Is there a way to let ffmpeg show the used audio and video codec inside a (.mp4) video file?
I assume there are commands like:
ffmpeg -i myvideo.mp4 -showvideocodec
and
ffmpeg -i myvideo.mp4 -showaudiocodec
How is the corresponding command syntax in detail?
simply call:
and ffmpeg should output something like:Code:ffmpeg -i myvideo.mp4
which is the same output you get when calling 'ffprobe myvideo.mp4'.Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'h:\TestClips&Co\chapter.mp4': Metadata: major_brand : avc1 minor_version : 0 compatible_brands: isomavc1 creation_time : 2009-06-30 06:08:14 Duration: 00:00:17.16, start: 0.000000, bitrate: 934 kb/s Chapter #0.0: start 0.000000, end 3.000000 Metadata: title : Zero Chapter #0.1: start 3.000000, end 5.000000 Metadata: title : Three Chapter #0.2: start 5.000000, end 7.000000 Metadata: title : Five Chapter #0.3: start 7.000000, end 11.000000 Metadata: title : Seven Chapter #0.4: start 11.000000, end 17.000000 Metadata: title : Eleven Chapter #0.5: start 17.000000, end 17.160000 Metadata: title : Seventeen Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 640x352 [SAR 1:1 DAR 20:11], 801 kb/s, 25 fps, 25 tbr, 25k tbn, 50 tbc Metadata: creation_time : 2009-06-30 06:08:14 handler_name : GPAC ISO Video Handler Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 130 kb/s Metadata: creation_time : 2009-06-30 06:08:14 handler_name : GPAC ISO Audio Handler
If you need more details/control better use MediaInfos CLI version.
Cu Selur
Ps.: there's no syntax/call to get just audio/video/chapter/subtitle infos from a file using ffmpeg.
how to enhance audio in an mp4 / avi video file
By antinikhil in forum Video ConversionReplies: 6Last Post: 15th Jul 2012, 02:00 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 07:01 -
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 10:13 -
Merging audio file and video file using ffmpeg
By suresh3484 in forum ffmpegX general discussionReplies: 3Last Post: 17th Aug 2008, 22:20 -
By suresh3484 in forum ffmpegX general discussionReplies: 0Last Post: 27th May 2008, 04:05
