  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    I am trying to convert MTS video clips to mpeg. I use directshowsource to load the MTS clip into VirtualDub.
    I can play the video but not audio. I am running Windows7 and already install AC-3 ACM codec 2.2. VirtualDub version 1.9.1.1.
    This is my video format.
    Please let me know what I have not done right.
    Thanks in advance.
    Have you tried convert? No audio then also?
    I wouldn't trust the video preview in virtualdub.
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi Baldrick,
    Thanks.
    Yes, I converted the video from MTS to AVI. Video is OK but no audio.
  4. DECEASED
    Jun 2009
    Heaven
    DirectShowSource() rarely will use an ACM codec. You need an appropriate (read: NON-microsoft) DirectShow filter for AC3.
    Also, you could/should remux the MTS to MKV, and then use FFMS2 instead.
  5. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi El Heggunte,
    I install AC3Filter 2.5b and it works.
    Now, both sound and video.
    Thank you very much.
