I'm trying to capture a video source, a Panasonic DVD player. I'm doing it through my Sony Handy Cam TRV480. I run a firewire cable from the 480 to a firewire port on my PC Win7. An RCA jack runs from the player to the camera. When I turn on the player a 480, I get no boing sound from the speakers. I verified that I can hear the speakers by running an audio file, and by pulling out a USB device. The latter goes boing. When I use File->Capture Video, I get a dialog that says there is "Please connect a device". I'm aware of the Preferences under Capture Video. Enable DV control is unchecked. If I check it, still a device in not detected.
If I try with a 8 mm tape instead of the player, I do not get connected.
I've tried different orders of turning on with Vegas, camera and player. Perhaps a camera setting is mis-set? Nothing works. No boings or device detected.
Comments?
Maybe trying it on Windows Movie Maker might be fruitful. I've never used it.
Solved. I had to dig deep, but I'll spare you a lot. I finally discovered the small circuit board inside my PC for firewire use wasn't working. Fortunately, lightly pushing it around a little bit caused the connection to work. Vegas does detect my input source, a DVD player in my case.
Vegas 9.0 Camera not connected
By solarblast in forum Capturing and VCRReplies: 2Last Post: 26th Mar 2012, 17:25 -
DV capture in Vegas not working
By Knightmessenger in forum Capturing and VCRReplies: 22Last Post: 29th May 2009, 08:31 -
Vegas Studio will not capture audio
By mpjbrennan in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2009, 09:24 -
Unable to capture hdv with Vegas 8 Platinum
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 22nd May 2008, 05:10 -
Sony Vegas Pro 8 Capture in 16.9
By Ben17 in forum Capturing and VCRReplies: 18Last Post: 25th Apr 2008, 01:30
