source is VC-1 file 5 of 7 cant be rencoded AVC error winwow appears and is closing down
this is log:
[01-23-13] BD Rebuilder v0.42.08 (beta)
[16:12:06] Source: ROBIN
- Input BD size: 45,03 GB
- Approximate total content: [04:43:37.341]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7600]
- Quality: Good (Very Fast), Two Pass
- Decoding/Frame serving: X264/LAVF
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
- Resuming from previously started job.
[16:12:10] PHASE ONE, Encoding
- [16:12:10] Processing: VID_00046 (5 of 7)
- [16:12:10] Reencoding video [VID_00046]
- Source Video: VC-1, 720x480
- Rate/Length: 29,970fps, 35 045 frames
- Bitrate: 1 694 Kbs
- [16:12:10] Reencoding: VID_00046, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.42.08 (beta)
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[16:12:15] - Failed video encode, aborted
if i cant reencode it can i skip that file and how to rebuild remaining structure?
main movie was reencoded already.
You have interlaced VC-1 in this video. BDRB is infamous for its problems in re-encoding interlaced VC-1. Sometimes it works. Sometimes it doesn't. There's nothing you can do when it doesn't work. If you want to waste your time you can go the official Doom9 forums and complain about it, but all you'll get is the author's sycophantic followers who will respond and tell you how stupid you are because if you had set up BDRB correctly, it would have worked for you because it is infallible and it simply cannot fail to encode anything when set up correctly. This is of course bs. Even the author himself admits that he lacks a consistently working way to handle interlaced VC-1.
All you can do that I know is to NOT re-encode anything and just burn the rip as is to a BD-R DL disc. I've tried playing with all of the options in BDRB that could possibly help, but once you hit this problem, it's almost impossible to get around it. You try turning off the settings for "de-interlace interlaced video" (something like that) and that ITVC setting if you have them turned on, but probably they won't make any difference whether on or off.
By the way, interlaced VC-1 is somewhat rare so the sycophants have quite probably never run into it. "Battlestar Galactica" uses it more than you might think in their region A BluRay discs and I've even seen it used in a few discs of the US show "The Office".
Just so you'll know, if you see VC-1 as the "Source Video" setting and either 29.97 or 25 fps under "Rate/Length" then you have interlaced VC-1. -
"Just so you'll know, if you see VC-1 as the "Source Video" setting and either 29.97 or 25 fps under "Rate/Length" then you have interlaced VC-1."
dont have that option -
Easy jman98, Were here to help, Apparently asiafan didn't know where to look, asiafan if you would look in your log on the 14th & 15th lines down you will see what jman98 is talking about.
dude, that's just too funny LOL. first you rip into the people that hang out at the doom9 forums with:
then when he doesn't doesn't understand what you were talking about you call him a moron and say he's not smart enough to understand when people try and help him.If you want to waste your time you can go the official Doom9 forums and complain about it, but all you'll get is the author's sycophantic followers who will respond and tell you how stupid you are because if you had set up BDRB correctly, it would have worked for you because it is infallible and it simply cannot fail to encode anything when set up correctly. This is of course bs. Even the author himself admits that he lacks a consistently working way to handle interlaced VC-1.
ROTFLMAO. -
point is that jman98 havent answered correclty for any of mine question
i can try to skip commpresion of problematic m2ts files but once compression was successful but if i cant compress main menu file there can be problem . I dont know how i can rebuild manually BD structure reedited clpi files and mpls
Robin Hood + BD RB
By Drerunsit in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2011, 18:49 -
Can't Rip Prince of Persia
By Brent212 in forum DVD RippingReplies: 1Last Post: 7th Nov 2010, 20:24 -
HP - Half Blood Prince BlueRay
By wulf109 in forum Blu-ray RippingReplies: 2Last Post: 18th Dec 2009, 13:18 -
breaking news: 12 dead, 31 wounded in Fort Hood, Texas shooting
By deadrats in forum Off topicReplies: 1Last Post: 5th Nov 2009, 16:19 -
To say that paying customers are criminals and thieves
By NICEBUD in forum Off topicReplies: 14Last Post: 30th Dec 2008, 02:31
