Results 1 to 9 of 9
  1. Assume I want (have to) re-encode (wiht MP3) the audio part of an original video. I can do it by flags like:
    ffmpeg -i .... -acodec mp3 -ab 128 ...
    or
    ffmpeg -i .... libmp3lame -aq 5 ....
    Ok, but this way I define the output quality independently from the existing audio quality.
    Is there a way to tell ffmpeg:
    "Hey ffmpeg, I don't know the exact audio source quality but find out by yourself and auto-adjust
    the target audio quality by yourself so that the quality loss is minimal" ?
    As far as I know there was a flag like "-sameq" in the past but this seems to be deprecated/removed in newer versions of ffmpeg.
    Is there a corresponding new flag for that?
    Is there a corresponding new flag for video part (Xvid codec) as well?
    Thank you
    Peter
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    May not be what you mean, but you can use the "copy" codec to have ffmpeg extract the audio from a video, basically just demuxing it, no conversion made.
    e.g., (assuming the video uses AAC audio)
    ffmpeg -i %1 -vn -acodec copy %1.aac
    But if you're changing the audio codec, you do need to specify a bitrate, as there isn't a universal rule for equivalent bitrates in different codecs.
    Sameq was just same quantizers if you converted between same codecs, see http://ffmpeg.org/trac/ffmpeg/wiki/Option%20'-sameq'%20does%20NOT%20mean%20'same%20quality''
    Mar 2013
    Slovakia, Modra
    I did ffmpeg -i Ramble_On__It_Might_Get_Loud.flv -vn -acodec Ramble_On__It_Might_Get_Loud.mp3 and it says I must specify at least one output file???? when I put copy after -acodec terminal says: Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You specify the audio codec by: "-acodec XXX".
    In your original line line the XXX is "Ramble_On__It_Might_Get_Loud.mp3" which of course isn't a codec, and so then there is no output file either.
    -acodec copy
    is the same as the input.
    Are you sure your flv is MP3 audio?
    A lot are AAC.
    Do just
    and it will tell you what video and audio codecs the file has.
    Mar 2013
    Slovakia, Modra
    yeah thanks it's aac, so i'll convert it into aac but is there an option to convert aac-mp3 with "same" bitrate or like the mp3 eqivalent of particular aac
    Mar 2013
    Slovakia, Modra
    I did ffmpeg -i $f -acodec copy $f.mp3 , it creates file but that file won't play and amarok says it's null....
    Mar 2013
    Slovakia, Modra
    cd /media/data/robert/Videos/nekonvert
    while IFS= read -r line; do  ## line is stored in $line .. len nepozna -r =recursive
    fname="${line%.*}"
    e="${line##*.}" #extension
    echo "$fname"
    echo "$e"
    case "$e" in
    mp4)
    ffmpeg -i $line -vn -acodec copy $fname.mp3
    #ffmpeg -i $line -vn -acodec $fname.mp3
    ;;   #konci moznost pre mp4
    flv)
    ffmpeg -i $line -vn -acodec copy $fname.aac
    #ffmpeg -i $line -vn -acodec $fname.aac
    esac #case ends
    done < /media/data/robert/Videos/nekonvert/obsah.txt
    it creates an mp3/aac file with same name but won't play and amarok says it's null. I read output of that script and files were converting it looks OK. Original files are in nekonvert folder, and the fielnames are in obsah.txt
  9. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I think you're using a Unix shell script, so I can't test it directly.
    But it looks like it assumes that mp4 all have mp3 audio, which is not true.
    That will create a file with the extension mp3, but won't make any conversion, it will just copy the original codec. So if it wasn't already MP3, it won't work.
