Hi all-
I'm using YAMB to combine extracted video/audio tracks from flv video file. My digital entertainer (Netgear) will not recognize the default aac codec that YAMB uses for whatever reason. When I convert the audio stream to mp3, go through themp4 creation process with YAMB again, everything plays fine on the DE.
Now, is it possible to somehow replace the audio codec with an mp3 codec in YAMB so I can skip the extra step? If that can be done, how is it done?
Thanks!
Mark
With ffmpeg command line
put ffmpeg.exe and video.flv in same folder.Code:ffmpeg -i video.flv -vcodec copy -acodec libmp3lame -ab 128k video.mp4
Or try a ffmpeg frontend like xmedia recode, open flv, under format choose mp4, under video choose copy video stream, under audio choose mp3.
Or with avidemux, open flv, under video choose copy, under audio choose mp3, under format mp4, save as new.mp4.
Using YAMB to demux audio from MP4 problem...
By takearushfan in forum AudioReplies: 2Last Post: 2nd Feb 2012, 01:44 -
MkvToMp4 vs YAMB
By jandor2009 in forum Video ConversionReplies: 0Last Post: 4th Jan 2012, 06:52 -
Can MP4Box does everything YAMB could?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2011, 12:07 -
Yamb AVI to MP4 (with AAC audio)
By djalman in forum Video ConversionReplies: 5Last Post: 20th Aug 2011, 18:32 -
Can Someone recommend an Alternative to YAMB
By Scarpad in forum Blu-ray RippingReplies: 4Last Post: 5th May 2010, 15:39
