  1. Since laptops have either one VGA and/or HDMI port, i cannot use Multiple External monitors with stock hardware, so i'm looking at products that will allow me to use more.
    My Questions are,
    -up to how many external Monitors can i use? I Have already found this Martox product that gives 2x VGA from 1 port.
    -Is the graphics processing done internal by the laptops card or the device that allows for more Monitors?
    -Can I make use of both the analog and digital outputs at the same time? Like have a couple CRT Monitors through the VGA port, and an LCD via the HDMI?
    Reason i'm asking all these, is i'm considerign buying a laptop with a small screen and make use of a couple CRT Monitors i have in my Office, so i can manage different application on each Monitor at the same time.
  2. There is no one size fits all answer here. You did check this page, right?
    http://www.matrox.com/graphics/en/support/compatibility/gxm/home/
