Hey guys, I need help fixing my MPC player settings or more. Would usually ask my friend for technical stuff, but he's far out in Japan until September, so he can't do jack to help right now. I'm trying to figure this out myself now, but need assistance.
Apparently I tried out a Wireless VGA stick, and it seems to have messed everything up. It's called the Vianect Devolo (DO NOT BUY), and it's crap. The software it came with messed up all my settings, or codecs, whatever it is, and video playback above 720p now stutters like a b***h.
I'll post the video details here so we might find a crossreference to what exactly is wrong.
Need to find where I can extract a list of all my settings so I can actually show you a status of the MPC settings, where do I find that?Format : Matroska
File size : 5.67 GiB
Duration : 1h 54mn
Overall bit rate : 7 103 Kbps
Movie name : Summer Wars
Encoded date : UTC 2010-03-15 19:44:11
Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Cover : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 54mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : Commie
Writing library : x264 core 88 r1471 1144615
Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
Language : Japanese
Audio #1
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 1h 54mn
Bit rate mode : Variable
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Title : 5.1 Lossless
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 54mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 523 MiB (9%)
Title : Commentary
Language : Japanese
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Title : UTW-TMD Styled Subtitles
Language : English
Text #2
Format : ASS
Title : UTW-TMD Hard Core Typesetting
Language : English
Text #3
Format : ASS
Title : UTW-TMD Unstyled Subtitles
Language : English
Menu
00:00:00.000 : en:00:00:00.000
00:00:49.049 : en:00:00:49.049
00:05:28.537 : en:00:05:28.537
00:09:51.549 : en:00:09:51.549
00:14:44.717 : en:00:14:44.717
00:17:40.184 : en:00:17:40.184
00:19:39.261 : en:00:19:39.261
00:22:59.253 : en:00:22:59.253
00:24:34.056 : en:00:24:34.056
00:28:42.721 : en:00:28:42.721
00:31:23.965 : en:00:31:23.965
00:34:00.747 : en:00:34:00.747
00:38:04.991 : en:00:38:04.991
00:43:12.757 : en:00:43:12.757
00:47:35.227 : en:00:47:35.227
00:53:39.133 : en:00:53:39.133
00:56:57.956 : en:00:56:57.956
00:58:29.131 : en:00:58:29.131
01:01:27.350 : en:01:01:27.350
01:03:58.251 : en:01:03:58.251
01:10:04.492 : en:01:10:04.492
01:14:55.241 : en:01:14:55.241
01:18:52.519 : en:01:18:52.519
01:21:52.366 : en:01:21:52.366
01:24:52.504 : en:01:24:52.504
01:29:37.622 : en:01:29:37.622
01:31:04.668 : en:01:31:04.668
01:33:55.880 : en:01:33:55.880
01:40:06.209 : en:01:40:06.209
01:46:11.365 : en:01:46:11.365
01:48:59.908 : en:01:48:59.908
I have MPC with Shark007's Codecs x64 and reinstalled DivX, to no avail, DXVA does not show up under external filters, do not know if it is important.
EDIT: Deinstalled Codec & MPC, reinstalled MPC-HC x64 1.6.5.6366 (744df1c) & Shark007 Codecs x32 & x64 v3.9.7
The previous video works now, the next one doesn't. I don't understand my PC anymore.
General
Unique ID: 243363731232592325449052043044056128536
(0xB716265516F61CCF9EE87E24F982DC18)
Complete name : (removed)
Format: Matroska
Format version: Version 2
File size: 7.91
GiB Duration: 1h 42mn
Overall bit rate mode: Variable
Overall bit rate: 11.0 Mbps
Encoded date: UTC 2011-07-07 10:30:35
Writing application: mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library: libebml v1.2.0 + libmatroska v1.1.0
Video ID: 1
Format: AVC
Format/Info: Advanced Video Codec
Format profile: High@L4.1
Format settings, CABAC: Yes
Format settings, ReFrames: 4 frames
Codec ID: V_MPEG4/ISO/AVC
Duration: 1h 42mn
Bit rate mode: Variable
Bit rate: 9 175 Kbps
Maximum bit rate: 40.0
Mbps Width: 1 920 pixels
Height: 794 pixels
Display aspect ratio: 2.40:1
Frame rate mode: Constant
Frame rate: 23.976 fps
Color space: YUV
Chroma subsampling: 4:2:0
Bit depth: 8 bits
Scan type: Progressive
Bits/(Pixel*Frame): 0.251
Stream size: 6.43 GiB
(81%)
Title: (removed)
Writing library: x264 core 115 r2008 4c552d8
Encoding settings: cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1
/ psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 /
threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 /
bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 /
b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=1 / keyint=240 /
keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass /
mbtree=1 / bitrate=9175 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 /
qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=40000 /
nal_hrd=vbr / ip_ratio=1.40 /
aq=1:1.00
Language: Italian
Default: Yes
Forced: No
Audio
#1
Format: AC-3
Format/Info: Audio Coding 3
Mode extension: CM (complete main)
Format settings, Endianness: Big Codec
Duration: 1h 42mn
Bit rate mode: Constant
Bit rate: 640
Kbps Channel(s): 6 channels
Channel positions: Front: L C R, Side: L R, LFE
Sampling rate: 48.0 KHz
Bit depth: 16 bits
Compression mode: Lossy
Stream size: 470 MiB (6%)
Title: Ita Ac3
5.1Language: Italian
Default: Yes
Forced: No
Audio #2
Format: AC-3
Duration: 1h 42mn
Bit rate: 640 Kbps
Bit depth: 16 bits
Stream size : 470 MiB (6%)
Title: Eng Ac3
5.1 Language: English
Default: No
Forced: No
Audio #3
Format: AC-3
Duration: 1h 42mn
Bit rate: 576 Kbps
Bit depth: 16 bits
Stream size: 423 MiB (5%)
Title: Esp Ac3 5.1
Language: Spanish
Default: No
Forced: No
While playing the video in MPC right click on the player window and hover over Filters. That will show you what filters are being used to play the video. Selecting a filter will bring up a dialog box where you may be able to change options.
In MPC select View -> Options -> Internal Filters. Enable or disable Source Filters or Transform Filters as necessary.
Also check View -> Options -> Playback -> Output. Try the different DirectShow renders. Especially the EVR renderers.
If you're not using MPCHC you should switch to that. It's much more up to date.
System Overhead while running DVDFlick
By harishkumar09 in forum Authoring (DVD)Replies: 8Last Post: 4th Jan 2013, 00:15 -
Change Icon In System Tray?
By DarrellS in forum ComputerReplies: 7Last Post: 8th Feb 2011, 23:36 -
Trying to change aspect ratio from 19:9 to 4:4 for mp4 iPod Docking System
By llee782 in forum MacReplies: 3Last Post: 22nd Jun 2009, 17:49 -
question about PC running hot -room humidity and water coolance system
By mazinz in forum ComputerReplies: 7Last Post: 29th Apr 2009, 17:27 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59
