Hi Video Gurus,
I am a new member and need some help here! I have about 44 analog camcorder tapes (8mm) in which I was able to transfer to my pc using WinDV with great quality; I understand they’re transfer in uncompressed (lossless) .avi format. I am very happy with the quality of the video but each 2 hours tapes required about 23 Gigs of space. Here are my questions:
1. What is the best way to reduce the file size (under 5Gigs) without sacrifice the video quality
2. If the method is to convert to other formats, what is the best format converting avi to? Would it be mp4(h264)?
3. What conversion programs do you recommend?
Last night I have tried using HandBrake to convert .avi to mp4(h264), with the default settings. The file size reduced to 3+ Gigs, which is great but clearly the .mp4 video quality has deteriorated a lot. Would a different program such as SUPER or using different setting make any difference?
Handbrake's default settings are best suited for converting to something to watch on a mobile. Not great quality.
You'd want the high profile, to say the least. It gives you 8x8 DCT and it's probably the most important quality setting.
Beyond that, it gets more complex.
I'm not saying there's anything wrong with handbrake. There are many other x.264 encoders recommended here by pretty serious video geeks, but they are not suitable for beginner use. Handbrake or vidcoder (same encoder actually) have the best power/ease of use balance.
DV AVI to smaller file size format?
By movie in forum Video ConversionReplies: 6Last Post: 5th Dec 2012, 06:06 -
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 03:59 -
decrease file size
By zsuppguy in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2010, 16:30 -
How could I decrease video file size but keep high-quality?
By jace89 in forum Software PlayingReplies: 11Last Post: 20th Dec 2008, 20:25 -
Decrease the size of an avi file
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 11:51
