copyright (c) 2000-2014 the Libav developers
      built on Mar 16 2015 13:19:10 with gcc 4.8 (Ubuntu 4.8.2-19ubuntu1)
    Format detected only with low score of 25, misdetection possible!
    [hls,applehttp @ 0x230b8e0] max_analyze_duration reached
    Input #0, hls,applehttp, from 'http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-64-2500k.m3u8':
      Duration: 00:54:44.00, bitrate: 0 kb/s
        Stream #0.0: Video: h264, 90k tbn
        Metadata:
          variant_bitrate : 560000
        Stream #0.1: Audio: aac, 0 channels, fltp
        Metadata:
        Stream #0.2: Video: h264, 90k tbn
        Metadata:
          variant_bitrate : 960000
        Stream #0.3: Audio: aac, 0 channels, fltp
        Metadata:
        Stream #0.4: Video: h264, 90k tbn
        Metadata:
          variant_bitrate : 1360000
        Stream #0.5: Audio: aac, 0 channels, fltp
        Metadata:
        Stream #0.6: Video: h264, 90k tbn
        Metadata:
          variant_bitrate : 2660000
        Stream #0.7: Audio: aac, 0 channels, fltp
        Metadata:
        Stream #0.8: Video: h264, 90k tbn
        Metadata:
          variant_bitrate : 206000
        Stream #0.9: Audio: aac, 0 channels, fltp
        Metadata:
        Stream #0.10: Audio: aac, 22050 Hz, stereo, fltp
        Metadata:
          variant_bitrate : 64000
        Stream #0.11: Video: mjpeg, yuvj420p, 320x480, 90k tbn
        Metadata:
    [libx264 @ 0x34d1520] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
    [libx264 @ 0x34d1520] profile High, level 2.1
    [libx264 @ 0x34d1520] 264 - core 142 r2389 956c8d8 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.25 aq=1:1.00
    encoder 'aac' is experimental and might produce bad results.
    Add '-strict experimental' if you want to use it.
    me@vm-ubuntu:~$
    Did it work? cant tell...
    me@vm-ubuntu:~$ ls -alh
    -rw-rw-r-- 1 me  me     0 Sep 18 20:13 test.mp4
    No it appears it did not work, 0 byte file... damn.
    If I replace the .m3u8 extension with .mp4, I get HTTP 403 Forbidden (Not Authorized). .m3u8 is the only file extension I can get a HTTP 200 on.
    The file contents look like this
    #EXTM3U
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=560000,CODECS="avc1.4d001f, mp4a.40.5",RESOLUTION=416x234
    omalumez-16x9-hls-400k.m3u8
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=960000,CODECS="avc1.4d001f, mp4a.40.5",RESOLUTION=640x360
    omalumez-16x9-hls-800k.m3u8
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=1360000,CODECS="avc1.4d001f, mp4a.40.5",RESOLUTION=854x480
    omalumez-16x9-hls-1200k.m3u8
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=2660000,CODECS="avc1.4d001f, mp4a.40.5",RESOLUTION=1280x720
    omalumez-16x9-hls-2500k.m3u8
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=206000,CODECS="avc1.4d001f, mp4a.40.5",RESOLUTION=320x180
    omalumez-16x9-hls-150k.m3u8
    #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=64000,CODECS="mp4a.40.5"
    omalumez-16x9-hls-64k.m3u8
    If I open one of the other .m3u8 files, ex: omalumez-16x9-hls-1200k.m3u8
    #EXTM3U
    #EXT-X-VERSION:3
    #EXT-X-PLAYLIST-TYPE:VOD
    #EXT-X-TARGETDURATION:10
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00001.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00002.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00003.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00004.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00005.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00006.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00007.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00008.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00009.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00010.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00011.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00012.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00013.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00014.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00015.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00016.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00017.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00018.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00019.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00020.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00021.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00022.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00023.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00024.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00025.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00026.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00027.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00028.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00029.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00030.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00031.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00032.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00033.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00034.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00035.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00036.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00037.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00038.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00039.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00040.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00041.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00042.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00043.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00044.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00045.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00046.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00047.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00048.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00049.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00050.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00051.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00052.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00053.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00054.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00055.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00056.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00057.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00058.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00059.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00060.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00061.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00062.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00063.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00064.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00065.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00066.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00067.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00068.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00069.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00070.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00071.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00072.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00073.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00074.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00075.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00076.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00077.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00078.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00079.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00080.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00081.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00082.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00083.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00084.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00085.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00086.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00087.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00088.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00089.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00090.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00091.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00092.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00093.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00094.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00095.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00096.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00097.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00098.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00099.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00100.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00101.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00102.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00103.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00104.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00105.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00106.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00107.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00108.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00109.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00110.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00111.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00112.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00113.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00114.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00115.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00116.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00117.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00118.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00119.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00120.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00121.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00122.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00123.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00124.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00125.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00126.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00127.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00128.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00129.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00130.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00131.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00132.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00133.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00134.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00135.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00136.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00137.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00138.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00139.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00140.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00141.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00142.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00143.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00144.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00145.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00146.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00147.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00148.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00149.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00150.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00151.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00152.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00153.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00154.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00155.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00156.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00157.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00158.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00159.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00160.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00161.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00162.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00163.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00164.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00165.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00166.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00167.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00168.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00169.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00170.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00171.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00172.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00173.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00174.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00175.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00176.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00177.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00178.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00179.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00180.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00181.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00182.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00183.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00184.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00185.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00186.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00187.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00188.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00189.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00190.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00191.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00192.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00193.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00194.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00195.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00196.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00197.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00198.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00199.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00200.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00201.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00202.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00203.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00204.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00205.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00206.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00207.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00208.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00209.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00210.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00211.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00212.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00213.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00214.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00215.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00216.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00217.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00218.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00219.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00220.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00221.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00222.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00223.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00224.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00225.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00226.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00227.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00228.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00229.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00230.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00231.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00232.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00233.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00234.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00235.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00236.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00237.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00238.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00239.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00240.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00241.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00242.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00243.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00244.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00245.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00246.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00247.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00248.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00249.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00250.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00251.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00252.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00253.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00254.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00255.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00256.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00257.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00258.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00259.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00260.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00261.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00262.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00263.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00264.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00265.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00266.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00267.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00268.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00269.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00270.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00271.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00272.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00273.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00274.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00275.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00276.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00277.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00278.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00279.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00280.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00281.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00282.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00283.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00284.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00285.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00286.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00287.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00288.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00289.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00290.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00291.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00292.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00293.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00294.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00295.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00296.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00297.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00298.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00299.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00300.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00301.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00302.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00303.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00304.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00305.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00306.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00307.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00308.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00309.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00310.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00311.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00312.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00313.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00314.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00315.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00316.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00317.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00318.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00319.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00320.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00321.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00322.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00323.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00324.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00325.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00326.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00327.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00328.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00329.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00330.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00331.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00332.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00333.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00334.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00335.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00336.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00337.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00338.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00339.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00340.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00341.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00342.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00343.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00344.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00345.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00346.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00347.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00348.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00349.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00350.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00351.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00352.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00353.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00354.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00355.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00356.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00357.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00358.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00359.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00360.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00361.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00362.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00363.ts
    #EXTINF:9.9766,
    omalumez-16x9-hls-1200k-00364.ts
    #EXTINF:8.9423,
    omalumez-16x9-hls-1200k-00365.ts
    #ZEN-TOTAL-DURATION:3640.4247
    #EXT-X-ENDLIST
    me@vm-ubuntu:~$ avconv -i http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b 63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8 asdf.mp4
    Input #0, hls,applehttp, from 'http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8':
      Duration: 00:54:44.00, start: 10.000000, bitrate: N/A
        Stream #0.0: Video: h264 (Main), yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
        Stream #0.1: Audio: aac, 44100 Hz, stereo, fltp
    [libx264 @ 0x10fa780] using SAR=1/1
    [libx264 @ 0x10fa780] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
    [libx264 @ 0x10fa780] profile High, level 3.1
    [libx264 @ 0x10fa780] 264 - core 142 r2389 956c8d8 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.25 aq=1:1.00
    me@vm-ubuntu:~$
    0 byte file again
    Any ideas?
  3. Originally Posted by Meruem View Post
    Input
    Output
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
    me@vm-ubuntu:~$
    Any ideas?
    hi
    direct link
    http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-mp4-2500k.mp4
    or format .ts
    livestreamer "hls://http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8" best -o video.ts
    ffmpeg -i "http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8"  -c copy video.ts
    avconv -i "http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8"  -c copy video.ts
    or format .mp4
    ffmpeg -i "http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8" -bsf:a aac_adtstoasc  -c copy video.mp4
    or
    avconv -i "http://ga.video.cdn.pbs.org/videos/frontline/a89d7494-7e08-4bc2-8b63-767108cb1caf/43334/hd-mezzanine-16x9/omalumez-16x9-hls-2500k.m3u8" -bsf:a aac_adtstoasc  -c copy video.mp4
  4. wow that was easy, thank you
    very helpful post
    Sep 2015
    Birmingham AL
    Would it be possible for someone to help me out with a link for this video? Highest quality if possible but anything would be helpful. My boss appears in the video and wants a copy.
    http://video.pbs.org/viralplayer/2365553777/
  6. Originally Posted by RansomSAG View Post
    hi
    direct link
    http://ga.video.cdn.pbs.org/videos/religion-and-ethics-newsweekly/8ffe7be4-7a40-49d1-b182-38b6a6cb4611/199236/hd-mezzanine-16x9/925f8afa_payday-lenders-cove-pbs-mezzanine-spec-16x9-mp4-2500k.mp4
    like this this post
    https://forum.videohelp.com/threads/374166-Download-Flash-Video-from-PBS
    Nov 2015
    714 S San Antonio St, Port Lavaca, TX, USA, 77979
    Trying to get these videos:
    video.klru.tv/video/2365592475/
    and
    video.ket.org/video/1459183868/
    help please
  9. Originally Posted by thegeet View Post
    and
    help please
    Direct download links for videos and captions:
    1.
    http://ga.video.cdn.pbs.org/videos/austin-city-limits/c1662742-3e51-4f16-92f2-fc3a2859...4-baseline.mp4
    http://ga.video.cdn.pbs.org/captions/austin-city-limits/c1662742-3e51-4f16-92f2-fc3a28...50_Encoded.srt
    2.
    http://urs.pbs.org/redirect/595c235574a8420fa953eb995bf9654d/
  10. Member Emeritus
    May 2014
    4500k and 6500k is available for newest videos.
    Nov 2015
    and
    help please
    1.
    2.
    Thank you so much
    Nov 2015
    The video info method worked better.
    Nov 2015
    Help I can't download any more:
    watch.thirteen.org/video/2330287477/
    video.kcts9.org/video/2365068345/
    help asap
  14. Originally Posted by thegeet View Post
    help asap
    hi
    http://ga.video.cdn.pbs.org/videos/thirteen-specials/af970c26-cef4-4870-8339-c16dbf1ccba1/107100/hd-mezzanine-16x9/fmml-000105-mlkjr2-stream-web-16x9.mp4
    http://ga.video.cdn.pbs.org/videos/kcts-9-documentaries/d0db4630-87ed-47f5-8e83-bc6312e6b5f3/37742/hd-mezzanine-16x9/latinos-master2-16x9-mp4-2500k.mp4
    Nov 2015
    help asap
    hi
    TNX very much
  16. Hi all...
    I have tried SEVERAL of the methods listed above to no avail. I would very much appreciate any help I can get downloading this video:
    http://video.pbs.org/video/2365596258/
    I would especially like it in HD or a higher quality, if I could get it. (I was at this concert, and would love to show it to my family.)
    Any assistance would be amazing! Thank you!
    Edit: I managed to get here, if this is helpful: http://player.pbs.org/portalplayer/2365596258/?uid=&clientId=310fcb44-9e9d-11e5-baa5-22000b8c0012
  17. Originally Posted by Skinnamirink View Post
    Hi all...
    hi
    http://ga.video.cdn.pbs.org/videos/lincoln-center/f021566a-b56b-4376-ad98-50824539382f/208480/hd-mezzanine-16x9/570c44b1_lvlc4006-16x9-mp4-2500k.mp4
  18. Originally Posted by biezom View Post
    Hi all...
    hi
    THANK YOU so incredibly much!!!!
    Nov 2015
    video.ket.org/video/2365622595/
    It asks me for a pass
  20. Originally Posted by thegeet View Post
    given below is code and captions:
    http://ga.video.cdn.pbs.org/videos/comment-kentucky/a02e01fd-99ee-4aa1-b934-c15b5068e9e6/214098/hd-mezzanine-16x9/0b2e8986_kcomm_004205_mezz_5000-16x9-mp4-2500k.mp4
    http://ga.video.cdn.pbs.org/captions/comment-kentucky/a02e01fd-99ee-4aa1-b934-c15b5068e9e6/captions/476364_Encoded.srt
  21. Hi, I am recently trying the methods of downloading the subtitles from PBS, the "videoInfo" way finding the captions seems not working.
    I have no problem getting the .m3u8 address and the .ts files, just the subtitles problem, I seem so far can't find a way to solve it.
  22. Member Emeritus
    May 2014
    videoInfo is still present. The server name has changed from video.pbs.org to player.pbs.org
  23. Member
    Aug 2002
    South Florida
    Use WM Capture. It gets them all.
  24. Originally Posted by ponens View Post
    Thanks so much, I've got it sorted out.
  25. Member
    Jan 2011
    Middle US
    I've been downloading the Time Scanner series. I've been able to get 2 of them just fine and have found the info on the 3rd, but I can't find the info on the other 3 since they have "expired". Using the videoInfo page I was able to download the subtitles from 2 of them. Since the subtitles are still there I thought that the videos probably are too. But I can't find them. The redirect from the videoInfo page responds "Gone Redirect is no longer available".
    I would appreciate any help in finding the URL's for downloading these.
    Thank you.
    The episodes I need help with are:
    Egyptian Pyramids
    http://www.pbs.org/video/2365280998/
    http://player.pbs.org/videoInfo//2365280998/
    St. Paul's Cathedral
    http://www.pbs.org/video/2365281660/
    http://player.pbs.org/videoInfo/2365281660/
    Petra
    I can't find any URL for it.
    PS: pones: Thanks for the new server name on where to find the videoInfo directory.
  26. I have found that after the PBS video has expired, if you have the correct URL download, you can still download the video. Since you have the subtitle URL, "maybe" ponens or biezom will help you find the video URL from the subtitle URL.
  27. Member
    Jan 2016
    Canada
    Hi,
    Looking for help downloading http://www.pbs.org/wgbh/pages/frontline/the-confessions/
    Also looking for help on how to learn to do this myself. Cheers
  28. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Originally Posted by khaldu106 View Post
    use youtube-dl or any of its gui's
    youtube-dl http://www.pbs.org/wgbh/pages/frontline/the-confessions/
    I love it when a plan comes together!
  29. Member
    Jan 2016
    Melbourne, Australia
    Hello,
    I've tried various methods shown in this thread for downloading from PBS with none of them working for me, so I'm wondering if someone could just get the 720p MP4 link to this video for me http://www.pbs.org/video/2365637124/
    Cheers
  30. Originally Posted by josho999 View Post
    Hello,
    Cheers
    hi
    http://ga.video.cdn.pbs.org/videos/austin-city-limits/c606f7f1-4249-4c1a-8c3c-9340c29f6e88/217960/hd-1080p-mezzanine-16x9/6ccbcfc9_aucl4108_r-16x9-mp4-2500k.mp4
