Well, I've tried many guides in the past to capture to Divx (I have no intention of making this video a VCD) with my capture card, and I've always had dropped frames like crazy.
Seeing as I reformatted yesterday, I followed the instructions here to the letter and in a few seconds got more than a 150 dropped frames. This was pretty amazing seeing as previously I got about 1 dropped frame per second, which itself is pretty bad.
My system is:
Intel P4 1.8ghz CPU
Asus P4T mobo (Intel)
256MB RDRAM
WindowsXP OS
GeForce256 DDR video card
Hauppage WinTV PCI (using manufactuer's WindowsXP drivers)
40GB Seagate (ST340016A)
Now I have no clue how I'm supposed to fix this. :( Any advice would be appreciated.
Have you enabled direct memory access for your hard drive
Craig -
I'm using WindowsXP, and so I don't know how to do that, as it's changed from 9x. I assumed XP enabled it automatically though.
Hi, first post. :D
You set DMA mode in Device Manager, on the IDE Controller. (primary and secondary IDE Channel)
On my system DMA was enabled by default.
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Pryo DV capture adds tons of blank frames in between dropped ones.
By Knightmessenger in forum Capturing and VCRReplies: 11Last Post: 18th Jul 2009, 16:08 -
Tons of Video out there
By skybird in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2007, 09:32 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59 -
How to copy a CD w/tons of mp3 tunes to another CD??
By rbatty11 in forum AudioReplies: 6Last Post: 19th Jun 2007, 19:30
