				Results 31 to 36 of 36
	hey ozok, aren't you the author of tencoder? if you are, well, i like your work. i think it's better than mediacoder in some ways.
	Under "Others" tab you'll see "Advanced Options" textbox. Click to the box left to it to enable it. Enter "-x ref=11". But if you select a x264 preset/profile/tune it most probably will override it. I managed to get ref 11 by setting "Preset", "Profile", "Tune" and "Level" to "auto" under "x264" tab and entering "-x ref=11".
 @tugshank yes I am, thanks.
	1.2 Changes:
 Download location.-Added: Interface changes
 -Fixed: "File Size" option wasn't saved
 -Fixed: Progress list wasn't visible if skin was disabled
 -Fixed: "Select all" subtitle selection didn't include srt files in some cases
 -Fixed: Settings weren't saved when some post-encode options were selected
 -Renamed: Program to "THandBrake"
 -Updated: HandBrakeCLI
 -Updated: MediaInfo to 0.7.69
  GUI Tool created for batch video tasksBy VirtualDoobMon in forum ProgrammingReplies: 10Last Post: 10th Jun 2019, 09:50
  Batch processing GUI for HCEncBy freebird73717 in forum ProgrammingReplies: 15Last Post: 20th Apr 2011, 22:31
  Simple batch encode H.264By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2009, 13:32
  Seeking A Better Hammer -- Simple GUI to Convert Ripped DVDsBy GrayStrickland in forum Video ConversionReplies: 10Last Post: 15th Feb 2009, 04:08
  DeVeDe - easy, batch capable video to DVD Linux/UN*X GUIBy danboid in forum LinuxReplies: 1Last Post: 23rd Oct 2008, 19:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
