  1. Member vhelp's Avatar
    Mar 2001
    New York
    does anyone know if there is such a thing as a reader or viewer that opens .js files and display them in their original form and not as garbage in notepad or wordpad ? i believe these are java files. somehow, i don't believe end-users design these .js files like this, they most be in some format. anyway.
    i ask because i have these .js files that my home made youtube player app dumps in the temp folders. i'm trying to understand how they work and all but these files are not formated in any way for me to grasp. thank you.
    --snipet--
    (function(){var je=google.j,dr=0,fp='bc9af38cc3ecd502',_loc='',_ss =0;je.api({'n':'ac','c':{},'fp':fp,'r':dr,'sc':0,' is':_loc,'ss':_ss});je.api({'n':'pcs','i':'gstyle' ,'css':'body{color:#000;margin:3px 0;overflow-ycroll}body,#leftnav,#tbdi,#hidden_modes,#hmp{backg round:#fff}a.gb1,a.gb2,a.gb3,.link{color:#12c!impo rtant}.ts{border-collapse:collapse}.ts td{padding:0}.ti,.bl,#res h3{display:inline}.ti{display:inline-table}#tads a.mblink,#tads a.mblink b,#tadsb a.mblink,#tadsb a.mblink b,#rhs a.mblink,#rhs a.mblink b{color:#1122cc!important}#tads .ch,#tadsb .ch,#rhs .ch{margin-top:4px;}a:link,.w,#prs a:visited,#prs a:active,.q:active,.q:visited,.kl:active{color:#12 c}.mblink:visited,a:visited{color:#609}.vst:link{c olor:#609}.cur,.b{font-weight:bold}.j{width:42em;font-size:82%}.s{max-width:42em}.sl{font-size:82%}.hd{position:absolute;width:1px;height:1p x;top:-1000em;overflow:hidden}.f,.f a:link,.m,.c h2,#mbEnd h2,#tads h2,#tadsb h2,.descbox{color:#666}.a,cite,cite a:link,cite a:visited,.cite,.cite:link,#mbEnd cite b,#tads cite b,#tadsb cite b,#ans\x3ei,.bc a:link{color:#093;font-style:normal}.mslg cite{display:none}.ng{color:#dd4b39}h1,ol,ul,li{ma rgin:0;padding:0}li.head,li.g,body,html,.std,.c h2,#mbEnd h2,h1{font-sizemall;font-family:arial,sans-serif}.c h2,#mbEnd h2,h1{font-weight:normal}.clr{clear:both;margin:0 8px}.blk a{color:#000}#nav a{display:block}#nav .i{color:#a90a08;font-weight:bold}.csb,.ss,.play_icon,.mini_play_icon,.m icon,.licon,.close_btn,#tbp,.mbi,.inline-close-btn{background:url(/images/nav_logo117.png) no-repeat;overflow:hidden}.csb,.ss{background-position:0 0;height:40px;display:block}.ss{background-position:0 -91px;position:absolute;left:0;top:0}.cps{height:18 px;overflow:hidden;width:114px}.spell{font-size:16px}.spell_orig{font-size:13px;text-decoration:none}a.spell_orig:hover{text-decoration:underline}.mbi{background-position:-153px -70px;display:inline-block;float:left;height:13px;margin-right:3px;margin-top:2px;width:13px}.mbt{color:#11c;float:left;font-size:13px;margin-right:5px;position:relat
  2. You could try notepad ++
  3. Member vhelp's Avatar
    Mar 2001
    New York
    thanks, i'll look it up..
  4. Member vhelp's Avatar
    Mar 2001
    New York
    download: http://notepad-plus-plus.org/download/v6.2.3.html
    ok, that didn't work. it display the whole .js script on one line. but if i go into \view\.. and turn on word wrap, it display the same garbage format as in notepad and wordpad. i'll keep searching, thanks anyway.
  5. DECEASED
    Jun 2009
    Heaven
    Would you mind uploading a sample file
  6. Member vhelp's Avatar
    Mar 2001
    New York
    i tried, but this sight is blocking it and won't allow to upload.
    these are random files, ie.., "bc9af38cc3ecd502[1].js"
