Page 2 of 2
FirstFirst 1 2
Results 31 to 59 of 59
  1. Or duplicate a frame to create one where one was missing and then replace it with a new and interpolated one:
    Loop(2,1325,1325)
    RX(1326,1)
    Here you've created a new frame number 1326 to temporarily 'stand in' for the missing frame (by duplicating #1325) and then interpolated off of the frames on either side. That way the function doesn't have to be modified. Of course you can create as many new duplicate frames as is necessary and then replace them all with interpolated ones.
    Me, I find the function descriptive and easy enough to understand with its given name, not to mention much quicker to type when necessary (I'm a lousy typist). I'm assuming 'RP' means 'Replace Pairs' and 'RX' means 'Replace X Number Of Frames'. Searching? Yes, that's a different matter.
  2. Here's my mod of RX() to insert missing farmes rather than replace existing frames. Audio is blank during the inserted frames.
    function InsertFramesMC(clip Source, int N, int X)
      # inserts missing frames using motion interpolation
      # N is the frame number before which the sequence will be inserted
      # X is number of frames to insert
      # the video length is increased by X frames
      # won't work for N=0, N>last
      # e.g. InsertFramesMC(101, 5) would
      # keep the source's frames from 0 to 100
      # create and insert 5 motion interpolated frames (based on source frames 100 and 101)
      # append the source's frames 101 to the end
      # audio is silent during the inserted frames
      start=Source.trim(N-1,-1) # frame before N, used for interpolation starting point
      end=Source.trim(N,-1) # frame at N, used for interpolation ending point
      start+end # join them into a two frame video
      AssumeFPS(1) # temporarily FPS=1 to use mflowfps
      super = MSuper()
      backward_vec = MAnalyse(super, isb = true)
      forward_vec = MAnalyse(super, isb = false)
      MFlowFps(super, backward_vec, forward_vec, blend=false, num=(X+1), den=1)
      Trim(1, X) # trim ends, leaving only the frames for insertion
      AssumeFPS(FrameRate(Source)) # return to source framerate for joining
      Source.trim(0,-N) ++ last ++ Source.trim(N,0) # join, before, inserted, after
    Or using manono's "loop" method and the original RX():
      loop(Source, X+1, N, N)
      RX(N, X)
    Maybe you'll want to call it IX()?
    My first thought was to insert blank or repeat frames and use RX but I didn't know what function could do that. Manono's method has the additional benefit that it won't require modification if RX() is improved in the future.
  3. Anonymous
    Guest
    Thanks, jagabo. I'll give that a try and report back.
  4. Here's a version of ReplaceFramesMC() that works a little differently. I find it usually works a little better than the version posted earlier. It can be called by InsertFramesMC() too.
    function ReplaceFramesMC(clip Source, int N, int X)
     # N is number of the 1st frame in Source that needs replacing.
     # X is total number of frames to replace
     #e.g. RX(101, 5) would replace 101,102,103,104,105 , by using 100 and 106 as reference points for mflowfps interpolation
     start=Source.trim(N-1,-1) #one good frame before, used for interpolation reference point
     end=Source.trim(N+X,-1) #one good frame after, used for interpolation reference point
     start+end
     AssumeFPS(1) #temporarily FPS=1 to use mflowfps
     super = MSuper(pel=2, hpad=0, vpad=0, rfilter=4)
     backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
     forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
     backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3)
     forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3)
     backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3)
     forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3)
     MBlockFps(super, backward_3, forward_3, num=X+1, den=1, mode=0)
     AssumeFPS(FrameRate(Source)) #return back to normal source framerate for joining
     Trim(1, framecount-1) #trim ends, leaving replacement frames
     Source.trim(0,-N) ++ last ++ Source.trim(N+X+1,0)
  5. Anonymous
    Guest
    Jagabo, I've tried the first version of your function, and it works very well for my purposes. Thank you very much. I'll have a look at your second function too.
    How is this accomplished? I still don't understand how functions work: I just use them.
  6. Originally Posted by Jeff B View Post
    The argument syntax is identical to RX(). So you can get rid of the old RX() and rename the new function RX(). Or you could modify the call in InsertFramesMC() to call this function instead.
    For example, if you kept the old version named RX(), and added my new version called ReplaceFramesMC(), then you could modify the "RX(N, X)" line in InsertFramesMC() to read "ReplaceFramesMC(N, X)".
    Or you could keep both pairs of functions:
    function RX(clip Source, int N, int X)
    start+end
    super = MSuper()
    MFlowFps(super, backward_vec, forward_vec, blend=false, num=X+1, den=1) #num=X+1
    function IX(clip Source, int N, int X)
      RX(N, X)
    and:
     # Replace X frames, starting at N, with motion interpolated frames
     start+end
     # Insert X motion interpolated frames at N
     # N is the insertion point
     # X is the number of frames to insert
     # the frames will be interpolated with Source frames N-1 and N as references
  7. Anonymous
    Guest
    Jagabo, does InsertFramesMC use a great deal of memory? When I try to render from Virtualdub, it hangs. I have just received an error message.
    Avisynth read error("GetFrameBuffer: Returned a VFB with a 0 data pointer!\n"
    "size=3110464, max=536870912, used=86540224"
    "I think we have run out of memory folks!"
    I guess this has something to do with MVTools. Does anyone have ideas?
    EDIT: I've just tried using SetMemoryMax.
    SetMemoryMax(64)
    It seems to be rendering all right.
  8. i am working on script (on another language) that can create a full mapfile.txt/map data within a few seconds for the RemapFrames() function.
    I will share it when I will done..
  9. Originally Posted by Jeff B View Post
    I'm not really sure. I've only used it on short videos. I seem to recall having problems with ReplaceFramesMC() when the number of frames got over ~15. I don't remember exactly what the problem was but it might be related.
  10. I've used InsertFramesMC dozens of times within a single AviSynth script and with it interpolating frames into the 20's at a time and haven't had any problems.
    And thanks for that script, jagabo. It doesn't work miracles but it gets rid of those weird white edge artifacts and is a distinct improvement over the earlier interpolators.
  11. Originally Posted by manono View Post
    Glad it helped you out. I just took the code from another frame rate interpolator and adapted it.
  12. Anonymous
    Guest
    Thank you both for the information. I think the problem is with MVTools rather than the function. I found an old thread here, in which this is discussed on this and the following page. Regardless, adding SetMemoryMax() seemed to work.
  13. Jagabo, this function takes up a hell of a load of memory. I have a couple thousand frames to insert. I got all of them from the deldup log that I'm gonna re-insert as interpolated frames but my question is how to do it when I can only insert like 300 at a time?
    I'd split the job up with trims but the problem is that every frame inserted changes the frame count so I have to always start at the beginning.
    I would do RX instead while the duplicates are still there and RX() them but the video is shaky, interlaced and shimmered and I'd rather do frame interpolation AFTER the video is clean.
  14. Originally Posted by Mephesto View Post
    Work in reverse.
  15. I can't. The video (without duplicates) is only about 28000 frames which'll be 31000 with the frames inserted but I can't insert IX(30990,1) if there are only 28000 frames.
    That's why I have to start from the beginning, so with all the previous frames inserted there will be a frame 30990 at the end to insert at, unless my logic is wrong.
  16. I found a solution. I used the stats.txt outputted by DeDup.avs, sorted in excel and kept the duplicate frames and created a huge RX(frm,1) list so it replaces and interpolates the duplicate frames. I had to do it 200 lines at a time though.
    In the end, I scrapped the video because I hated the result. I'll keep the lower FPS without the duplicates, screw it.
  17. Anonymous
    Guest
    I solve that problem by adding Showframenumber() or Info() so I can see the frame-number and moving it about the script after I've added the frames. It takes a while to get the hang of it, but it works for me.
  18. Originally Posted by Mephesto View Post
    Work in reverse.
    I know you've worked out another method. But since you're using Excel you could subtract the line number from each entry. That would give you pre-inserted frame numbers. Use that list to work backwards.
    line#, frame#, frame#-line#
    0, 35, 35
    1 ,44, 43
    2, 53, 51
    3, 68, 65
    Oct 2019
    Colorado
    Hey All,
    First I am sorry for resurrecting an old thread.
    I am new to the forum and I am very intrigued with frame interpolating some DVD's I am working for my library. The difficulty I am having at the moment is figuring out on how to scan and output a list of frames randomly duplicated within the footage (assuming I need that based on how the logic presented here works). I tried DeDup, but the DupMC log looks messed up and the frames look wrong compared to what I see the frame is in AvsPmod
    DeDup 0.17 by Loren Merritt, based on Dup 2.20 beta 1 by Donald Graft/Klaus Post, Copyright 2004
    frm 450: diff from frm 451 = 1.0904% at (544,320)
    frm 301: diff from frm 302 = 20.8187% at (32,256)
    frm 0: diff from frm 1 = 0.3083% at (256,0)
    384)
    frm 325: diff from frm 326 = 2.5611% at (320,352)
    frm 17: diff from frm 18 = 0.1222% at (384,384fffrm 20: diff from frm 21 = 0.1313% at (64,64)
    Any Advice?
    I have been trying to review the script here (https://forum.doom9.org/showthread.php?p=1563921#post1563921) to see if I can figure out on how to get said list, but its going slow.
    Thank you in advance!
  20. If you want to replace duplicate frames with interpolated frames, then FillDrops is probably what you want. Much better, though, would be for you to make available10 seconds or so of source video showing the problem.
  21. Originally Posted by qops1981 View Post
    384)
    What source filter are you using ?
    Post your script
    Did you run a complete analysis pass linearly, from start to end? Those framenumbers are misordered - that suggests you did not.
  22. To get a list of duplicate frames you can use the runtime function YDifferenceFromPrevious along with WriteFileIf().
    Mpeg2Source("filename.d2v")
    WriteFileIf("Dups.txt", "YDifferenceFromPrevious<0.5", "current_frame", flush=true)
    You'll have to change the threshold to suit your video. Dups.txt will contain a list of duplicate frames. You'll always get a false positive at frame 0.
    But this step may not be necessary -- you can probably do every thing you need in one script. For example, there's a script by johnmeyer that will automatically detect and replace duplicate frames with a motion interpolated frame (motion interpolated halfway between the frame before it and the frame after).
    Oops, I see manono already mentioned FillDrops.
  23. The original filldrops function was written by Mugfunky for the old MVTools. I updated it years ago for the more modern MVTools2 and also wrote a version for interlaced video. Here are the progressive and also the interlaced version of Filldrops:
    function filldrops (clip c)
      super=MSuper(c,pel=2)
      vfe=manalyse(super,truemotion=true,isb=false,delta=1)
      vbe=manalyse(super,truemotion=true,isb=true,delta=1)
      filldrops = mflowinter(c,super,vbe,vfe,time=50)
      fixed = ConditionalFilter(c, filldrops, c, "YDifferenceFromPrevious()", "lessthan", "0.1")
      return fixed
    function filldropsI (clip c)
      even = c.SeparateFields().SelectEven()
      super_even=MSuper(even,pel=2)
      vfe=manalyse(super_even,truemotion=true,isb=false,delta=1)
      vbe=manalyse(super_even,truemotion=true,isb=true,delta=1)
      filldrops_e = mflowinter(even,super_even,vbe,vfe,time=50)
      odd  = c.SeparateFields().SelectOdd()
      super_odd=MSuper(odd,pel=2)
      vfo=manalyse(super_odd,truemotion=true,isb=false,delta=1)
      vbo=manalyse(super_odd,truemotion=true,isb=true,delta=1)
      filldrops_o = mflowinter(odd,super_odd,vbo,vfo,time=50)
      evenfixed = ConditionalFilter(even, filldrops_e, even, "YDifferenceFromPrevious()", "lessthan", "0.1")
      oddfixed  = ConditionalFilter(odd,  filldrops_o, odd,  "YDifferenceFromPrevious()", "lessthan", "0.1")
      Interleave(evenfixed,oddfixed)
      Weave()
  24. Member
    Oct 2019
    Colorado
    Holy frijoles!
    That's was a way quicker and more substantive set of responses than I expected!
    @manono I saw this filter but it's function confused me as they aren't "dropped" frames, unless I misunderstand what frame is. I will take some more time to review this filter to better understand it. As far as a ten second video, I am a bit timid to so so. As you will see from the script below it is a Disney Ducktale's Episode from DVD's I do own, but just not sure how the legality works there. But I also don't think its hard to imagine what a duplicate frame looks like.
    @poisondeathray You are correct, my original run (also partial) was erased and this was just me scrubbing. Here is a run 10 seconds in from the beginning.
    frm 12: diff from frm 13 = 0.1363% at (160,0)fffrm 24: diff from frm 25 = 0.1521% at (64,64)fffrm 36: diff from frm 37 = 0.1122% at (32,192)frfrm 48: diff from frm 49 = 0.2826% at (288,32)frfrm 60: diff from frm 61 = 0.6204% at (64,44frmffrm 72: diff from frm 73 = 4.2819% at (672,1frmfffrm 84: diff from frm 85 = 2.0529% at (64,96frffrm 96: diff from frm 97 = 64.6734% at (192,64frffrm 108: diff from frm 109 = 29.0592% at (32,0frmfrm 120: diff from frm 121 = 1.7566% at (288,224frmfrm 132: diff from frm 133 = 1.5779% at (416,32frfrfrm 144: diff from frm 145 = 1.7973% at (256,38frfrfrm 156: diff from frm 157 = 55.0690% at (672,19ffrffrm 168: diff from frm 169 = 25.2256% at (0,192frffrm 180: diff from frm 181 = 1.3331% at (64,320frmfrm 192: diff from frm 193 = 3.8718% at (352,16frm frm 204: diff from frm 205 = 3.6656% at (544,64frmfrm 216: diff from frm 217 = 73.7276% at (512,12frm frm 228: diff from frm 229 = 1.9290% at (384,28frm frm 240: diff from frm 241 = 3.0764% at (96,288frmfrm 252: diff from frm 253 = 1.1095% at (544,32frmfrm 264: diff from frm 265 = 0.9691% at (128,416frmfrm 276: diff from frm 277 = 27.3978% at (288,22frm frm 288: diff from frm 289 = 0.6624% at (320,38frm frm 300: diff from frm 301 = 3.1159% at (320,3frm 3frm 312: diff from frm 313 = 2.1779% at (288,1frm 3frm 324: diff from frm 325 = 1.4648% at (384,frm 3ffrm 336: diff from frm 337 = 27.1863% at (512frm 3frfrm 348: diff from frm 349 = 20.2564% at (96frm 34frm 360: diff from frm 361 = 1.7761% at (320frm 36ffrm 372: diff from frm 373 = 2.1547% at (288,frm frm 384: diff from frm 385 = 0.8369% at (352,0frmfrm 396: diff from frm 397 = 35.7509% at (320,19frmffrm 408: diff from frm 409 = 8.1129% at (672,12frm frm 420: diff from frm 421 = 2.3325% at (0,448)frfrm 432: diff from frm 433 = 1.7088% at (384,0)
    frm 444: diff from frm 445 = 1.0967% at (448,320)
    frm 456: diff from frm 457 = 26.1661% at (608,288)
    ffrm 468: diff from frm 469 = 0.6026% at (576,288)
    ffrm 480: diff from frm 481 = 0.5988% at (608,160)
    frm 492: diff from frm 493 = 0.5976% at (544,192)
    frm 504: diff from frm 505 = 0.4609% at (512,224)
    frm 516: diff from frm 517 = 37.4805% at (448,256)
    ffrm 528: diff from frm 529 = 29.5450% at (320,256)frfrm 540: diff from frm 541 = 1.2990% at (320,22frm frm 552: diff from frm 553 = 1.3472% at (320,19frm frm 564: diff from frm 565 = 0.7817% at (160,38frm frm 576: diff from frm 577 = 1.1370% at (192,384frmfrm 588: diff from frm 589 = 1.5151% at (192,224frmfrm 600: diff from frm 601 = 1.8318% at (288,192frmfrm 613: diff from frm 614 = 0.8378% at (640,128frmfrm 625: diff from frm 626 = 0.7289% at (352,384frmfrm 637: diff from frm 638 = 1.9012% at (416,448frmfrm 649: diff from frm 650 = 0.9367% at (640,448frmfrm 661: diff from frm 662 = 71.1889% at (416,384frmfrm 673: diff from frm 674 = 2.7190% at (288,192frmfrm 685: diff from frm 686 = 6.9024% at (64,32)frfrm 697: diff from frm 698 = 3.5813% at (96,32)frm 69frm 700: diff frm 701: diff from frm 702 = 35.1733% at (224,64)
    Also you asked about the code.
    Note: I am soooo a novice, lol, please be kind.
    Also, side Note: The Disney DVD's for there animated series are garbage. I can't believe they charge money for these!
    SetFilterMTMode("QTGMC", 2)
    SetFilterMTMode("DeSpot", 2)
    SetFilterMTMode("DeFlicker", 2)
    SetFilterMTMode("SMDegrain", 2)
    SetFilterMTMode("MPEG2Source", 2)
    SetFilterMTMode("MergeChroma", 2)
    SetFilterMTMode("awarpsharp2", 2)
    MPEG2Source(d2v="S:\DuckTales\MakeMKV\DT3-0N-NW1.1_DES\title_t00.sample.d2v", cpu=5, iPP=true, moderate_v=20)
    DeSpot(p1=35, p2=14, mthres=25, pwidth=12, pheight=14, interlaced=true)
    SeparateFields()
    DeFlicker(scene=30)
    Weave()
    SMDegrain(tr=6,thSAD=500,interlaced=true,prefilter=1,refinemotion=true,lsb=true)
    QTGMC(Preset="Slower", Edithreads=4)
    MergeChroma(awarpsharp2(depth=30))
    DupMC(log="P:\title_t00.dedup.txt")
    Prefetch(threads=12)
    I am quite pleased with the output of this so far. I have also been seeing IVTC mentioned a lot in my search and might take a look there for more inspiration, but so far I like what see from the above script.
    @jagabo This is very helpful, The link I posted that also uses this may have just been obfuscated in its complexity for me. Thank you!
    @johnmeyer This is also very helpful. I was hoping to use SVP as described in this thread, but in some comparison videos MVTools* isn't looking to shabby either. This is also a great example of filldrops as @manono described for my use. I might just pursue this next. If it looks good I won't see a reason to spend more time than I need to right away.
    Thank you to everyone!
  25. Originally Posted by qops1981 View Post
    The filter name is misleading, yes, but it does what you want. Except, you want the wrong thing, I think.
    It's called 'Fair Use' and you can look it up. It's perfectly okay to make available a small section for study.
    You bob a video and then want to remove the dupe frames created? And from an animation to boot? Better might be to perform an IVTC to begin with and forget all the rest of it. Again, post a short sample cut from the source. DGIndex can do it
    It's things like this that always prompt us to ask for both the script and a sample. Often the poster has no idea what he/she has and how to treat it. Then we waste our time answering irrelevant questions.
  26. Originally Posted by qops1981 View Post
    SVP is based on MVTools. Its only advantage is that it runs really fast when trying to increase the number of frames without changing the playback speed. Doing this makes film look more like video and can eliminate some film artifacts, like the "judder" that happens when the camera pans horizontally. IMHO, it usually makes the video look FAR worse, so I am not a fan, at all.
    SVP is not the right choice for any other motion interpolation task because the developers focused only on the one task of increasing the number of frames when they ported it to run on your computer's video GPU. Many of the MVTools2 functions are not fully implemented in SVP.
    MVTools2 can be used to:
    1. Increase the total number of frames. This can be done to introduce the "soap opera effect," something most people find interesting initially, but then end up hating. SVP was designed to do exactly this function.
    2. Do the same thing as #1, but play the frames more slowly, resulting in smooth slow motion.
    3. Interpolate between individual frames, for removing duplicates and fixing other random problems (such as eliminating a photographer's flash).
    4. Temporarily move adjacent pixel locations in adjacent frames to match their location in the current frame, prior to applying a temporal denoising filter.
    SVP's syntax is unusually difficult, so much so that another person developed Interframe, a function that puts a "friendlier" face on SVP.
  27. Yes, Duck Tales is shot on film then telecined. The correct procedure is usually to inverse telecine, not deinterlace.
    To extract a short sample use DgIndex: mark-in, mark-out, File -> Save Project And Demux Video. Upload the resulting m2v file. Do NOT cut a sample from the intro (shots there often slow down or sped up) but rather the body of an episode.
    And, by the way, motion interpolation doesn't work well with animated material (except during simple panning shots). You should forget about that.
  28. Member
    Oct 2019
    Colorado
    @manono Yes & No, at least thats my perception of it. Reviewing the video it seems that they alternate the movement of the background and the characters. So every frame has movement in it. Furthermore; the de-interlaced frames also seem to present as unique frames that are different from there neighbors. Sometime more, sometimes less. But that being said there are times where are are legit duplicate frames where I cannot perceive any difference.
    @johnmeyer
    This is an awesome review, Thanks, I am sold.
    @jagabo
    As I mentioned to @manono they alternate movements so ever frame has movement in it. Is that telecine? I thought that telecine limited all movement to certain frames.
    As requested here is a sample video and where I am at with it. I feel this clip also demonstrates well how they alternate movements.
    Sample Video
    title_t00.help.sample.m2v
    Work so far
    Note: This is without any frame interpolation to replace dups. I have been playing with it thought. Seems interesting. I see what you mean by soap opera effect.
    title_t00.help.work_so_far.mkv
    Last edited by qops1981; 26th Oct 2019 at 18:02. Reason: Add note about "Work so far"
  29. This will get the original film frames, no dups, no drops (unless the source has them):
    Mpeg2Source("title_t00.help.sample.d2v")
    TFM()
    TDecimate()
    Follow that with whatever cleanup you want.
