is there anything on pc or ipad where i can add a video ( its actually one of my own vids, but the only copy i have is downloaded off youtube)
its quite dark... i know if it were a photo it would be quite easy to make it a bit better with brightness/contrast etc etc
is there any cheap/free easy to use video editor that will allow me to do those sorts of things?![]()
You can use avidemux,
open video
under video choose a codec like mpeg4 avc
under filters->colors add the mplayer eq2 filter, adjust the brightnes and contrast(you will se a preview)
under audio choose copy
select output format mp4,mkv,avi, etc.
last save as video.mp4/avi
If avidemux fails/crashes you can try xmedia recode. Load video and under filters add the color correction filter.
If it also crashes then try video to video converter. I have not tried the filters though....
Other alternatives to also consider are Windows Live Movie Maker that comes with Windows 7 which has adjustable brightness, and VirtualDub which has adjustable brightness and contrast.
Looking for a basic, free, video editor
By granturissimus in forum EditingReplies: 6Last Post: 15th Dec 2012, 13:33 -
Looking for a FREE Video Editor that does PIP
By Talgon in forum EditingReplies: 8Last Post: 22nd Aug 2012, 23:53 -
Best Free Video Editor
By Spiralagnus in forum Newbie / General discussionsReplies: 26Last Post: 27th Jul 2011, 19:42 -
Free video editor
By jazzygirl in forum Video ConversionReplies: 1Last Post: 16th Jul 2011, 01:54 -
Need info on the best free video editor
By garrettstuff in forum EditingReplies: 8Last Post: 6th Jul 2011, 17:44
