Hello Everybody
Could someone tell me what CVD is????
I have seen that some DVD-players can take it, but what is it exactly????
CVD: China Video Disc. It is china's SVCD. In a way, SVCD is the western answer to that format. The only difference is the resolution: CVD is 352 X 576 when SVCD is 480 X 576. All SVCD players has to be compatible with CVD. China is a huge market you know...
There are some benefits for creating CVD and not SVCD: First of all, you can fit more per CD. Then, is the resolution: 480 X 576 ain't DVD compatible, when 352 X 576 is. This called D2 Resolution (some US friends of the forum call it half D1), fully supported by DVD-Video. It is the second real legal resolution of DVD-video we know. It is ideal for SVHS to mpeg 2 convertion. With an average bitrate of 3000, you get the quality similar to DVD - D1, at the half file size. An average bitrate about 1900 also create fair results, most of the times enough for movies.
You 'll not see any difference between the quality of CVD and SVCD. Horizontal lines don't count the way Vertical ones do!
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
