Hey guys, I need help fixing my MPC player settings or more. Would usually ask my friend for technical stuff, but he's far out in Japan until September, so he can't do jack to help right now. I'm trying to figure this out myself now, but need assistance.
Apparently I tried out a Wireless VGA stick, and it seems to have messed everything up. It's called the Vianect Devolo (DO NOT BUY), and it's crap. The software it came with messed up all my settings, or codecs, whatever it is, and video playback above 720p now stutters like a b***h.
I'll post the video details here so we might find a crossreference to what exactly is wrong.
Need to find where I can extract a list of all my settings so I can actually show you a status of the MPC settings, where do I find that?HTML Code:Format: Matroska File size: 5.67 GiB Duration: 1h 54mn Overall bit rate: 7 103 Kbps Movie name: (removed for now, not really important) Encoded date: UTC 2010-03-15 19:44:11 Writing application: [url=https://www.videohelp.com/tools/MKVtoolnix]mkvmerge[/url] v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17 Writing library: libebml v0.7.9 + libmatroska v0.8.1 Cover: Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes Video ID: 1 Format: AVC Format/Info: Advanced Video Codec Format profile: High@L5.1 Format settings, CABAC: Yes Format settings, ReFrames: 16 frames Muxing mode: Container profile=Unknown@5.1 Codec ID: V_MPEG4/ISO/AVC Duration: 1h 54mn Width: 1 920 pixels Height: 1 080 pixels Display aspect ratio: 16:9 Frame rate: 23.976 fps Color space: YUV Chroma subsampling: 4:2:0 Bit depth: 8 bits Scan type: Progressive Title: Commie Writing library: x264 core 88 r1471 1144615 Encoding settings: cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80 Language: Japanese Audio #1 ID: 2 Format: FLAC Format/Info: Free Lossless Audio Codec Codec ID: A_FLAC Duration: 1h 54mn Bit rate mode: Variable Channel(s): 6 channels Sampling rate: 48.0 KHz Bit depth: 16 bits Title: 5.1 Lossless Writing library: libFLAC 1.2.1 (UTC 2007-09-17) Language: Japanese Audio #2 ID: 3 Format: AC-3 Format/Info: Audio Coding 3 Mode extension: CM (complete main) Codec ID: A_AC3 Duration: 1h 54mn Bit rate mode: Constant Bit rate: 640 Kbps Channel(s): 2 channels Channel positions: Front: L R Sampling rate: 48.0 KHz Bit depth: 16 bits Stream size: 523 MiB (9%) Title: Commentary Language: Japanese Text #1 ID: 4 Format: ASS Codec ID: S_TEXT/ASS Codec ID/Info: Advanced [url=https://www.videohelp.com/tools/Sub-Station-Alpha]Sub Station Alpha[/url] Title: UTW-TMD Styled Subtitles Language: English Text #2 ID: 5 Format: ASS Codec ID: S_TEXT/ASS Codec ID/Info: Advanced Sub Station Alpha Title: UTW-TMD Hard Core Typesetting Language: English Text #3 ID: 6 Format: ASS Codec ID: S_TEXT/ASS Codec ID/Info: Advanced Sub Station Alpha Title: UTW-TMD Unstyled Subtitles Language: English Menu 00:00:00.000 : en:00:00:00.000 00:00:49.049 : en:00:00:49.049 00:05:28.537 : en:00:05:28.537 00:09:51.549 : en:00:09:51.549 00:14:44.717 : en:00:14:44.717 00:17:40.184 : en:00:17:40.184 00:19:39.261 : en:00:19:39.261 00:22:59.253 : en:00:22:59.253 00:24:34.056 : en:00:24:34.056 00:28:42.721 : en:00:28:42.721 00:31:23.965 : en:00:31:23.965 00:34:00.747 : en:00:34:00.747 00:38:04.991 : en:00:38:04.991 00:43:12.757 : en:00:43:12.757 00:47:35.227 : en:00:47:35.227 00:53:39.133 : en:00:53:39.133 00:56:57.956 : en:00:56:57.956 00:58:29.131 : en:00:58:29.131 01:01:27.350 : en:01:01:27.350 01:03:58.251 : en:01:03:58.251 01:10:04.492 : en:01:10:04.492 01:14:55.241 : en:01:14:55.241 01:18:52.519 : en:01:18:52.519 01:21:52.366 : en:01:21:52.366 01:24:52.504 : en:01:24:52.504 01:29:37.622 : en:01:29:37.622 01:31:04.668 : en:01:31:04.668 01:33:55.880 : en:01:33:55.880 01:40:06.209 : en:01:40:06.209 01:46:11.365 : en:01:46:11.365 01:48:59.908 : en:01:48:59.908
I have MPC with Shark007's Codecs x64 and reinstalled DivX, to no avail, DXVA does not show up under external filters, do not know if it is important.
Closed Thread
Never Change A Running System
By Klappstuhl in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2013, 06:32 -
System Overhead while running DVDFlick
By harishkumar09 in forum Authoring (DVD)Replies: 8Last Post: 4th Jan 2013, 01:15 -
Change Icon In System Tray?
By DarrellS in forum ComputerReplies: 7Last Post: 9th Feb 2011, 00:36 -
question about PC running hot -room humidity and water coolance system
By mazinz in forum ComputerReplies: 7Last Post: 29th Apr 2009, 18:27 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59
