This was weird. To me, at least. I imported all my files, sync'd them all up, went into multicam mode and did all that fun stuff where you can click on your source and create your "mix" on the fly. And then I went back and watched it and put in a few transitions and got to a spot where I realized I cut from one source to another a little too soon. So I tried to go back and change the cut. Well, I lost ALL my transitions, and I lost all my mix from that point on. So, I still see the cuts, but only one source is active from that point on. How do I manually choose which cut (or "take") should be the active one at a given point?? I'm attaching a pic of my screen, you'll see the cuts but only one track shows as active.
	Turn it off (Multicam), then normal editing resumes. Also, you can CTRL-Z back.
	When in normal editing, how do you select which track is the active track at a given point?
  Multicam; differend sourcesBy shorto in forum EditingReplies: 0Last Post: 27th Jan 2013, 05:25
  vegas pro11 multicam editing woesBy aedipuss in forum EditingReplies: 19Last Post: 22nd Jun 2012, 01:11
  How can insert a video in timeline between other video files with Vegas ProBy siopilos in forum EditingReplies: 2Last Post: 15th Jun 2011, 17:53
  Seeing what looks like one video over another in Vegas Pro???By tonyp2 in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:36
  Vegas 8 multicam - Keep video effects intactBy stantheman1976 in forum EditingReplies: 5Last Post: 22nd Jan 2009, 13:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
