Friends
Is it just me or does the wizard in TMPEG set the KBPS to 2520 by default when selecting Super VCD?
I thought the SVCD has a lower KBPS?
Cheers
Pat
If you are referring to the max bitrate then no, in fact it can be higher. The svcd max video bitrate is 2600kbits per sec. The total combined bitrate (audio + video) is ~2.77mbits. So factor in audio and overhead data and 2520kbits is a pretty reasonable video max to encode with.
Thanks Adam
But why does my DVD player stutter when I encode at the TMPEG default rate 2520? and as soon as I lower the rate to 2200 it plays smoothly?
Cheers
Pat -
are you using a sony dvd player? try setting the audio to 128kbps if you're using 2520kbps video. 2500kbps video and 224 audio works too, so maybe you could use 2520 and 160 or 192 (i haven't tried)
Some dvd players have stricter limits than what the standard allows. Pioneer dvd players are known for having difficulty with video bitrates above ~2500kbits or so. A template is simply a suggested setting, nothing else. Ultimately all you can do is choose settings that work best on your dvd player.
Burning SVCD At 480 x 272, 1152 kbps ?
By Tham in forum Authoring (VCD/SVCD)Replies: 2Last Post: 16th Sep 2010, 15:21 -
128 kbps to 96 kbps MP3 - big difference?
By joshua4 in forum AudioReplies: 12Last Post: 24th Oct 2008, 15:11 -
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57 -
iPod classic limit for AAC NOT 160 kbps! Supports 320 kbps!
By FallenAngelII in forum AudioReplies: 1Last Post: 29th Dec 2007, 13:14 -
Convert .ac3 (384 Kbps) to Dolby 5.1 (448 Kbps) ????
By christopheramos in forum AudioReplies: 6Last Post: 11th Jul 2007, 01:35
