hello, I need to merge and convert one image file and sound file into a ogg video.
I'm using:
which does produce a file, but doesn't work with vlc player.Code:ffmpeg -y -i img2x2.bmp -i guitarra.mp3 -acodec libvorbis sync2.ogv
output from console:
Code:ffmpeg version N-49069-gc74d465 Copyright (c) 2000-2013 the FFmpeg developers built on Jan 20 2013 23:39:19 with gcc 4.7.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libg sm --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --e nable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --e nable-libspeex --enable-libtheora --enable-libtwolame --enable-libvo-aacenc --en able-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable -libxavs --enable-libxvid --enable-zlib --enable-filter=frei0r libavutil 52. 15.100 / 52. 15.100 libavcodec 54. 89.100 / 54. 89.100 libavformat 54. 61.101 / 54. 61.101 libavdevice 54. 3.102 / 54. 3.102 libavfilter 3. 32.101 / 3. 32.101 libswscale 2. 2.100 / 2. 2.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 2.100 / 52. 2.100 Input #0, image2, from 'img2x2.bmp': Duration: 00:00:00.04, start: 0.000000, bitrate: N/A Stream #0:0: Video: bmp, bgr24, 2x2, 25 tbr, 25 tbn, 25 tbc [mp3 @ 02585380] max_analyze_duration 5000000 reached at 5015510 microseconds Input #1, mp3, from 'guitarra.mp3': Duration: 00:00:06.06, start: 0.000000, bitrate: 321 kb/s Stream #1:0: Audio: mp3, 44100 Hz, stereo, s16p, 320 kb/s Output #0, ogg, to 'sync2.ogv': Metadata: encoder : Lavf54.61.101 Stream #0:0: Video: theora, yuv444p, 2x2, q=2-31, 200 kb/s, 25 tbn, 25 tbc Stream #0:1: Audio: vorbis, 44100 Hz, stereo, fltp Stream mapping: Stream #0:0 -> #0:0 (bmp -> libtheora) Stream #1:0 -> #0:1 (mp3 -> libvorbis) Press [q] to stop, [?] for help frame= 1 fps=0.0 q=0.0 Lsize= 71kB time=00:00:06.04 bitrate= 95.7kbits/ s video:0kB audio:63kB subtitle:0 global headers:7kB muxing overhead 0.907899%
what am I missing?
regards
Hi, I'm just coming back from work. -r 1 did the trick.
Thanks lot for your help!
how to merge sub file into .avi video file?
By neiffee9211 in forum SubtitleReplies: 3Last Post: 12th Nov 2012, 13:40 -
[Help] Extract Audio from one file and merge it to another file
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2012, 14:40 -
How to merge subtitles from one file with timing from another file?
By MousE0910 in forum SubtitleReplies: 3Last Post: 29th Jul 2010, 11:14 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 14:04 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 01:15
