Good day all
I have a few old project files from Ulead Video Studio (a way old version), and am now trying to import those into Vegas Pro 10.
Does anyone know if this is possible? And if so, how?
Google has only turned up a mass of comparisons between the programs.
Thank you, in advance![]()
NLEs that "share" usually do so by importing/exporting their EDLs (timeline lowest common denominator). This used to be in the very basic form of a specifically formatted text file (Grass Valley spec, most common) of edit cut listings (hence the name, "edit decision list"). Newer, more advanced forms use something like OMF, AAF or MXF. QT Reference files could be considered a form of this also (they retain their track & timeline layout & original clip formats).
So, if UVS were to share, it would be in one of those ways. Vegas has, depending upon its version, had the capability to share EDLs, so it mainly would depend on UVS's capabilities (which I'm guessing are small).
SOS! Problem with VSP projects of Corel Pro X4 - sound disappears in MP4
By PhysioEmoDynamics in forum EditingReplies: 2Last Post: 12th Oct 2012, 13:11 -
Help me with a project. Convert 8mm film to DVD.
By flyin-lowe in forum Authoring (DVD)Replies: 5Last Post: 8th Oct 2010, 08:37 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
The "convert a single VOB file to a DVD" project!! :)
By djdust in forum Authoring (DVD)Replies: 42Last Post: 23rd Feb 2008, 07:49
