Hi Forum,
I have an mp4 video clip that I'd like to compress to get it under the 100MB size limit - then I'll be able to upload it to my vShare website.
I get the following error message :- [mpeg4 @ 0x12621a0] Invalid pixel aspect ratio 65536/65536, limit is 255/255.
An output .mp4 file is generated but has no content.
The following is terminal o/p..................
jrm@acer:~/Conference_singing$ ffmpeg -i 20130101_143615.mp4 -acodec mp2 glany13_1.mp4
ffmpeg version 0.8.4-4:0.8.4-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
built on Nov 6 2012 16:51:33 with gcc 4.6.3
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 90000.00 (180000/2)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '20130101_143615.mp4':
Metadata:
major_brand : isom
minor_version : 0
compatible_brands: isom3gp4
creation_time : 2013-01-01 15:38:05
Duration: 00:01:49.49, start: 0.000000, bitrate: 9675 kb/s
Stream #0.0(eng): Video: h264 (Baseline), yuv420p, 1280x720, 9612 kb/s, PAR 65536:65536 DAR 16:9, 24.03 fps, 90k tbr, 90k tbn, 180k tbc
Metadata:
Stream #0.1(eng): Audio: aac, 16000 Hz, mono, s16, 60 kb/s
Metadata:
creation_time : 2013-01-01 15:38:06
File 'glany13_1.mp4' already exists. Overwrite ? [y/N] y
[buffer @ 0x1264420] w:1280 h:720 pixfmt:yuv420p
Output #0, mp4, to 'glany13_1.mp4':
Stream #0.0(eng): Video: mpeg4, yuv420p, 1280x720 [PAR 65536:65536 DAR 16:9], q=2-31, 200 kb/s, 90k tbn, 90k tbc
Metadata:
Stream #0.1(eng): Audio: mp2, 16000 Hz, mono, s16, 128 kb/s
Metadata:
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening encoder for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
o/p ends.
The following is the input .mp4 file information from mediainfo................
General
Complete name : /home/jrm/Conference_singing/20130101_143615.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 126 MiB
Duration : 1mn 49s
Overall bit rate : 9 675 Kbps
Encoded date : UTC 2013-01-01 15:38:05
Tagged date : UTC 2013-01-01 15:38:05
Video
Format : AVC
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 1mn 49s
Bit rate : 9 612 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.027 fps
Minimum frame rate : 23.803 fps
Maximum frame rate : 24.252 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.434
Stream size : 125 MiB (99%)
Title : VideoHandle
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 49s
Bit rate mode : Constant
Bit rate : 60.4 Kbps
Nominal bit rate : 96.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 16.0 KHz
Compression mode : Lossy
Stream size : 807 KiB (1%)
Title : SoundHandle
Language : English
Encoded date : UTC 2013-01-01 15:38:06
Tagged date : UTC 2013-01-01 15:38:06
o/p ends.
I'm sure I need to change the command line but what to do I've no idea - me VideoHelp Newbie !
Many thanks for any advice
semperlinux
I would try a different binary, although it's only a couple of months old, this build has a depreciated warning
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead. -
-> you could try if it helps to specify the aspect ratio with:
-aspect 1:1 -
Poisondeathray :-
I read in several places that the 'deprecation' notice is there because Ubuntu have stopped using it - ffmpeg is apparently still being developed / maintained. This however must be an Ubuntu package version as it contains the deprecation notice.
I don't think there's anything wrong with this version - i.e. the problem isn't being caused by software failure.
Selur :-
Using your 'aspect' command produced a different error as follows...........
[mpeg4 @ 0x7c81a0] timebase 1/90000 not supported by MPEG 4 standard, the maximum admitted value for the timebase denominator is 65535
The remainder of the text o/p is identical to the original error.
Thanks for the input.
Semperlinux -
FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)
By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 17:22 -
Why does FFmpeg stop with an error message with "-c copy -b:v 700k"options?
By falco2000 in forum Video ConversionReplies: 5Last Post: 4th Oct 2012, 12:39 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20
