Not sure if this is the proper place, but... I have scanned thousands of frames of 8MM film to a series of still photos. I now want to turn it back into digital video. Can anyone suggest software that will allow you to convert still frames into video? I guess this is sort of "time lapse" video, because 8MM was shot at 20FPS and I need to turn it into 30FPS so it's NTSC standard. Any help is appreciated!
Most decent NLEs, as well as Virtualdub & AVISynth will allow you to use "picture sequences" as input. They usually have to be labelled the same with a sequentially numbered ending (sometimes starting at 000, sometimes at 001).
For example, PICTURE_0001.png, PICTURE_0002.png, PICTURE_0003.png...PICTURE_2393.png, PICTURE_2394.png put into a single folder, and adding the first item in the list, will usually be all you need to do for the NLE, etc to recognize the sequence and load the whole series as one piece of footage. You may or may not have the ability to pre-determine the framerate (depends on the app).
In Virtualdub, you would do it this way:- [File | Open Video file], navigate to pic sequence folder (should ONLY have sequence in there)
- Highlight/select first item in sequence, click [Open]
- Go to [Video | Framerate], and in SourceRateAdjustment section, use the "Change Frame rate to (fps)" option.
- First import the sequence & export to losslessly-compressed video, using Source Framerate Adjustment to change framerate to 20fps.
- Then, import the losslessly-compressed video and do a frame rate conversion to 29.97fps.
Note that while smooth, the Framerate Conversion option in Vdub does NOT apply pulldown, instead it uses interpolation. If you want pulldown, you may have to try different methods.
If you are going to go to MPEG2/DVD, you could also bypass the problem & CHEAT a little and:- Create 20fps video & Encode to MPEG2 at 20fps
- Use DGPulldown to apply the appropriate pulldown flags to get it up to the standard 29.97.
edit: BTW, since you scanned these images in, I have to STRONGLY suggest you apply some kind of image stabilization filter to the video unless you are absolutely sure than the scans had exact, correct framing registration on every frame.Last edited by Cornucopia; 24th Jan 2013 at 13:53.
Cornucopia - what a tutorial!
I don't know how long it took for Cygnus to capture the 8mm shots, but you certainly gifted him with knowledge.
Kudos: I applaud you!
Well done, for a senior member of videohelp (or was it DVDhelp when you joined???? - as for me???)
Good work!;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
inserting photos within a music video
By Olustee bus in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2011, 10:47 -
how to take photos and put them in a video where they appear like rapidfire
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Apr 2011, 08:42 -
PLEASE HELP - Getting scanned photos off of a Video...
By violet in forum Newbie / General discussionsReplies: 6Last Post: 19th Jul 2010, 12:09 -
Upload video and photos to Facebook?
By mlong30 in forum Video ConversionReplies: 1Last Post: 10th Dec 2009, 00:10 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 12:31
Thanks!!
