  1. Hi everyone...I have a project Im working on. It entails creating a powerpoint presentation that when completed will be converted to video then burned on DVD. Once on DVD the disk will be distributed to customers to watch at home on their televisions sets.
    Now my problem is Im not sure how large a slide should be or the resolution it should be set at in Powerpoint. Is there any type of standard size or resolution I should create the presentation in for people to view the video on their television sets? I've been searching the heck out the net and all of the informattion I looked up just confused me more.
    Any help would be appreciated...Thank you!
    Oct 2005
    666th portal
    dvd is basically one size. either 720x480 for ntsc or 720x576 for pal - it just depends on your countries tv system.
