Hello. VLC is my general all purpose media player.
I recently took a file that has many audio tracks, which plays perfectly in VLC, and removed about 10 audio tracks and then inserted 3 new correct tracks via MKVToolNix.
After the new file is complete VLC can play the file fine but if I try to fast forward at a high speed or jump anywhere in the file more than a minute or two at a time the file will either not play or take a very long time to begin playing again.
This does not happen with the same file in PotPlayer or XBMC.
Any ideas?
There is a known compability issue with vlc and mkvtoolnix 6.0 . Use older version or wait until it gets fixed
Yes, but I would go back a few versions of mkvtoolnix to ensure compatibility - Other software and/or hardware might have problems as well. You're going to have headaches down the road sorting everything out
As long as the current version doesn't cause problems with any standalone/hardware players you might be using, which it shouldn't.... software will be updated sooner or later, and as far as I know it's only VLC which has problems because it doesn't follow the rules for MKV quite as exactly as it should.
If you do go back to an older version (I think 5.9.0 would be fine) just make sure you go into it's options and check the "disable header removal compression" box if it's not already checked, or that'll probably give you grief sometime down the line. The setting has been removed in version 6 as MKVMergeGUI no longer uses header removal compression. Thankfully.....
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 22:34 -
Easycap Lag
By swiftflikk in forum Portable VideoReplies: 14Last Post: 16th Jul 2012, 01:50 -
Lag when watching HD
By jester5120 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 18:43 -
Video Lag....HELP
By chump0 in forum Newbie / General discussionsReplies: 2Last Post: 14th Apr 2009, 20:21 -
when i try to play a video in vlc player it starts to lag
By icedemon in forum Software PlayingReplies: 4Last Post: 17th Aug 2008, 21:33
