Results 1 to 10 of 10
  1. I have some movies that are microsoft high speed mepg4 v3 . I would like to convert it so I can put it on a vcd. Thanks I should say that virtualdub13c says that it is mpeg 4, but it is a avi fromat. it will not work on TMPGEnc .
  2. "Hepl"
  3. Originally Posted by e-z-e
    "Hepl"
    Help ,my bad
  4. if i recall correctly, microsoft does not want anyone to use that codec in an avi file. it is meant for the wmv format, so that means other programs cannot view it. you need to re-encode your video with a different codec, ms v2 or divx or something
    hope that makes sense
  5. Originally Posted by saturn123
    It is a avi file.?. hmm I guess there no way to convert ? I downloaded it from the net.
  6. mpeg4 is divx.
  7. Banned
    Jun 2001
    UK
    Just install the codec
    Search grokster for "Mpeg4 Codec.exe"
    And some others that I quite like
    V3 unlocked Mpg4c32.dll
    Wmvds32.ax
    3.11 Alpha
    Install and convert away
  8. u got any direct links for the MPEG 4 codec and others the u mentioned??
    Sunil
  9. Banned
    Jun 2001
    UK
    Sorry no links, you need to use Grokster or Kazza
  10. Thanks all for your help.I updateed my virtualdub 1.3 to virtualdub 1.4 and it worked GRREEAt Thanks Lurp
