Hi all, I have encountered a problem as follow,
I have recorded a video by using a webcam recorder and save it as an avi.file.
However, I can't open it. I have tried different kinds of software, such as media player classic etc, it doesn't work as well.
I get the following message when I open it with GOM Player:
The following is the binary information of the file failed to play.
BINARY INFO
FileName : 2013-1-27 02.07.16.AVI
Header Data :
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
What can I do ? Thanks very much for your help.
Results 1 to 10 of 10
It looks like it doesn't contain anything at all.
Try open it with mediainfo and see what it says.
Try also play with VLC Media Player. -
delete it. it's a completely empty file.
Thanks for helping. I have downloaded mediainfo and the result is as follow:
General
Count : 280
StreamCount : 1
StreamKind : General
StreamKind/String : General
StreamKindID : 0
Inform : CompleteName : E:\2013-1-27 02.07.16.AVI
FileSize/String : 16.0 GiB
FolderName : E:
FileExtension : avi
FileSize : 17226502144
FileSize/String1 : 16 GiB
FileSize/String2 : 16 GiB
FileSize/String3 : 16.0 GiB
FileSize/String4 : 16.04 GiB
StreamSize : 17226502144
StreamSize/String : 16.0 GiB (100%)
StreamSize/String1 : 16 GiB
StreamSize/String2 : 16 GiB
StreamSize/String3 : 16.0 GiB
StreamSize/String4 : 16.04 GiB
StreamSize/String5 : 16.0 GiB (100%)
StreamSize_Proportion : 1.00000
Is there any ways for me to recover the file ? I have tried open the file with VLC but it doesn't seem work too ....Last edited by denden1231; 26th Jan 2013 at 19:08.
VirtualDub or VirtualDubMod will try to repair AVI files if need be when you open them, although I think yours is beyond that. If successful though, you can resave it as a fresh AVI using DirectStreamCopy as the video compression method (no re-encoding). It can't hurt to try.
Thanks for answering. I have tried to use VirtualDub to repair the file, however when I tried to open the file in VirtualDub, a dialog box poped up with message: The file "E:\2013-1-27 02.07.16. AVI" is of an unknown or unsupported file type" ;(
Besides, for VirtualDubMod, it also fails to recover my file. A dialog box with message "Cannot detect file type of "E:\2013-1-27 02.07.16.AVI" is poped up when I tried to open the file. ;(
What should I do ? ...
Anyway, thanks for your reply. -
It's probably empty as aedipuss says because it's only zeros in the gom player header preview.
You could also open the avi with a hex editor to check the entire file, like http://download.cnet.com/HxD-Hex-Editor/3000-2352_4-10891068.html .If it's only zeros/dots in the hex editor it's empty. -
Baldrick, thanks for you reply!
I have checked the file with hex editor. The file is not only zeros/dots. The first 1500 row is zeros and dots, while the rest are not. So is it possible for me to cut the first 1500 row's zeros/dots ? so that I can recover my video ?
Thanks very much -
Re MediaInfo if you set the view to Text you will get more meaningful information.
Like this as an example
Code:Format : AVI Format/Info : Audio Video Interleave File size : 856 MiB Duration : 1h 21mn Overall bit rate : 1 469 Kbps Writing application : Lavf51.12.1 Video ID : 0 Format : xvid Codec ID : xvid Duration : 1h 21mn Bit rate : 1 200 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5:4 Frame rate : 25.000 fps Standard : PAL Bits/(Pixel*Frame) : 0.116 Stream size : 699 MiB (82%) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Codec ID : 55 Codec ID/Hint : MP3 Duration : 1h 21mn Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 149 MiB (17%) Alignment : Aligned on interleaves Interleave, duration : 24 ms (0.60 video frame) Interleave, preload duration : 24 ms Writing library : LAME3.97
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Avi file won't play
By billyman115 in forum Software PlayingReplies: 3Last Post: 20th Jan 2012, 16:04 -
Can't play AVI file
By JohnC1726 in forum RestorationReplies: 9Last Post: 14th Jan 2010, 09:47 -
I can't play a big avi file
By Xp4nd3r in forum Newbie / General discussionsReplies: 6Last Post: 20th Feb 2009, 07:29 -
Which codec to play avi file?
By roblobster in forum Newbie / General discussionsReplies: 6Last Post: 27th Jan 2009, 22:34 -
Corrupted AVI File. How Can I Play It?
By GangstaRap in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2008, 17:23
