Hi all, I recently bought a new TV.
I would like to connect my hard disk to my tv with normal usb I've already tried it .
En it works fine but on my tv usb input stands that it only supports 5v(0.5a) usb device's en my hard disk takes 12V(1.5a) but i don't realy have problem's yet it just takes a bit more time to read all the files on the hard disk . My question is whether I will get damage to my TV or hard disk ?
Thanks in advance!![]()
So, your external hard drive has a 12V 1.5A power supply connected to it... There is no problem with that, this is the only way you can have a 3.5" hard drive work externally and no power flows back to the TV through the USB port.
If your hard disc needs 12V at 1.5A, I'm assuming it is powered from an external power supply and not from the 5V supply from the USB port. It won't harm either if that is the case.
A okay so that 5V stands for hard disc's with no external power if you got one with external power then you gonna have never trouble with that ?
Aren't those USB powered externals all notebook (2.5") drives? Anyway, yeah, you'll be fine with a powered 3.5" external. I use NTFS, MBR formatted 2 TB powered external drives with my LG 65LW6500 TV.
Pull! Bang! Darn!
connecting external hard drive to blu ray player then accessing data off it
By julie_152 in forum DVD & Blu-ray PlayersReplies: 36Last Post: 24th Sep 2012, 07:44 -
I have a question about connecting an external hard drive to Blu-ray
By shalevagr in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Aug 2011, 19:38 -
Connecting HDMI to my apple LED 24" Cinema Display
By dtellez in forum MacReplies: 5Last Post: 5th May 2010, 15:31 -
Connecting SATA hard drive in IDE PC
By alegator in forum ComputerReplies: 17Last Post: 13th Apr 2010, 14:00 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
