  1. Im trying to convert divx to Mpeg 1, but the sound is in ac3 - I know what programs to use to convert the ac3, just dont know how to get the .ac3 from the .avi - Any help appriciated,
    Cheers
    lzrdisc@hotmail.com
  2. Banned
    Jun 2001
    UK
    Hi
    You wont need to extract the audio unless there is a lip sync or some other reason. Just install the AC3 codec. I believe the Nimo Codec Pack includes this. Also WinDVD has it. Then load TMPGEnc and before you load the movie, change the priority of the direct show reader priority to 1 or 2.
  3. where is that direct show reader in tmpgenc???????????????????????????????
    Feb 2002
    Czech Republic
    I am using VirtualDub > Audio > DirectStream Copy > Save as Wav
    this wav is unusable in almost all programs...
    so i wrote little program which cuts off WAV head and makes true AC3 stream...
    Than i use BeSweet GUI (tooLame)
    If anyone would like this program, than send me email... to
    toz@centrum.cz
    But only today... (to prevent to much emails)
    Than i maybe put this little tool to web...
  5. vob2audio contains a little prog called Wavemp3 which adds a header that Virtualdub can accept......
  6. Banned
    Jun 2001
    UK
    Options > environmental settings > VFAPI plug-in > Right click select higher priority
